| LinkBack | Thread Tools | Search this Thread |
| | #151 |
| Senior - BHPian Join Date: Jan 2008 Location: Poona
Thanked: 88 Times
| As it gets more expensive, it may find fewer buyers. Fewer buyers means lesser intrest to import it.... or for shopkeepers to stock it. Hope the newer stocks are at least FD rated. Hope Motul will import the 510. Hopefully it will be priced at around the range the semi-synthetics are selling. Have found more people who would be intrested in the product... Is anybody here interested in the Motul 510 (mentioned above, imported from France)? |
| | #152 | |
| Senior - BHPian Join Date: Oct 2007 Location: Bombay
Thanked: 32 Times
| Quote:
| | #153 |
| Senior - BHPian | Petronas is making bike smoother and smoother .. am Enjoying it , Smoke level has gone down a lot. Less Ring noise !! |
| | #154 |
Thanked: 88 Times
| | #155 | |
Thanked: 32 Times
| Quote:
I just stocked up another bottle of the 5000 2T for the rains and a 2000 4T for the gearbox. | |
| | #156 |
Thanked: 88 Times
| ^^^ Thanks for the pics! ![]() No ways Motul 710 (fully synth) will come that cheap. Motul is a French Import and Petronas Malaysian. I'm hoping the 510 will be priced where the other semi-synths are, if at all they bring it to India. Also remember, Petronas isn't even mentioning what base stock its using etc. It may not even be a true synthetic. Motul is Easter based and all... and thats expensive to produce. As for Sprinta 2000 4t - its 20W50!!? Dosen't RX also need 20W40? Whats the price anyway? I don't see a JASO rating either. Consider the Gulf Pride 4T Plus. Very good semi-synth oil. Made my CBZ-x smoother with better pick-up. Heats up less too. Price Rs. 200 (with discount). API SL, JASO MA2. Last edited by Raccoon : 22nd May 2009 at 00:58. |
| | #157 | |
Thanked: 32 Times
| Quote:
The 20W-50 works better when I ride for long periods and everything heats up. Its made the gears smoother now. I have even tried the Castrol full sythetic oil in the gear box which was 5W-40. Next, I'm thinking of trying the Petronas Syntium full synthetic in the gear box. | |
| | #158 | |
Thanked: 88 Times
| Quote:
The Castrol fully synth you mentioned must be CP1R. Its 10W40. How did you find it?? At least I wouldn't use a 20W50 where a 20W40 is recommended. Other things aside, it will create more drag... | |
| | #159 | |
Thanked: 32 Times
| Quote:
I had used the Castril Edge which is 5W-40. Its a good oil but my clutch plates were bad that time so didn't really get a good idea. After the rains I'll try a synthetic oil in the gearbox. So far the 20W-50 has not had any bad effects on the gear box or clutch feel. I think its better that the 20W-40 Motul I was using. | |
| | #160 |
Thanked: 88 Times
| I was talking about the oil for the transmission. I guess we have discussed almost all the currently available 2t oils already. Castrol Edge for gearbox?? :o Why not CP1R? (Castrol Power 1 Racing) Have you tried that? Motul fully synth is known to outperform that though. I was just looking at empty bottle of Castrol Jet X which is in my bike right now... and I notice that it no longer mentions its semi-synthetic! Intriguing... have they downgraded the oil and increased the price or what....?? ![]() Last edited by Raccoon : 23rd May 2009 at 14:23. |
| | #161 | |
Thanked: 32 Times
| Quote:
| | #162 |
Thanked: 88 Times
| No, I definitely remember the words 'semi synthetic' mentioned on the bottle. Maybe it was prior to 2007... probably prior to when it started carrying the 'Power 1' label. |
| | #163 |
Thanked: 32 Times
| | #164 |
Thanked: 88 Times
| ^^^Hehe. Now its higher than Rs. 200 for 1 lt. Thats what I said - they seemed to have removed the semi-synthetic part (label, at least), and keep hiking the price. Castrol is all about average products at premium prices. Spoke to someone from Motul. Was told they are importing the 510 and it should take about a months time. ![]() |
| | #165 |
Thanked: 32 Times
Similar Threads | ||||
| 2T - My '05 Yamaha RX135 | Viju | Motorbikes | 53 | 9th May 2013 10:59 |
| Does 2T oil the fuel really work? | amu1983 | Technical Stuff | 1 | 23rd December 2008 17:47 |
| can we use 2T oil in petrol for my '03 Pulsar | sankeerthreddy | Motorbikes | 2 | 19th March 2007 14:06 |
| What is the Difference Between a Two Stroke and Four Stroke Engine? | WILDTHING | Technical Stuff | 3 | 25th January 2007 07:46 |
| Wanted Castor based 2t oil or OWS 2t | cbr1000f | Shifting gears | 0 | 20th January 2006 10:28 |
