Old 8th April 2010, 21:55   #301
aargee's Avatar
Thanked: 2,143 Times
I kinda tend to agree with straight6 here. Reason? - I don't know what oil (in the right side in the engine) was used last time, but I'd my motorcycle running for 5400 Kms without any issues & changed air filter & cleaned up carbs partially. The ride was always a charm without any issues. But I guess the gears are bit harder till date (even after a change) & that's probably because of slight bend in the main shaft.
Old 9th April 2010, 20:50   #302
straight6's Avatar
Thanked: 118 Times
Picked up the Petronas Sprinta 4000 2T and the 2000 4T for balenopowers RXZ today. Should get a review from him soon.
Interestingly, Petronas have changed the grade of the 2000 4T to 20W-40. It used to be 20W-50.
straight6 is offline   Reply With Quote
Old 10th April 2010, 11:32   #303
Awaiting Email Confirmation
^^^ bro... wats the pricing of the sprinta 2T ?
nitin.dangayach is offline   Reply With Quote
Old 10th April 2010, 16:57   #304
straight6's Avatar
Thanked: 118 Times
It is for 195 bucks.
Old 12th April 2010, 17:32   #305
Raccoon's Avatar
Thanked: 105 Times
^^^Wish it was available in Poona. :( Good price! Cheaper than Castrol Jet X... and better, perhaps? Whats the manufacturing (not import) date, btw?
Old 12th April 2010, 18:02   #306
straight6's Avatar
Thanked: 118 Times
Import is '07. I'm sure manufacture is also '07. The blue bottle has a manufacture of March '10 and its already here.
Old 12th April 2010, 18:24   #307
Raccoon's Avatar
Thanked: 105 Times
2007 is old... at least I would not use it. Don't count on the Manuf. date to be of the same year! I think I had mentioned sometime earlier - Petronas salesman tried to sell me a bottle that was imported in 2007 and manuf. in 2005... if I recall corect. Of course I refused to buy it. I'v even seen some dealers smudge out the manuf. date! Beware.
Old 12th April 2010, 18:45   #308
straight6's Avatar
Thanked: 118 Times
My mech is using a bottle of Motul 800 since the last 8 yrs! He uses a few drops of it in the tank on long rides. If he can use it for 8 yrs without worrying its too old, I wouldn't be too worried either.
He's got two RX-100's of which one is highly ported (to a 135) and one ported RD-350. He's very finicky about most things and wouldn't have used it if he thought it wasn't a good idea to use old oil.
I've used Petronas before of the same year and it was superb. I once used Pennzoil and it was so bad that I drained it out within 20 kms and gave it to a rickshaw driver. I could immediately tell the difference and the bike felt like the engine was jammed and rusted inside.
Old 13th April 2010, 20:32   #309
Raccoon's Avatar
Thanked: 105 Times
^^^ To each his own, but fact remains that it is technically wrong. Generally oils are said to have a shelf life of 4 years at max... that too when stored as they should be. Personally, I would not it even upto 4 years.
Old 14th July 2010, 18:40   #310
straight6's Avatar
Thanked: 118 Times
The Petronas Sprinta 4000 was crap! I tried it and drained it the next day and gave it to the local mech. The bike became really rough. I used it instead of BP as I ran out of oil and the Motul 510 was out of stock.
I used 500 ml of Mak (which was much better than the Sprinta 4000) before I came back to the 510. Yesterday, I finally got the 800. Will try around 150 ml with the oil pump to see how it feels.
Old 14th July 2010, 21:02   #311
aargee's Avatar
Motul 800 2T is pretty expensive for daily use isn't it? I'm using Shell Advance now days. Costs about Rs 230 a litre; not sure if I can use anything good in that price range for daily use.
Old 14th July 2010, 22:01   #312
straight6's Avatar
Thanked: 118 Times
Yes, its too expensive but I always wanted to try it. I'm trying to get the 710. I don't think I'll ever go below the 510.
You can get the new Yamalube for 230. Saw it at the Yamaha showroom.
Old 14th July 2010, 23:54   #313
aargee's Avatar
Instead of Yamalube, I'll stick with Shell Advance for almost the same price. I haven't used Yamalube till date; besides accessebility is another big factor. How is Yamalube? Is it good? I've recently rebuild my entire engine replacing every single washer with new one, what's that you recommend for the run in period?
Old 15th July 2010, 05:53   #314
straight6's Avatar
Thanked: 118 Times
Mineral oil is best while breaking in for 1k. Then Full synthetic.
Old 16th July 2010, 13:31   #315
Raccoon's Avatar
Thanked: 105 Times
Well, as I'd mentioned earlier, I don't think any FC or above 2t oil is just mineral. So it would be appropriate to say try anything except fully synthetic in the run in period.
Renault's new two-cylinder, two-stroke 730cc diesel with 67 BHP & 145 Nm torque RavenAvi The International Automotive Scene 5 24th December 2014 07:39
What is the Difference Between a Two Stroke and Four Stroke Engine? WILDTHING Technical Stuff 3 25th January 2007 08:46
2 stroke ... 4 stroke ......6 STROKE ! pepper Technical Stuff 3 10th March 2005 00:58
two stroke engine akshitdewan Technical Stuff 1 10th April 2004 22:41
