Old 22nd April 2009, 08:39   #1
amtak's Avatar
Thanked: 342 Times
Default HH Hunk, Bike revs high on it own
Hi Gurus,
I have a Hero Honda Hunk which I purchased last year. Since 2 days I am facing RPM problem. The bike reaches 5,000 RPM in first gear and riding it is becoming increasingly difficult because of the vibrations in the handle. It has so far completed 6,000 KMS only and has been serviced every 3 months.
Please help!
amtak is offline   Reply With Quote
Old 22nd April 2009, 09:44   #2
five46's Avatar
Thanked: 80 Times
IMHO, looks like a accelerator cable or clutch setting problem. A visit to the Service Center should cure it.
five46 is offline   Reply With Quote
Old 22nd April 2009, 10:10   #3
amtak's Avatar
Thanked: 342 Times
Could this also because of air filter clogging?
Old 22nd April 2009, 10:16   #4
cruiser_1982's Avatar
Thanked: 16 Times
This could also be an idling problem as well. Does the RPM increase when its in neutral? Do check if you are riding with choke on. These are small things which you might have checked already, but no harm in checking them.
cruiser_1982 is offline   Reply With Quote
Old 22nd April 2009, 10:28   #5
amtak's Avatar
Thanked: 342 Times
I checked the choke part. Its not on. I guess you are right. Even in neutral, I remember seeing the RPM meter hovering between 1-2k. Planning to take her to the service station in the evening.
Old 22nd April 2009, 10:44   #6
five46's Avatar
Thanked: 80 Times
Theoretically Yes! But, I don't think so it is the case with yours.
Do check the manual, I think there should be a mention of the revs the bike should have at idling after becoming a bit warm.
Then also have a look at the placement of the idling adjustment screw in the manual and adjust it accordingly. It's a pretty easy DIY job.
If the manual doesn't help you in doing this, do ask about its whereabouts at the service center.
Old 22nd April 2009, 10:55   #7
amtak's Avatar
Thanked: 342 Times
Thanks Five46 I'll keep you all posted on what happens!
Old 22nd April 2009, 11:01   #8
five46's Avatar
Thanked: 80 Times
Cheers! Do update about it in your bike's proprietary thread as well.
Old 22nd April 2009, 11:02   #9
bblost's Avatar
Thanked: 6,663 Times
amtak. bunch of questions.
At what rpm did the bike idle before this issue.
At what rpm does it now idle.
Does the rpm raise on its own or under acceleration.
Do you need to acc more now for pickup.
Has this continued to occur over more than one tankful of petrol.
did you change your filling station by any chance.
did you use Premium petrol instead of ordinary or vice versa.
Has the top speed changed.
Does the vibration also occur when not acc at all.
Old 22nd April 2009, 11:50   #10
amtak's Avatar
Thanked: 342 Times
At what rpm did the bike idle before this issue. Never noticed this
At what rpm does it now idle. 1K min. Just at startup!
Does the rpm raise on its own or under acceleration. Only after I accelerate but goes upto 5k even at the slightest acceleration. Never used to happen this way.
Do you need to acc more now for pickup. Yes
Has this continued to occur over more than one tankful of petrol. This started happening when my last tankful was getting over. Continued ever since. About 3 days now.
did you change your filling station by any chance. Last tankful I had to, but filled in from a reputed COCO
did you use Premium petrol instead of ordinary or vice versa. No. Normal fuel.
Has the top speed changed. Yes, Now it is between 60-70/80 instead of 110!
Yes. It vibrates a lot.
The bike is touching 5k mark in the fifth gear and the speed is just 50 KMPH. Vibrating like a nokia 3310
Old 22nd April 2009, 11:54   #11
bblost's Avatar
CLUTCH.
Either the clutch is fried or the cable is jammed up.
Old 22nd April 2009, 12:10   #12
Technocrat's Avatar
Thanked: 2,492 Times
Wow that was one nice list of Qs Bblost
Amtak looks like a Clutch plate problem.
Btw do one more thing, next time the bike revs high try to pull the choke lever & see if the revs come down.
Btw did you show this to Service center guys?
Old 22nd April 2009, 12:17   #13
amtak's Avatar
Thanked: 342 Times
CLUTCH.
Oops! but I am a sedate rider.
Priyank, I am taking the bike to the service center today in the evening and would leave it with them. I tried to pull the choke, the engine cuts off. I showed my bike to the TBHP service guys first. Trust them more than the HH folks!
Old 22nd April 2009, 12:23   #14
praJEEP's Avatar
Ask the HH guyz to check the regulator, i was facing the same problem in my extreme and the regulator was the culprit.
praJEEP is offline   Reply With Quote
Old 22nd April 2009, 12:39   #15
Technocrat's Avatar
Hmm Usually if the bike is too lean it revs high on hot days & pulling choke brings the revs down. Anyways looks like carb/throttle issue if not clutch.
Btw Who's Priyank
1st Bike - Hunk/Pulsar/RTR/Unicorn? EDIT- Its a Hunk amtak Motorbikes 40 26th September 2013 18:10
Zen exhaust spitting lots of carbon powder at high revs after cold start!! devrajman Technical Stuff 32 20th June 2010 08:28
Tachometer Needle Vibrates at High Revs - Help amannarwal Technical Stuff 17 28th March 2008 11:02
revs too high during fst 5 mins... babe_on_wheels Technical Stuff 4 16th March 2006 17:09
Clutch Problem - Revs shooting up (Baleno) zaphod Technical Stuff 18 1st April 2005 13:49
