Old 1st May 2009, 15:33   #16
Raccoon's Avatar
Thanked: 105 Times
Originally Posted by dinar View Post
The spark plugs were not from Mico, they were [bosch] imports and I do not remember the model number.It's been really long time now. I sold my bike in 2001.
Ohhh ok. But aren't these BOSCH plugs marketed here by MICO? Do you get Made in Germany plugs too?? The W5BC I bought for my Shogun in Made in India... and carries both MICO and BOSCH names on the box.
If they are imported by MICO, I wonder why I was told by MICO that they they only have the single electrode W5BC for the gun... no fancy options.
On the other hand the NGKs I'v seen are all Made in Japan.
Raccoon is online now   Reply With Quote
Old 1st May 2009, 16:59   #17
Thanked: 53 Times
The plugs were 4 point, imports were not by me but a shop near my collage, I had picked a box of them 4 in box. Do not remember the the model. They were Bosch German made. No idea about the mico imports thou.The once I picked were not marketed as shogun specific for that matter any Indian vehicle specific. It was a case of me wanting a new spark plug and going to a shop to by one, the owner shows me a plug "these are new from Bosch just got a freash batch" Will it fit my bike? "we'll try". and than after a week of riding the bike I pciked the whole box for 4 plugs.
MICO plugs are not bad. I think MICO had launched two point plug in between , have no idea if they are still made.
dinar is offline   Reply With Quote
Old 1st May 2009, 17:26   #18
Raccoon's Avatar
Thanked: 105 Times
^^^Oh?! You never bothered with the heat ranges, reach, etc??
Anyway, that explains why there are no other options in the market. They do have multi electrode options for other bikes though... thats what I was told. Don't know if they are Made in India or imports.
Old 1st May 2009, 21:28   #19
Thanked: 53 Times
The heat range was close to the spec sheet[actually a lil colder]...the reach was as the factory once and there were some longer but those did not work well the bike heated soon.. but my bike needed a lil more with the mods it was running....I believe they were manufactured for some car and not bikes.
Just remembered the Mico plug were made for Kinetic Honda not for shogun[they were longer].No company in India bothered about a low volume bike.
If your getting the NGK in your spec range buy those. Anyways your bike does not have mods to the engine.
Old 2nd May 2009, 01:54   #20
Raccoon's Avatar
Thanked: 105 Times
Ok, I think its time for me to summarise my recent experience -
Have used the following plugs -
NGK BP8HS - Recommended by TVS. Available as TVS Genuine Spare with TVS dealers. Non-resistor type plug. Made in Japan.
NGK BPR7HGP (G Power, Platinum) - Recommended by NGK for Shogun, Samurai, Rx100, etc. Resistor type plug Made in Japan.
MICO BOSCH W5BC - The only other plug recommended by TVS for the Shogun. Non-resistor type plug. Made in India.
Have always used the HP8HS till now. Recently bought the NGK BPR7HGP. The bike seemed to get smoother with this plug. However I suspected loss of pick up/power. Firing also seemed a bit subdued. Engine seemed to vibrate a bit less. Cannot comment on any change in fuel efficiency as did not use it long enough. No change in RPM observed (compared to the old BP8HS)... though even the NGK auth. dealer said RPM will increase a bit. When the spark plug was removed, it did not seem to be in the best state... seemed oily and bit blackish! This in spite of being a hotter plug. Have never seen this before in my bike - the BP8HS plugs always seemed dry and brownish!
Replaced the above plug with a new W5BC. First thing I noticed was drop in idling RPM (about 200 - 300). Now I'm not sure if this is good or bad... I don't see how this can be good! Any comments anybody? The next thing noticible was the firing changed slightly. The bike seems to roar louder and seems more peppy! Pick up seems to improve! Bike feels rougher though... but whats the use of smoothness if its going to rob the power? Cannot comment on plug condition and change in fuel effeciency... will be checking that soon.
Now in spite of NGK recommending resistor plugs, it seems they are not suitable at least for the Shogun. Yes they do "work", as some of you have stated, but the question here is not to find what works! The idea is to find what works MOST OPTIMALLY!! Its very likely users of other bikes like Samurai, Rx, etc., where the recommended plugs are non-resistor type, may also see a similar difference. Its very likely that the older ignition systems are not designed to fire resistor type plugs. These resistor type plugs are supposed to add a 5 k ohm resistance to the circuit... which seems to reduce the spark voltage and hence intensity across the electrodes.
I just have one doubt though - the resistor plug I tried is a platinum plug. So cant be sure if the difference observed is because its a resistor plug or because its a platinum plug being compared with nickel plugs.
Resistor plugs usually have an "R" in the part number. So anybody using NGK's BPR7HS, BPR7HGP, etc., please consider comparing with non resistor plugs like NGK BP8HS or BOSCH W5BC and feel the difference.
Old 2nd May 2009, 05:21   #21
straight6's Avatar
Thanked: 118 Times
All I can say about the W5BC is that my bike starts with just one kick (and I mean one kick only) even if I haven't ridden it for 2 days. That never happened with the NGK BPR7HGP. Of course, the engine is now in its best state of tune than it has ever been before.
I'd like to see if it will still start like that after more than 2 days. Will keep you posted. The other thing is, when I start the bike cold, it idles fast for around 2 minutes and then slows down. It reminds me of Honda's PGM-FI for the CBR's!
straight6 is offline   Reply With Quote
Old 2nd May 2009, 15:09   #22
Raccoon's Avatar
Thanked: 105 Times
Intresting... your bike seems to be behaving as if it has a ECU... provided you aren't using the choke.
Suggest you compare the MICO W5BC with the NGK BP8HS. You will likely see a further improvement...
Which plug does Yamaha recommend btw?
Old 2nd May 2009, 15:35   #23
straight6's Avatar
Thanked: 118 Times
My mech had suggested that one to me as well. I'll try it sometime later.
No idea what Yamaha suggests.
Old 2nd May 2009, 18:50   #24
praJEEP's Avatar
Straight6 untill and unless you are using chambers there is no need for any other plug than W5BC for an rx, take my word for it.
praJEEP is offline   Reply With Quote
Old 2nd May 2009, 23:20   #25
Raccoon's Avatar
Thanked: 105 Times
^^^I saw a clear change in idle RPM between the old nickel BP8HS and the W5BC. As I said earlier, not sure why that is so or what changes I will observe with that... but there does seem to be a difference between them!!
Also some people say NGKs last longer. Can't make a personal comment about that as I haven't had the opportunity to compare their durablity.
Ignition, Spark plugs and Plug Wires - Questions? S@~+#0$# Technical Stuff 8 10th December 2017 14:45
Pulstar plugs! Are the spark plugs obsolete? Is it a scam? Sankar Technical Stuff 8 4th October 2009 01:58
Honda/HH Tuff-up tubes for other bikes (Shogun) Raccoon Motorbikes 13 6th July 2009 01:23
Spark Plugs and Wires bmdesai1987 Modifications & Accessories 0 6th October 2007 10:59
K&N for 800 mpfi 5 speed (EDIT: Bigger alloys, FFE and spark plugs) addyrulz01 Modifications & Accessories 7 27th August 2007 17:25
