Old 12th May 2009, 10:17   #1
mithun's Avatar
Thanked: 49 Times
Red face Can Stability go for a full toss because of a tyre ?
I had replaced my front stock tyre with a Dunlop Maxi-Rib Plus 2.75-17 41P. I had completed about 8000 KMS after replacing both the tyres. Rear is Dunlop Geo-Cruiser 100/90-17 55P.
I had searched for a better 17" tyre(esp. from the MRF stable) before making this choice, but due to no stock(and due to my busy schedule) I had to satisfy myself with this tyre. When I was searching, most of the shops at Cochin told that they are not having any Pulsar 17" tyres. I'm wondering how come there is a shortage for Pulsar tyres since it's the segment leader. And, it was hard for me to digest !
Now, after fitting the Dunlop my Bajaj service personnel told me that this is one of the worst front tyres known to him & it would jeopardise both braking & handling !
Now after riding for about 8,000 KMS I feel that he was right, although I'm not 100% sure. I'm not getting any full stopping power with my front discs. Also, the handling is not upto mark.
And, I've checked all the essential factors that contribute to bad handling like swingarm, forks, bearings, wheels etc.
So I want opinions of TBHP-ians about this tyre. Please tell me whether this tyre is a utter crap or not....
Old 12th May 2009, 10:29   #2
kannan666's Avatar
Thanked: 69 Times
Am not at all convinced that the Dunlop ribbed tyre is up to the mark, have always used MRF on my bike (Yamaha RX 100) and have found it to be really good. Ribbed tyres actually give better steering and line holding ability but does not offer much grip while braking while the converse is true if we use normal treaded tyres up front, then directional stability does go for a toss ! Yes, the RX does not have disc brakes up front while the pulsar does, so the above mentioned factors will be even more important on a pulsar I guess. Have ridden a pulsar but not that extensively to offer specific advise but I'm sure other T Bhpians will help you out here !
kannan666 is offline   Reply With Quote
Old 12th May 2009, 10:53   #3
Thanked: 3,507 Times
Friends who have used rib tyres on their Enfields with disc brake have nothing good to say bout them, their complaint is that it tends to skid easy and it dosn't brake straight. Guys using non rib tyres, Ceat Secura and Nylogrip, at the front on Enfield with disk brakes find that the vehicle stops better and holds the line under braking.
Old 12th May 2009, 16:47   #4
Raccoon's Avatar
Thanked: 105 Times
Hmmm... your tyre looks exactly like the tyre I'v recently installed on my Shogun... can't recall the exact model at the mooment. My tyre is 18" however.
Can you elaborate on this? How exactly are you defining "full stopping power"? Do you mean the tyre skids and wheel locks up much earlier than your previous tyre? And whats wrong with the handling?
I'v been using this tyre since a month now, and my take is that it does exhibit which I could call "tyre squirm", while taking turns.
Also the gap between the treads seems to be excessive. This would result in reduced contact patch and also maybe make the tyre more prone to punctures from sharp objects. On the other hand it MAY result in better performance on wet roads (haven't checked this out yet as it hasn't rained since). But these are just my speculations... haven't had any punctures yet. I thought of this before buying it, but could not get anything better... and didn't want to hunt more. The Dunlop Zebra was there but the compound seemed harder and the tyre thinner. MRF I did not want to consider as MRF mostly uses harder rubber. And I hate the Zapper Y on my CBZ-X.
Have done uptil 95 kmph couple of times on this tyre. Have not noticed any apparent issues with braking or handling on this tyre (other than the squirm). But then the Shogun does not have a disc brake either. Also the tyre is of a softer compound and I guess it should be lighter too (though I forgot to compare weights of the front tyres before purchasing). A lighter tyre is a definite plus.
In brief, I'd say this is not the best tyre you can have. But saying its "utter crap" would be an exaggeration.
Lastly, have you checked if you your air pressure is right? Makes a huge difference. I'm sure you know most gauges are inaccurate.
Old 12th May 2009, 18:59   #5
Spitfire's Avatar
Thanked: 692 Times
Infractions: 0/1 (7)
People still buy ribbed tyres?
Spitfire is offline   Reply With Quote
Old 12th May 2009, 19:05   #6
kannan666's Avatar
Thanked: 69 Times
Well, I bought mine nearly 8 years ago, the Yamaha has run only around 25K kms after that !
Old 12th May 2009, 20:27   #7
Raccoon's Avatar
Thanked: 105 Times
I don't know why, but 4 tyre dealers dissuaded me from going for the Zapper FS/Dunlop Zebra kind of pattern for a bike without front discs. None of them were able to provide any logical reason for this other than saying that the bike will skid and grip will suk, etc.
Old 13th May 2009, 13:16   #8
mithun's Avatar
Thanked: 49 Times
By "full stopping power", I meant the grip is missing(like when we wear different footwear).
The tyre is lighter than my old tyre and I've read somewhere that this pattern is good for rainy seasons !
The tyre will behave in the same way whatever be the pressure !
Old 13th May 2009, 14:49   #9
kannan666's Avatar
Thanked: 69 Times
That is not true ! If the tyre is under inflated, then contact patch is more and therefore grip on the road is better. Likewise, if the tyre is over inflated, contact patch is less which translates into lesser grip on the road. In fact, this knowledge is used in sandy regions where tyre pressure is deliberately reduced to get better grip and purchase from the surface.
Old 13th May 2009, 14:57   #10
bblost's Avatar
Thanked: 6,662 Times
How old is this tire?
The year and week of manufacture shall be printed on the side wall.
If the tire is older than 4 ~ 5 years, the rubber has gone hard and it is not advisable to use it.
Originally Posted by Raccoon View Post
^^^Absolutely. Tyre pressures make a huge difference. I suspect you are saying that because you are checking with inaccurate gauges(s).
within 15 mins, so reusing this post to say +1 to the quote.
For a good fun filled ride fill -5 psi (than req) in rear and +5 psi (than req) in front.
Watch your bike sway away to glory.
Old 13th May 2009, 15:00   #11
Raccoon's Avatar
Thanked: 105 Times
Old 13th May 2009, 16:11   #12
mithun's Avatar
Thanked: 49 Times
What I've meant is that there is not too much difference !
The tyre was less than 6 months old when I had purchased it & 7 months have passed since.
Old 13th May 2009, 16:35   #13
Raccoon's Avatar
Thanked: 105 Times
Btw, are you on alloys? If yes, did you get the wheel balanced?
Also, did you check that the bead has been seated evenly throught?
Old 18th May 2009, 11:09   #14
mithun's Avatar
Thanked: 49 Times
I'm having spoke wheels. Recently done wheel truing for both the wheels.
Old 18th May 2009, 17:42   #15
Raccoon's Avatar
Thanked: 105 Times
^^^The truing is done is a pretty crude way. Suggest you check yourself if its satisfactory.
One more thing comes to mind - hope you have checked that the tube size exactly matches the tyre size and that the tube is genuine. When I changed my rear tyre couple months ago, the shopkeeper actually passed on a bigger size tube... and later when I confronted him, they had the cheek to say it makes no difference so they did nothing wrong!!!
Citibank's Bill pay feature goes for a toss! benbsb29 Shifting gears 28 29th June 2012 22:52
Handicapped vehicle takes a toss noopster Street Experiences 6 11th October 2010 14:42
Can it be because of duplicate JBL components or very bad installation? kaushik_s In-Car Entertainment 16 17th May 2009 23:23
Santro Xing Front Bumper gone for a toss - to claim or not is the question !! DDGuy Indian Car Loans & Insurance 35 9th January 2009 17:17
Another Enzo goes for toss..this time in seoul.. 1Day The International Automotive Scene 8 11th July 2006 00:13
