Go Back   Team-BHP > Around the Corner > Motorbikes
Motorbikes Everything related to the two-wheeled breed.
Thread Tools
Old 25th May 2009, 23:53   #1 (permalink)
Wink Bullet Heart transplant
Hi guys, I just thought I should share this with you. My friends bullet was the 6th dissapointing 350 AVL bullet to be released by Bullet in India and the early ones were a flop. I believe that all things got to do with the number '6' is pure bad luck(Satan's number). We had been to our Bullet dealer in Vellore, Tamilnadu and wanted to improve our 350 machismo. We were promptly offered a new 500 cc stock AVL engine for Rs 35,000. This engine contains cylinders, crank case, crank and shaft, everything new. Just keeping the old gearbox. That's really cool, now all of you out there, don't waste money on re-boring an old engine. If you don't want an AVL engine, just go for a new "Cast iron engine", it costs Rs 15,000. Just get a load of that. It's a heart transplant that's worth every penny.
drsamuelk is offline   Reply With Quote
Old 26th May 2009, 19:24   #2 (permalink)
Torque-ative's Avatar
Refreshing thought process ! However is the 15000 for 350 CI or 500 CI !! Wishful thinking ??? You betcha !
__________________
Dont lie,...that way you'd have less to remember - Indian Larry
Torque-ative is offline   Reply With Quote
Old 26th May 2009, 20:15   #3 (permalink)
Rennjit's Avatar
Originally Posted by drsamuelk View Post
..We were promptly offered a new 500 cc stock AVL engine for Rs 35,000. This engine contains cylinders, crank case, crank and shaft, everything new..
That's too cheap for an Enfield engine. Are you sure its a Complete engine which can be directly loaded on to rest g'box & frame without any component transplants from the engine which goes out. For 15K it happens to be the most reliable & efficient refurbishment process ever.
__________________
Lone rider...
Rennjit is offline   Reply With Quote
Old 26th May 2009, 20:33   #4 (permalink)
desideep's Avatar
where can i get one?
__________________
2002 SUZUKI ZEN | 1993 YAMAHA RX100 | 1977 RE Bullet 350 STD | 2008 HH CBZ | 1997 LML NVSpl
desideep is offline   Reply With Quote
Old 1st June 2009, 23:29   #5 (permalink)
Yep thats what we were quoted, just gotta keep the old carb, exhaust and gearbox. But getting one from the firm will take time, just like we're waiting for a new one from the firm. Gotta provide them a copy of the RC book to get the engine number etched on the casing.
Old 1st June 2009, 23:32   #6 (permalink)
15 K for the 350 CI and 35K for the 500 AVL (without the carb)
Old 2nd June 2009, 18:43   #7 (permalink)
jeepster's Avatar
We had been to our Bullet dealer in Vellore, Tamilnadu .
hi drsamuelk
i have 88 bullet std which i have converted (or restored ) to an pre 60 one (for looks 0nly).
if the engine assembly is for 1500 i am interested in it.
give more details of the dealership as telephone number or email,etc.
if possible ask for the price of the new chassis also.
__________________
Jeep there is only one
mahindra 750 dp
jeepster is offline   Reply With Quote
Old 3rd June 2009, 02:33   #8 (permalink)
An what about the displacement change ? will that reflect in the RC ?
I am guessing that the dealership is assembling the engine from parts and getting the number stamped . I do not think you are getting an offer from RE .
Old 3rd June 2009, 02:35   #9 (permalink)
The characteristics of the AVL and Machismo engine are different . DO both of them share the same gearbox ?
Old 9th June 2009, 20:47   #10 (permalink)
No all new engines are procured from REM, we are at the final stage of clearance at the firm's head office, too much paperwork and red tape. Finally when it's approved the firm confirms the previous engine number, they stamp the numbers on and give it to us. I know this because when we get this engine, it will be REM engine no 3 on the same chassis. Yes we have been thro this process of changing the engine once before but things were a little faster because it was in the warranty period. Prior RTO clearance has to be obtained, which is a formality. And yes the gearbox are all the same, it should mate. Guys have you heard of a chap in chennai who mates a maruti 800cc engine to a bullet gearbox. It's possible, as the gears are in a different integral enclosed cassette with the first drive shaft jetting out. That's what makes a bullet so versatile. No other bike on the Indian road has such a gearbox. The next time you see a 'Custom bike build' on 'Travel and living' watch ssome of the engines closely, they are Vtwin engines and seperate gearbox briven by 2 belts. The bullet's gear box is something like that. I wish we could import Vtwin engines in India too.............Until then happy ridin.
Old 9th June 2009, 23:22   #11 (permalink)
N....next time you see a 'Custom bike build' on 'Travel and living' watch ssome of the engines closely, they are Vtwin engines and seperate gearbox briven by 2 belts. The bullet's gear box is something like that. I wish we could import Vtwin engines in India too.............Until then happy ridin.
do you mean these bikes have two sets of gearboxes? pardon my ignorance but I was under the impression that the two pistons are mated with the help of some crank case or something
__________________
RX 135
somspaple is offline   Reply With Quote
Old 10th June 2009, 10:18   #12 (permalink)
jkdas's Avatar
350AVL was what? It was an engine on high spirits.
And 500 cc stock AVL engine for Rs 35,000. This engine contains cylinders, crank case, crank and shaft, everything new. Wow! jump at it!
__________________
Audio, video, disco
Tat tvam asi
Old 12th June 2009, 00:33   #13 (permalink)
Wow! Thats interesting, does the same apply for the 535 also ?? eg. can I use the 535's head and cylinder and the rest of it from any different RE model ?
nitro.1000bhp is offline   Reply With Quote
Old 17th June 2009, 23:58   #14 (permalink)
Unhappy
{http://www.realclassic.co.uk/bullet07082100.html}
please follow the above link and check out the 2 part series on the 612cc bullet transformation. It's food for thought. Make us look like suckers!
In fact check the Real Classic - All about buying & selling, riding & restoring real classic motorcycles site and bullet is found under royal enfield motors, there are a host of other mods people have done with their bullet. Money and know how seems to be the bottom line, we have neither of these. It's depressing sometimes, how we're satisfied with 17 - 24 BHP.
Old 30th August 2009, 11:22   #15 (permalink)
I spoke to Hitchcock's a few months ago and asked if I could order performance cams for the AVL. They said, they were developing a high lift cam set for the AVLs which will be out for Christmas. Can't wait.
Cheers,
Jay
JayPrashanth is offline   Reply With Quote
Thread Tools
Can we transplant a liquid cooled Lombardini Diesel engine in a RE bullet? kkr2k2 Motorbikes 28 16th July 2009 19:53
safari engine transplant sanket12 Modifications & Accessories 16 6th September 2008 17:39
heart needed for transplant prabhuav Shifting gears 2 9th October 2007 11:11
Engine Transplant For 1000 axcman Technical Stuff 15 10th June 2006 03:02
Alto - Engine Transplant!!! urdudesamy Technical Stuff 6 3rd June 2006 00:36
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
