Old 27th May 2009, 01:01   #16
Bhargava_sr's Avatar
Thanked: 17 Times
Awesum work Joel, Saw the video - setup seems to be real cool, need to feel the power by a small TD
Bhargava_sr is offline   Reply With Quote
Old 27th May 2009, 01:50   #17
ananthkamath's Avatar
Thanked: 46 Times
Who did the camshaft for you? What about ignition timing - is that something you can change or you have to use the stock curve?
ananthkamath is offline   Reply With Quote
Old 27th May 2009, 08:20   #18
crazydiablo's Avatar
Thanked: 21 Times
Damn good stuff man. I dont think he can change ign timing. If you are tuning further its good to hook up an o2 sensor. Does this FID work like a power commander? I am suprised you can get good fuelling results from a diag tool.
How was the condition of the head? In terms of quality? Carbon build up?
crazydiablo is offline   Reply With Quote
Old 27th May 2009, 11:12   #19
Thanked: 639 Times
cool mods! And they seem to have paid off to. Awaiting dyno and other results. BTW, how much did the mods cost you? Is the price to performance ratio +ve? Its a totally different aspect that you did it cause you wanted to and didnt really bother to count the expenses.
Nilesh5417 is offline   Reply With Quote
Old 27th May 2009, 13:11   #20
fieroid's Avatar
Thanked: 286 Times
Nope, ignition timing is unaltered. STill using the stock ECU.
I had plans of hooking-up an O2 sensor, but didnt really find the need now. But will need one soon. The FID works a bit like a power commander, however not completely. You dont have the option of playing with curves but. With this tool you can only go lean and rich on fuelling. More like how we do jetting in a carb engine, but electronically thats it.
The head has excellent casting quality compared to the Indian casted heads. These engines are completely built and assembled in Thailand. Carbon build-up was very minimal for a 12k kms run engine when I opened. Stock engine runs very clean.
@Ananth - I got the camshaft ground abroad. Its a 270deg grind. Still using the stock curve.
Joel
fieroid is offline   Reply With Quote
Old 27th May 2009, 13:26   #21
jsmonu's Avatar
Impressive work there brodie!!
Love how the lower rev power seems to pump up quickly..
Wish all R15s could have that thrust initially too.. That's probably the only reason I'm still so perplexed about going for an R15.
Also, on the point mentioned by silver_shadow.. is fitting the 140 from FZ16 into an R15 -
1) doable ?
2) a good idea ?? :P
3) again.. not considering loss of fuel economy ?
Cheers!
J.
jsmonu is offline   Reply With Quote
Old 27th May 2009, 14:46   #22
fieroid's Avatar
Thanked: 286 Times
^silver_shadow was just kidding man. The swingarm itself cant accomodate any larger than the stock rubber. The stock tyre is excellent and can take a lot more power and grip levels are unheard of any other Indian made tyre.
Old 25th October 2010, 13:38   #23
Killer's Avatar
Thanked: 7 Times
Resurrecting this thread again to post a Video update. I dont believe there was ever a video of the bike in action, so decided to make one. Things have come a long way since 2009
Note from Team-BHP Support: Please DO NOT post videos/pictures depicting speeding on public roads. Do treat this as a warning. Thanks!
Last edited by mobike008 : 25th October 2010 at 14:20. Reason: Mentioned in the post
Killer is offline   Reply With Quote
Old 25th October 2010, 13:51   #24
Abbas's Avatar
Thanked: 27 Times
@killer: are you crazy !!! that`s absolutely rash and careless riding. If you really wanna test your bike, then go take it to a track. But doing this on public roads is completely irresponsible and dangerous. Request mods to remove the video immediately.
Abbas.
Abbas is online now   Reply With Quote
Old 25th October 2010, 13:56   #25
yogeshnaik's Avatar
Thanked: 40 Times
At which workshop all the work has been carried at Bangalore? After the modification were done did you check the BHP you got using a dynamometer?
yogeshnaik is offline   Reply With Quote
Old 25th October 2010, 13:56   #26
Thanked: 82 Times
awesome video..a couple of tight moments though.Says a lot bou man and machine.Way to go
octane1002 is offline   Reply With Quote
Old 25th October 2010, 14:02   #27
aargee's Avatar
Thanked: 2,105 Times
@Abbas - Cool; they've taken a different race modded R15 to track & I believe it has clocked over 205 Kmph & is supposed to be the fastest R15, atleast in India (could be in this planet though).
Yeah, you're right, they could've posted the video from testing it on the track rather than on the road.
Old 25th October 2010, 14:04   #28
manishalive's Avatar
Thanked: 699 Times
Originally Posted by fieroid View Post
Engine:
*Stock airbox and filter
*Stock throttle body and intake tract
Joel
Just wondering why you left the air filter to the stock, since everything else has been prepped up. And since the bike is Fuel Injected, me think the computer will taake care of excess air flow from a better (free flow) air filter.
^The stock rubber can do a lot more than what you can imagine
I read in Overdrive or Bike, that the rubbers (thin ones) were excusively designed for R15, infact jointly developed by MRF and Yamaha. If we change to any other the goodness is all gone. The stock ones are just make for R15. Any one please don't change them.
Old 25th October 2010, 14:05   #29
Killer's Avatar
Thanked: 7 Times
Abbas.
It was an easy run on a fairly open road, as far as i'm concerned i wasnt taking any risks to be too worried about...thats hardly rash riding. I realize rules are pretty strict here, Mods can remove the video if they wish to..
Old 25th October 2010, 14:08   #30
Killer's Avatar
Thanked: 7 Times
Actually the race bike should do around 160kph true speed (havent tested all out speed yet), dont know where the 205 came from.
Yup, heading to track this weekend, will take some all out videos
Replacing Tyres 195/60 R15 With 215/75 R15 in Ford Fusion singhisking Modifications & Accessories 14 11th January 2016 22:23
OMG!! A Hummer H2 tuned by Germans! Stratos The International Automotive Scene 20 25th June 2008 19:48
Novitec tuned Ferrari 360 X-Machine The International Automotive Scene 13 22nd September 2004 21:56
Tuned Indigo from Me Stratos Shifting gears 11 6th September 2004 19:12
HQ Pics of S-class tuned by A.R.T M POWER The International Automotive Scene 6 9th August 2004 22:32
