Old 26th May 2009, 15:58   #1
fieroid's Avatar
Thanked: 287 Times
Default My Tuned R15
Its my 7 months old R15 with 12000kms on the odo and not stock anymore. Completed a performance build about 2 days ago.
Here are a few specs of the bike as of now. The specs are always due for changes as and when I desire.
This is purely a street build and not a race build. key is reliability, economy and rideability. All works are done by me.
Engine:
*Ported and polished cylinder head with altered port geometry
*Custom valve springs
*Stock Valve sizes
*Reprofiled valve seat area
*Stage 1 spec camshaft with custom ground profile
*High compression set-up
*Modified cylinder and stock piston
*Fine tuning and set-up corrections
*Stock airbox and filter
*Stock throttle body and intake tract
Fuelling:
*Stock Injector
*Stock ECU + coil
*Altered AFR values for fuelling inputs
Gearing:
*Stock sprockets
*Stock Gearbox
*Stock Clutch
External:
*Stock looks
*Hand crafted Tuned Free Flow exhaust
*Full stock weight, no lightening
Performance:
0-60 – (awaiting tests)
0-100 - (awaiting tests)
Top-speed – 140kmph (As tested on 24/15/2009 on GPS and Speedgun, with rev-limiter cutting off speeds @ 10000rpm) with full stock mass.
The engine has higher low-end torque than a stock R15 untill 5000rpm and from then on, it gets into the powerband with a stronger pulse. The engine is very streetable and reliability is as much as stock. After being thrashed for over 200kms last afternoon and being pushing to top-speeds numerous times as part of my destructive tests, there was not a hitch in performance or engine NVH levels. The engine stills returns decent fuel efficiency for the power it generates. It’s approximately around 30-35kmpl.
Sunday, when I tested the bike, a stock R15 would clock 119 to a max of 125kmph on a hopelessly windy road (with multiple efforts) and at the same point my R15 clocked 131-138kmph. And recorded a max of 140kmph on a clear patch, with the rev-limiter kicking in @ 10000rpm.
I will also do a Dyno run and post results here.
Will post the pics a while later.
A small video of the exhaust note and the rpm climbing.
http://ishare.rediff.com/video/cars-...aha-r15/622960
Joel
fieroid is offline   Reply With Quote
Old 26th May 2009, 16:23   #2
srijit's Avatar
Nice going Joel BTW, your video link is faulty.
srijit is offline   Reply With Quote
Old 26th May 2009, 16:48   #3
fieroid's Avatar
Thanked: 287 Times
Sorry
Rediff iShare: Joels yamaha R15
Old 26th May 2009, 17:04   #4
fieroid's Avatar
Thanked: 287 Times
some pics of the bike
Old 26th May 2009, 18:05   #5
2StrokeJunkie's Avatar
Thanked: 13 Times
joel does that FI box come with all R15s ?
if u dont mind i have a few more questions .
how much distance did it take to hit 140 kmph ?
how much is it doing in 400 meters ?
whose done ur exhaust and head porting ?
2StrokeJunkie is offline   Reply With Quote
Old 26th May 2009, 18:21   #6
fieroid's Avatar
Thanked: 287 Times
Your answers,
The FID is an import. Its to rework fuelling and diagnoise Yamaha FI engines.
It took about 700-800mtrs to clock the 140kmph mark.
Does about 121kmph in 400mtrs. Stock does 112.
I have done the entire works myself.
Old 26th May 2009, 18:27   #7
sanjaymugur's Avatar
Thanked: 53 Times
nice work there Joel, thats a good grunt from the exhaust, a lot lot better than girly stock exhaust...
since Joel is a both a very good rider & a tuner i trust his work more than the other self acclaimed garage tuners....
hopefully someday u will take up some mod works on my YAMAHA GLADI....
sanjaymugur is online now   Reply With Quote
Old 26th May 2009, 18:37   #8
Thanked: 58 Times
Looks good, any plans to change the rear rubber. As the stock seems be outfit for this baby.
sam003 is offline   Reply With Quote
Old 26th May 2009, 18:44   #9
fieroid's Avatar
Thanked: 287 Times
^The stock rubber can do a lot more than what you can imagine
Old 26th May 2009, 19:29   #10
no dude you need to put the FZ 140 rear because it's uber cool! j/k!
silver_shadow is offline   Reply With Quote
Old 26th May 2009, 20:35   #11
Thanked: 13 Times
yea the R15 has got mind blowing cycle parts ... sorta like a TZ but with lesser power . infact even the other yamaha entry the Fz has got excessive cycle parts for its puny engine .
great work joel . i never knew u used to tune . heard u used to go the zen and then shankar .
Old 26th May 2009, 20:43   #12
fieroid's Avatar
Thanked: 287 Times
This is news to me man. Wonder where the rumours erupt from.
Thanks man!
Old 26th May 2009, 20:48   #13
Thanked: 13 Times
ah well its a small world
Old 26th May 2009, 22:59   #14
swift8847's Avatar
Great job buddy. A superb build just like the other builds of yours.
Btw which part of bangalore do you stay? Would love to see your bikes sometime.
swift8847 is offline   Reply With Quote
Old 26th May 2009, 23:06   #15
srijit's Avatar
Just saw the new link to the video. Congrats man!!! That is a cool jump to the reline when you revv it. Very nice!!!
Replacing Tyres 195/60 R15 With 215/75 R15 in Ford Fusion singhisking Modifications & Accessories 14 11th January 2016 22:23
OMG!! A Hummer H2 tuned by Germans! Stratos The International Automotive Scene 20 25th June 2008 19:48
Novitec tuned Ferrari 360 X-Machine The International Automotive Scene 13 22nd September 2004 21:56
Tuned Indigo from Me Stratos Shifting gears 11 6th September 2004 19:12
HQ Pics of S-class tuned by A.R.T M POWER The International Automotive Scene 6 9th August 2004 22:32
