Go Back   Team-BHP > Around the Corner > Motorbikes
Motorbikes Everything related to the two-wheeled breed.
Thread Tools
Old 26th May 2009, 23:41   #1 (permalink)
ron_9191's Avatar
Default Need opinions on Shell Helix 20W - 50 Oil for the Royal Enfield Bullet Electra 4S
Hi there fellow BHPians! I am planning to change the my Bullet Electra 4 Speed's engine oil to Shell Helix 20W - 50. I was very impressed with Shell oils coz I used it on my Baleno Vxi and boy oh boy the differences was quite noticeable. The car is super smooth now and the power delivery and the throttle response has improved drastically. I know the technology used in my bike is a million miles away from what is used in my car, but it still keeps me thinking that I should go for the Shell Helix. Please advice ....
__________________
2006 Baleno Vxi
2005 Bullet Electra 4s
ron_9191 is offline   Reply With Quote
Old 27th May 2009, 00:59   #2 (permalink)
desideep's Avatar
We used this oil in our Bullet Standard and our electra one the same day. we went from delhi to Gurgaon it was a total of around 35 Km run. it was hot sunny summer day last year. and when we got to gurgaon the engine was very hot tried to check the condition of oil i miss took it as warm water when my friend touched my hand with the dipstick. we drained the oil from the Electra rite away. it was flowing like any thing not thick at all.
300 some rs were going to go down the drain. but not rite way.
we got a can of Veedol Turbo star and put that into the electra again a run from IFCO chowk to New Delhi Domestic Airport and come back
check the bikes the Veedol was amazing and the Oil in my STD was again the same like the drained oil. so that means in roughly 70 KMs we had decieded never to touch that oil again for The bullets for sure.
now we had almost 6 L of oil to our disposal . i thought of using it in my Wagon R but was not sure so gave it to a friend to use it for his really old Maruti 800.
My borther uses Shell for his car he is very happy with it. i dont know what exactly he uses
__________________
2002 SUZUKI ZEN | 1993 YAMAHA RX100 | 1977 RE Bullet 350 STD | 2008 HH CBZ | 1997 LML NVSpl
desideep is offline   Reply With Quote
Old 27th May 2009, 01:40   #3 (permalink)
first of all, unless you are superman, there is no way by visual, touch or feel that a normal human being can make out whether one engine oil is better than the other.
the interpretations can be so different, for example:
1. warm oil as opposed to hot oil can also mean that the oil is not taking away the heat from the engine as required by it.
2. clean and clear oil despite running thousands of kms can also mean that the oil is not cleaning up the carbon in the engine.
Etc. etc. ect.
so lets not judge an oil until its put to a proper lab test. for example, all human perceptions of great performance and super smoothness of synthetic oils vs mineral oils are just hallucinations. no way we can make out a smoother running engine just by feel on the wheel.
i know that many may object but believe you me, what i am saying is true. of course am not saying that if you use 90w inplace of 40w that one cannot feel the diff. all am saying is that humanly its not possible to feel the difference in performance be it veedol 20w-40 or shell 20w-40.
__________________
life is a beach....enjoy it!
surYa
hollywoodhogan is offline   Reply With Quote
Old 27th May 2009, 01:48   #4 (permalink)
drastically? come on!!! dont tell me that the manufacturer recommended "groundnut oil" until you discovered that shell "drastically" improves performance??? no way jose!! its all in the head of the driver. you mean to say that hp, bpcl, iocl make poor lubricants that compare drastically negative to shell? not at all my friend.
__________________
surYa
Old 20th June 2009, 19:03   #5 (permalink)
ron_9191's Avatar
Running Shell Helix 20w-50 on the Bullet now. And trust me it is super smooth!!. I thought may be I was just feeling good or may be it was just me. So tried on one of my friend's Bullet Standard. He says the difference is far too much to explain. both of our bikes idle clean, makes very low noise from the valves at high RPM, and the most important thing is that vibrations have come down. Which is a good thing!!!. Try it out my friends. I m sure you will be happy about it.
__________________
2006 Baleno Vxi
Old 20th June 2009, 19:46   #6 (permalink)
Raccoon's Avatar
Instead of using Shell Helix, which is a car oil why not use a fully synth oil for bikes? Motul makes some xW50 oil for bikes, I believe. Would be much safer to use that. Price will also in the whereabouts to what you pay for Shell. Whats more its Ester based which I'm pretty sure Shell is not.
Old 21st June 2009, 06:40   #7 (permalink)
straight6's Avatar
Thats the 300V and its available in 15W-50.
straight6 is offline   Reply With Quote
Old 24th June 2009, 20:32   #8 (permalink)
ron_9191's Avatar
You guys are right straight6 and racoon. There are better oils available. But the difference here is that Shell performs better as the oil is a lot more thicker, which is very good for the bullet with a cast iron bore. Coz if you go for a thinner oil like the 5w-50, it can develop unwanted oil leaks on your bullets, which I am sure you wouldn't like. Well I am no scientist here, but Shell Helix 20w-50 has been running on my bike and I love the way my bike goes now. I feel a day and night difference between the stupid Veedol 20w-50 which the company recommends.
not the 5W-50. I meant to sat 15w-50
__________________
2006 Baleno Vxi
Thread Tools
Long Ride , Royal Enfield 350 CC Electra 4 S - Bangalore to Harihara thimappa Route / Travel Queries 3 18th May 2009 03:35
Royal Enfield Bullet oil change... ron_9191 Motorbikes 69 18th April 2009 08:51
What are the different ways to reduce weight on a Royal Enfield Electra 5S JayPrashanth Motorbikes 17 31st October 2008 22:03
For Sale:Royal Enfield Bullet Machismo binz Shifting gears 0 24th September 2006 13:54
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
