Old 14th June 2009, 16:31   #1
nawabnabeel's Avatar
Thanked: 32 Times
Default Bought karizma alloys for cbz!
guys yesterday i bought karizma alloys for my cbz. the rear brake drum of both the bikes is 130mm but the front disc is 276mm in karizma and 240mm for cbz. will the alloys fit my bike. also i want to use my bikes disc in the alloy wheel. is this possible. mine is a 2002 model cbz classic. please help.
nawabnabeel is offline   Reply With Quote
Old 14th June 2009, 18:37   #2
Thanked: 160 Times
The disc wont fit, U need to go for the karizzma's disc, then again the callipers wont align so you'll have to go for the karizma's forks or you can get the cbz drum brake forks and do a weld on it to fit the callipers (not recomended) But before all this you have to check if the shaft is the same size for the alloys. My suggestion is to return the alloys and save the money.
nitro.1000bhp is offline   Reply With Quote
Old 14th June 2009, 22:18   #3
Thanked: 32 Times
are you sure they wont fit? how many bolts does karizma has for mounting the disc on the alloy wheel?
Old 14th June 2009, 23:13   #4
Ricci's Avatar
Thanked: 995 Times
You can try a spacer to offset the calliper placement, but if the spacer isn't well designed ( accurate and rigid ), you'll get poor braking . Safer bet is a full Karizma fork unit .
Ricci is offline   Reply With Quote
Old 14th June 2009, 23:26   #5
rider60's Avatar
Thanked: 47 Times
all you need a good modifier mate.
i am running Zma's alloys on my unicorn too. the stock is the same as cbz but i have managed to use the same caliper set and stock fork set.
PM me your mail address i will try and send you some pics of the same for you to get an Idea as the what to do fit the 276mm disc
nothing to be worried about, just find a modder with enough common sense and experience to do this job.
rider60 is offline   Reply With Quote
Old 15th June 2009, 00:20   #6
Thanked: 32 Times
a big thanks to both of you for your positive replies. i was really scared but getting ray of hope now. hey ricci i didnot get your spacer concept can you elaborate a bit on that. hey rider60 i am pming you my mail id.
Old 15th June 2009, 01:49   #7
Thanked: 160 Times
@ rider60
He said his bike had a 240mm disc buddy, and i'd love to know how you managed to modify the hub ?? as I know its tough to get it done with the same kinda alloy but, did u make the hub alone with steel or how?? please share the info if possible..
Old 15th June 2009, 22:19   #8
Thanked: 32 Times
i tried fitting cbz-xtreme's front wheel on my bike and it fitted properly even with the extreme disc. what do you all think i should do? put xtreme's mag on the front or modify the
karizma's wheel that i have?
Old 17th June 2009, 23:44   #9
rider60's Avatar
Thanked: 47 Times
dude i dint receive any pm. if you need the pics send me one.
Old 18th June 2009, 00:43   #10
Thanked: 32 Times
i just sent you one again. please check
Rumour: Hero Karizma, Karizma ZMR production stopped Aditya Motorbikes 45 21st November 2016 11:36
Purchasing a Used Bike in PUNE - EDIT - Bought a Karizma aravindwarrier Motorbikes 13 13th June 2010 01:29
bike for weekend rides EDIT - Bought a Karizma kkr2k2 Motorbikes 42 12th August 2009 14:27
Pulsar's alloys on cbz!!! chiragh_bir Motorbikes 9 1st June 2008 02:34
Bridgestone G3 and Alloys for my Swift - now bought Chetu Tyre & Alloy wheel Section 44 8th May 2007 17:17
