Old 21st June 2009, 04:27   #1
pratap007's Avatar
Angry Karizma 5th Gear Problem..Please Help
Hi, A 2003 model karizma purchased second hand was discovered to have a rather serious problem. The bike accelerated quite smoothly through all the gears but when you shift into 5th at whatever speed, after a few seconds it automatically shifts back into fourth, proving very dangerous at high speeds.
1. The clutch plates were changed.
2. The center line packing used was inferior quality and idiots had used double packing, which was corrected as well.
3. Then we discovered that duplicate packing was used all over so the entire packing for the engine etc.. was changed.
3. There was a small part of the shifter inside which was fitted incorrectly(dont know the exact name) that was corrected and fitted according to the manual.
4. Basically, we went by the book and every part was examined for undue stress or wear and tear but to no avail. The gearbox was then assembled after making sure all the parts were present, but the problem persists.
If anyone has faced such a problem on any other japanese bike(as I 'm assuming the gearboxes would be similar)as well Could you please post a detailed explanation as to how the problem was fixed....any and all help will be appreciated.
Thank you.
pratap007 is offline   Reply With Quote
Old 24th June 2009, 12:00   #2
akshay4587's Avatar
Thanked: 1,686 Times
i faced kinda same problem when my zma's gear box broke.
it would not engage into 5th gear.so i had to get gear box stripped open again,and it was caused due to incorrect part usage,almost same structure of the internal shifters,just small difference.
Old 24th June 2009, 14:37   #3
Thanked: 54 Times
the dog legs might be worn out .. or u r mechanic might have missed a small washer .. LOL
Also check if the shifter drum grooves are worn out or the shifter drum has any slackness .
Rumour: Hero Karizma, Karizma ZMR production stopped Aditya Motorbikes 45 21st November 2016 11:36
I have lost the '1.5th Gear' of my Tucson - Pls. help me find it kamal.sn Technical Stuff 33 15th August 2011 11:47
Swift 2nd Gear Problem EDIT: Now first gear problem BUSA Technical Stuff 85 2nd September 2009 18:47
5th-gear noise?! ghostrider4385 Technical Stuff 25 7th February 2006 00:07
5th gear presenters!!! Shan2nu Shifting gears 7 12th February 2005 18:10
