Old 18th July 2009, 23:19   #61
coolboy007's Avatar
Thanked: 1,440 Times
@ sam sant 2005,
Thanks a lot for that short yet informative review. Seems all earlier problem areas areas are rectified by Bajaj this time.
I was a bit worried about cold start as 220 doesnt has a kick starter, do such bikes start in chilling delhi weather without fuss?
So you are giving full care in the running in good, dont know who you people are able to control. Got my Linea and the most i could control was 700-800 kms, after that back to 4-5k rpm shifts occasionaly.
coolboy007 is offline   Reply With Quote
Old 19th July 2009, 08:07   #62
sam_sant2005's Avatar
Thanked: 151 Times
@PatienceWins:
About the engine getting hot I havent noticed yet. I drive only a max of 8kms oneway to office. So havent had any such overheating issues.
I heard the 200/220 engines have been like that and the new oil cooler(with 33% more cooling area) will deal with it. Moreover we have a Engine Temp sensor too, so no ISSUES, atleast we ll know whats coming!
@All:
15 THINGS TO CHEER ABOUT BAJAJ PULSAR 220 DTSi
Did you people know,P220 has :-
1) Blocked air filter indicator
2) Low oil level indicator
3) High engine temp indicator
4) Low battery charge warning
5) Engine temp based ignition mapping
6) Low fuel indicator light apart from fuel gauge
7) High RPM warning
8) Not just Tubeless tyres, it has SOFT Compound tubeless, till now seen only in R15. Its a special grade COSTLY tyre which gives unbeleivable road grip.
9) Graphite based short skirt piston (not sure about the correct term), for anti-seizure capabilities. So high engine temp shouldnt be something to get worried about.
10) 21bhp and 0 to 100 in 11.1 secs which is almost equal to Hyundai Verna CRDi and much much FASTER THAN cars like swift
11) DC wiring. HL switches ON even when engine is OFF.
12) Low beam projector HL is awesome. Highbeam is also powerful since 55W bulb is used.
13) Starter cuts off automatically for a few secs after continuously repeated cranks to protect itself from burn out.
14) Gearbox and Clutch assembly provided by FCC RICO (who are suppliers for Hondaclap
15) Avg mileage till now for owners is above 40kmpl.
and more things too !! and after all these a price of 70k (Ex-Showroom). dont you think this is the best VFM bike in India currently.
an question :- I heard FZ sucks. is it? One proff racer friend of mine said it doesnt even go above 105kmph! And its a stupid bike with just looks and nothing else! And now Fazer is out with same engine!
Last edited by Technocrat : 19th July 2009 at 09:34. Reason: Only 2 smilies per post allowed, please read the board rules carefully before proceeding. Thanks
sam_sant2005 is online now   Reply With Quote
Old 19th July 2009, 09:38   #63
Technocrat's Avatar
Thanked: 2,492 Times
Out of the 15 you have mentioned, these below have been there on most of the earlier pulsars
7) High RPM warning
I am not sure if the carb one has this, all it has is Auto Choke which allows the bike to be started with ease in cold starting conditions.
Old 19th July 2009, 09:55   #64
PatienceWins's Avatar
Thanked: 261 Times
Thanks Sam. It seems to be good value for money. Good that Bajaj is continously improving their products.
My only worry is whether they would start discontinuing their products soon, as happened for 200. I have a 2000 model Fiero and I heard that some spare parts are getting difficult to source. The vehicle has not given any problem other than clutch plate replacement and a leaking fuel tank. The fuel tank is unavailable and I am using the old tank by fixing the leak with M-Seal.
Waiting to see the new Karizma. I hope it wont be costly. 220 seems to be good VFM with all the features.
PatienceWins is offline   Reply With Quote
Old 21st July 2009, 20:16   #65
Thanked: 151 Times
7) High RPM warning
Try googling you will be more than happy to find that P220 DTSi does have engine temp based ignition mapping. Ignition has nothing to do with FI/Carb dude, its just about setting the 'timing' on when to fire the spark plugs.
And about other things I really havent seen a Pulsar other than 220 till date which has DC wiring. And in which other can you keep Headlights ON when engine is off? Not to mention that in new P220, the HL auto cuts off after a few seconds if engine is off!
Air filter, low oil and other misc things which I mentioned, I agree might be there in older pulsars but I was merely talking about P220 DTSi FEATURES dude.
FEATURES OVER FEATURES that is P220 DTSi for you
Old 22nd July 2009, 12:18   #66
Technocrat's Avatar
When Did I say they are related? All I said was that carb has Auto Choke feature which you might be confusing for engine temp based ignition mapping. That said it has both.
Did you check the P200, it had the same feature.
Old 24th July 2009, 20:07   #67
Thanked: 151 Times
Default Mileage - 41kmpl
ODO - 365kms.
Twice I checked and I got 41kmpl.
I use my P220 DTSi daily to office which is 9kms away from home. I have three Traffic signals which bear the highest traffic (in Kerala). Basically although its a NH47 Bypass. So can say its like 60% highway, 40% very slow moving traffic. I ride in 55 - 65kmph.
So by any chance I feel this bike should fetch a MINIMUM of around 45-48kmpl on Highway under normal driving.
Old 25th July 2009, 10:49   #68
coolboy007's Avatar
sam_sant2005
Thanks for that FE update. I am still unclear what would new p220 give in city though it hardly matter because my Honda Activa gives below 30 as i ride it hard style as fast as it can go I am sure i will get more in the p220.
Wasnt Bajaj claiming something above 50 on highways? Lets wait till one of you go on a full highway trip.
Old 5th August 2009, 17:51   #69
Thanked: 151 Times
Default FE update
ODO - 600kms
I have increased my driving speed marginally from 50-60 kmph to 60-65kmph.
So the mileage I got now is 39kmpl. (60% heavy traffic)
I ll be giving for first service next week so expect a further increase in mileage after that.
By any case I think on a long strech without much traffic, this bike should fetch above 45kmpl in cruising speeds of 55-65kmph.
Old 5th August 2009, 17:57   #70
Technocrat's Avatar
What revs do you shift gear?
Old 5th August 2009, 18:51   #71
Thanked: 151 Times
3000-3500 probably. My top gear ride will be around 4k+
Old 11th September 2009, 11:35   #72
MurtazaGhiya's Avatar
Thanked: 35 Times
@Sam_Sant2005:
Whats your experience of owning the 220 after some long time now?
I plan to get this beauty home next month . Would you recommend it?
MurtazaGhiya is offline   Reply With Quote
Old 12th September 2009, 07:06   #73
sriramv.iyer's Avatar
Thanked: 710 Times
First, Congrats on the new bike! It is probably the best around -
I was reading the new features you had mentioned, and for me it was heart breaking to see 'soft compound' tires - I have an R15, and these tires are so much prone to punctures - I've already replaced my rear tires, and I have 2 punctures already
May be these tires are meant for the tracks - Why put them on a street bike? :(
sriramv.iyer is offline   Reply With Quote
Old 12th September 2009, 13:46   #74
Thanked: 151 Times
Hi Guys,
Its almost two months and ~1500kms. Iam totally happy and satisfied with the performance of the bike.
Only aprehension is when some say, off late Bajaj bikes have bad engines. As of now everything is fine. My old pulsar stood well for 5 yrs and 35k kms.
So a bit scared to rip it the way i used to in my P150. So i drive normally in gears. Just drive smoothly without undue strain on the engine. Though have taken it to 125 once.
The bike is heavy and hence has great control on the highway. It does well on minor potholes. well planted and confident.
If engine stays like this, anyday P220 DTSi is the best bike in the country today for the price
Mileage:
Worst 33. Best 41.
Avg 36-37.
Current driving speed 80-90kmph city. Mileage 35
Old 12th September 2009, 14:57   #75
Thanked: 261 Times
Sam, Happy to know that you are happy with the bike. You are fortunate to have less traffic in Cochin compared to total chaos like Bangalore. My native is Cochin.
There have been reports of 220 engines become harsh once they clock some mileage. Good that you are taking care of it properly during the inital period.
Pulsar 220 (new) or the Apache RTR 180 - EDIT - Bought Pulsar 220 M abhayshanu Motorbikes 203 1st March 2011 14:27
Pulsar 220 DTSi with R15 headlight sam_sant2005 Motorbikes 13 15th October 2010 21:49
A Dichotomous Soul: RE Classic 500 or Pulsar 220 DTSi GreaseMonk Motorbikes 50 28th June 2010 15:55
2000 kms with the Fastest Indian!!!! (Pulsar 220 DTSi) abhinav.s Motorbikes 68 30th April 2010 20:55
Bajaj set to launch killer performance bike! EDIT - Its Pulsar 220 DTSi (carb not Fi) devil_in_flesh Motorbikes 69 6th July 2009 23:07
