Old 28th February 2010, 10:34   #46
Originally Posted by DeepakMenon View Post
Cool; where did you get the work done?
What kind of PIston; Crank are u running?
You should throw the stock running gear; make some money while you do it and upgrade the suspension; the stock gear is not so great unless to spend $500 + to change all internals [As they are more than 20 year old]
What ignition? Stock? Apparately 31K has the best curve [51L marking on CDI]
Those pipes are not 31K pipes; they are either 1UA or the same i have [The end cans should have 51L stamped on them] if yes then you would be running hot unless you do some mods as they are rz250r pipes;
Last question what chain are you running?
Nice Stanc eyour bike's got
The Bike was a 29L 250 the same was converted into 350.
Internals were changed completely around a year back.
CDI is stock
Pipe Cans have been modified as per new specifications
Chain is from Karizma
Pistons Tkrj .50
Crank Stock
The bike is completed by Sumit Speedwayz Noida
I was actually Ok with OEM things because the quality for the same is good and also I was not comfortable spending more on it as I will not be keeping it with me for a longer period or you can say I am planning to upgrade.
Champ111 is offline   Reply With Quote
Old 13th December 2012, 09:25   #47
crazydiablo's Avatar
Thanked: 21 Times
Default Re: Yamaha RZR.. dream come true
Inspired by Deepak's bike I built my own Dream RZ. Its been a long journey but in the end it turned out not so bad. Don't want to create a new thread so adding it here for the 2 stroke fanatics:
Spec Sheet:
RDDreams Stage 3 48H cylinders on 2nd oversize
Wiseco Prolite Long Rod Pistons
RDD Balanced and welded Crank with 115mm Hot Rods (Long Rod Setup)
Keihin PWK 28 Carbs
Banshee Reeds
UNI Filters
Jim Lomas Mild Steel Pipes with Ali-end cans
OEM Yamaha steel plates
EBC HD Clutch plates
Toomey HD Clutch Springs
RG500.com High Capacity Radiator
Talon Ali Sprockets
RK Chain Kit
Suspension:
Front: RGV VJ22 USD Forks
Rebuilt and setup with Adnreani Kit:
Harder spring set K6.5
New precision ground/ hard chromed damper shafts
New piston head 7075 Ergal Aluminium, anodised/ machined, revised oil flow.
New shim stack, dyno tested and configured
New by-pass spring for sharper transition
Ohlins fork oil - selected and supplied by Adriani.
Rear: RGV VJ22 Banana Swing Arm
Penske 8975D Series Fully Adjustable Shock custom built by MDM
Brakes:
Front: Brembo 16X18 Radial Master cylinder
RGV Tokico 4 pot calipers
RGV 300 mm rotors
EBC Sintered HH Brake pads
HEL Steel Braided lines in Carbon Black
Rear: Brembo Master cylinder
RGV Tokico Caliper
Aftermarket Wavy 210mm Rotors
EBC NON- Sintered Brake pads
Wheels and Tyres
RGV Suzuki 3 spoke wheels front and back
Dunlop Sportsmax 120/70R17
Dunlop Sportsmax 150/60R17
Misc Mods:
7 inch round Headlamp
Trailtech Vapor Digital Meter - Speed, RPM, Temp etc
Billet Tank Cap
Pingle Fuel Tap - Dual outlet
Oil Pump block off
New 31K Wiring Loom
New Banshee Stator and stator plate
New CDI and PV controller
Motul Fluids
Coolant - Motocool with Water wetter
crazydiablo is offline   (5) Thanks Reply With Quote
Old 13th December 2012, 15:25   #48
balenopower's Avatar
Thanked: 228 Times
Looks fantastic..no chance of making it semi faired?
balenopower is offline   Reply With Quote
Old 13th December 2012, 20:51   #49
Asif 6959's Avatar
Thanked: 20 Times
Love live 2-strokes.
The list of work gone into is beyond my intellect. How long did it take you to complete the build. Would like to see the before and after pics.
Asif 6959 is offline   Reply With Quote
Old 14th December 2012, 06:44   #50
Thanked: 21 Times
No plans to make it semi faired. Its gonna be a street fighter. I am posting a before picture below, I got the bike as a non runner. It took me 3 years of planning, buying and learning to do this.
crazydiablo is offline   (4) Thanks Reply With Quote
Old 6th August 2013, 15:03   #51
Thanked: 68 Times
Thumbs up Re: Yamaha RZR.. dream come true
A beautiful mean machine, it clearly pulls in every gear without a hitch, you will feel like to whack open the throttle even more. The suspension on the vehicle is really impressive you will have full confidence and control on the handling.
An awesome build which no one will attempt to go this further in India (period).
TwinHead is offline   Reply With Quote
Old 7th March 2015, 10:51   #52
aravind511's Avatar
Thanked: 48 Times
Smile Re: Yamaha RZR.. dream come true
This is first post on the forum, I am deepak and i wanted to share my dream come true bike (Not named it yet)
Specification
Engine (All work done by RDD with mild porting)
  • Yamaha RZ250 RR converted to 350 using 48H barrels
  • Wiseco 0.50 Pistons
  • New Wiseco banshee Hot crank assemebly
  • TM28 carbs
  • TZR 6 petal reeds with fiber petals
  • All gearbox internal replaced to new
  • Brank new clutch bell & primary
  • Stock Exhaust
  • Stock air box with UNI filter
Running Gear (TTW mumbai)
  • Stock RZR frame (No modification)
  • RGV250 VJ22 USD fork
  • VJ22 braced aluminium swingarm
  • RGV wheels
  • RGV stock caliper & disc
  • Ohlins 3 way adjustable rear shock
Instruments
  • Stock RZ tacho speedo unit
  • Switch gear R15
Body Work
  • Stock Tank & panels
  • RGV front & rear mudgaurd
  • TZR125rr front fairing with headlight
  • FZR400RR rear view mirrors
Electricals
  • Rewired to accept R15 ignition key & switch gear (Wanted the yamaha key)
  • Zeeltronic programable CDI (Replaced stock CDI, YPVS controller)
Let me know what you think of it
Hi bhpians.
I have picked up this machine now.. She still rides smooth but the paint scheme and pipes have been changed. Zeeltronic is no longer firing properly so it's been switched back to stock CDI. Presently it's running on 3rd OS bores.
aravind511 is offline   Reply With Quote
Old 28th March 2017, 21:30   #53
aravind511's Avatar
Thanked: 48 Times
Originally Posted by aravind511 View Post
Hi bhpians.
The bike has been with me for more than 2 years now and the journey has been fantastic so far. Many thanks to Deepak for building it from ground up and for Bino for keeping her up over the years. She pulls up really nice and fast and once the power valve opens she gives both or.. and ear.. gasms..
Rode her to Goa once and for many short trips in and around here.. She is definitely a keeper
aravind511 is offline   (2) Thanks Reply With Quote
Dream Come True. The Skoda Octavia vRS!! Update: 59,712 kms HAFI Test-Drives & Initial Ownership Reports 76 13th September 2014 23:07
Been Leh'd & back: The dream come true! lordofgondor Travelogues 174 30th August 2013 17:43
Dream Come True - Our Dream Machine Diesel 2.2 VTT @ 35,000kms kdeepakk Test-Drives & Initial Ownership Reports 58 24th July 2010 14:39
A dream come true - Scorpio SLE (Black) Anoop RD Test-Drives & Initial Ownership Reports 21 7th December 2009 22:13
NVIDIA Ion platform - the car PC dream come true randomgyan In-Car Entertainment 35 17th September 2009 18:44
