Go Back   Team-BHP > Around the Corner > Motorbikes
Motorbikes Everything related to the two-wheeled breed.
Thread Tools
Old 11th August 2009, 23:28   #16 (permalink)
bj96's Avatar
Originally Posted by Sawyer View Post
Another angle on why the right foot gear shifters are a good idea - not too many people will ask to ride your bike on a casual basis...
+1.
However, for left shifters,ask the casual borrower to kick start in one go. If he can't start, he can't ride, etc.
9/10 will fail this test as they are used to generous twisting of throttle while starting.
1/10 will bounce the challenge back to you. Just impress him with your bullet skills
This test has worked for me on my e5s.
-BJ
__________________
If Columbus had turned back, no one would have blamed him.
Of course, no one would have remembered him either.
bj96 is offline   Reply With Quote
Old 12th August 2009, 07:17   #17 (permalink)
@BJ - the thing is that for right shifters, they do not ask you in the first place, so there is no strain on the friendship! Of course, for many such as I, it is also the reason for not buying it - I had two bikes, and while I could have learnt to ride one with the right shift, I was not sure I could cope with switching back and forth.
__________________
If anything is worth doing, it is worth doing well
Sawyer is offline   Reply With Quote
Old 23rd September 2009, 14:48   #18 (permalink)
ron_9191's Avatar
Hi Desideep. I have a question on what you mean by "Point replacement Kit. that is being made by Autoescorts Bombay." What is this thing? Is it similar to the TCI that comes in the Electra 4S and 5S?? If it is not, can we advance and retard the timing using the point replacement kit??
__________________
2006 Baleno Vxi
2005 Bullet Electra 4s
ron_9191 is offline   Reply With Quote
Old 29th October 2009, 20:24   #19 (permalink)
Default Electra 5s vs 4s
Though I will revive this thread instead of starting a new similar one. I am in the market for a used 500 CI, but it is hard to come by. As a result, also evaluating Electra 5s vs. 4s.
I am looking for some inputs from experienced riders about the Electra(just in case a 500 does not materialize fairly soon).
1. The front shocks on the Electra look slightly different from the standard, are these an improvement over the standard?
2. Does the Electra come with 18" wheels? If the rear wheel is now 18", did RE compensate by changing the size of the sprocket or changing the gearbox?
3. The 5s has a 5th gear, does this make highway cruising relaxed compared to the STD/4s? In other words, is the 5th taller on the 5s compared to the STD/4s's 4th?
4. Is the quality of the gear shift on the 5s any way better than the 4s or is it worse? Personally, the neutral finder is the redeeming feature of the 4s's gearbox, I am somewhat inclined toward the 4s.
The RE showroom here in Hyderabad isnt offering test rides and I dont know anyone here who owns a 5s. I have been told that a 4s is still available for ordering. I dont care about the electric start, but consider the disc brake and electronic ignition vital improvements, so the STD 350 is not in contention.
Beast_of_Burden is online now   Reply With Quote
Old 29th October 2009, 20:43   #20 (permalink)
I own a Electra 4s with disk brake and have posted my reolies In Bold.
Hope it helps..
Originally Posted by Beast_of_Burden View Post
1. The front shocks on the Electra look slightly different from the standard, are these an improvement over the standard? Yes The shocks are different And are definately an improvement over the Standard and the rear shocks are Gas filled
2. Does the Electra come with 18" wheels? If the rear wheel is now 18", did RE compensate by changing the size of the sprocket or changing the gearbox? The Electra Comes with 19 Inch Wheels in the front as well as the Back
3. The 5s has a 5th gear, does this make highway cruising relaxed compared to the STD/4s? In other words, is the 5th taller on the 5s compared to the STD/4s's 4th? I have riden my friends 5s and compared to my Electra 4s i have not felt any major difference in Highway cruising.
4. Is the quality of the gear shift on the 5s any way better than the 4s or is it worse? Personally, the neutral finder is the redeeming feature of the 4s's gearbox, I am somewhat inclined toward the 4s. The neutral finder is worth its weight in gold as far as i am concerned And the gearshift is not all that different.
__________________
I Love surprises, That's why
I Bought a Bullet
Born 2 Be Wild is offline   Reply With Quote
Old 29th October 2009, 21:23   #21 (permalink)
Great inputs, thanks. The 4s is a better choice if the final ratio is the same, especially for someone who has ridden either the std 350 or the 500 CI only.
However, Electra 5s's are relatively plentiful on the used bike market compared to the 4s. As a result of the generous supply, a very good 5s can be had for 65k which is excellent value IMO. I can live with left side gear shift and lack of neutral finder( have gotten used to riding an interim P180 which has a lousy gearbox for a modern bike) if all else is the same for all practical purposes.
Old 29th October 2009, 22:22   #22 (permalink)
bj96's Avatar
The final drive ratio is same (1:1) in both 5s and 4s. Hence, top gear cruising should not be different. However, the gears in 5s are closer spaced, hence city riding would be slightly better on 5s. The 4s gear box is prone to leak (grease + oil). My 5s gearbox hasn't leaked in 3.5 years- it uses (more modern) EP90 gear box lubrication. However, if you can find a new 4s- go for it for its pure bullet experience . Engine and ride wise there won't be any difference between a 5s and 4s.
-BJ
__________________
Old 29th October 2009, 22:45   #23 (permalink)
Randhawa's Avatar
The final ratio on the 4s and 5s is same. Only difference is the gap between 3rd and 4th on 4s is reduced in 5s gearbox. Means less downshift, I found 4s a bit irritating while driving on some rough roads through Himalayas.
But you can get a set of gears from UK to reduce the gap in 3rd and 4th on 4s.
Randhawa is offline   Reply With Quote
Old 29th October 2009, 23:00   #24 (permalink)
Unless there is/was a significant price difference, most std 350 customers ought to have been buying the 4s. I don't think RE sold too many of the 4s, if the availability in the user bike market is any indication.
I have one other query relating to the shift quality itself on the 5s. Is there a difference meaning better or is it false neutrals galore as usual?
Considering the 5s is more easily available in the used bike market, that should swing it decisively in its favor. IMHO, the fact that the gear shift is on the left and there is no neutral doesn't really detract from the authentic bullet experience, I am sure I will quickly get used to it.
Old 30th October 2009, 11:21   #25 (permalink)
Rennjit's Avatar
Originally Posted by bj96 View Post
The final drive ratio is same (1:1) in both 5s and 4s. Hence, top gear cruising should not be different...
Originally Posted by Randhawa View Post
The final ratio on the 4s and 5s is same...
Could you guys explain what is meant by final drive ratio 1:1 ? hope primary & final chain drives have same ratios in both machines. From RE manuals, gear box top ratios are like: 4S> 5.32:1 & 5S> 4.726:1. Any advantage to 5S in terms of top speed/ lower engine rpm at same speeds?
__________________
Lone rider...
Rennjit is offline   Reply With Quote
Old 31st October 2009, 12:30   #26 (permalink)
bj96's Avatar
I correct myself. I meant final gear (5th in 5s and 4th in 4s) ratio is 1:1 as Bullets have no overdrive. My bad for using wrong terminology.
Correct.
Ok, here are the sprockets teeth on both models:
1. Engine= 25T
2. Clutch= 56T
3. top gear teeth = 16T for 4s and 18T for 5s.
4. Rear wheel sprocket teeth= 56T
Use this website Modern Motorcycling Ltd. | Suzuki Motorcycles, Ratio's Page, 'Dealer of Choice!' to calculate the RPMs and speeds of 4s and 5s at top gear. The engine max RPM is 5500 on both.
At 3000 RPM 4s makes about 70 km/h while 5s makes 79 Km/h. In other words if you are cruising at ~70 km/h, Electra 5s engine will make less RPMs, more relaxed, hence, better fuel economy. The difference is about 10%.
-BJ
__________________
Old 31st October 2009, 12:54   #27 (permalink)
bj96's Avatar
-BJ
For a std 19" rim + tyre, Bullet wheel dia is about 26".
Rear wheel chain sprocket is 38T (not 56T as posted last)
__________________
Last edited by bj96 : 31st October 2009 at 13:10. Reason: corrected rear wheel chain sprocket teeth
Old 31st October 2009, 17:26   #28 (permalink)
@Bj96 - Any idea about of the number of teeth on front sprocket(smaller one off the gearbox)? Do all the models have the same number of teeth on the front sprocket? If the answer is No and if the sprockets are freely swappable, the possibility of making the final drive ratio, for that matter all ratios a little taller by putting in a sprocket with an extra tooth exists.
My bro had bought a used 1970 bullet which had one tooth less than the standard for reducing the ratios, an adaptation for a bike that is mostly ridden in the hills. As might be expected, it was sprightly but had extremely low top speed . So the idea of swapping sprockets is not new, it has been around for a long time. We thought it was a characteristic of the old engine, found out the real cause when it was time to change the chain and sprockets
Old 31st October 2009, 19:29   #29 (permalink)
bj96's Avatar
I think 4s 350 has 16T, 5s has 18T and 500cc 4s has 17T, and these sprockets are swappable.
__________________
Old 1st November 2009, 01:04   #30 (permalink)
-BJ
So, there is a difference between 4s and 5s. the 5s does higher speeds at lower rpm compared to the 4s. Please confirm that I am reading this right.
By the same token, the 5s would cruise slightly more relaxed than the 500 CI by about 5%. The 500CI would be doing 100 kph at 4000 rpm while the 5s would be doing the same speed at 3800 rpm.
The calculator comes up with a top speed of 124 kph at 5000 rpm for the 500 CI and a top speed of 131 kph at 5000 rpm for the 5s. Are these numbers plausible?
Thread Tools
Std 350? Hmmm Electra 5s? Or Mach 350? vinit.merchant Motorbikes 38 10th August 2009 14:57
Bullet 350/Electra 4S/ Electra 5S neoisme Motorbikes 23 16th June 2009 18:24
Taking a Brand new 'classic' - RE Bullet 350 Std sam_sant2005 Motorbikes 65 15th May 2009 22:07
Oil change for 93 std CI bullet howler Motorbikes 4 13th April 2009 11:42
Bullet Std 350- stuck gear topedgemonk Motorbikes 2 17th January 2009 22:53
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
