Old 12th February 2009, 12:47   #1
nayyar.rao's Avatar
Default How To: Clean your motorcycle helmet
Guys,
Is there a place where i can get my helmet cleaned? I tried doing it with a vaccm cleaner from the inside but i guess it is not good enough. It has 1 year worth of riding memorabilia in it.
I surveyed some shops on JC road but i did not find their methods appealing. Please suggest me of a shop where i can go and get it done.
nayyar.rao is offline   Reply With Quote
Old 12th February 2009, 13:46   #2
WasavaTyres's Avatar
Thanked: 239 Times
Why don't you try cleaning it with those upholstery cleaning cans that are used for car seats ?? The only thing being you'll feel you're in an orange farm when you have your helmet on
WasavaTyres is online now   Reply With Quote
Old 12th February 2009, 13:55   #3
esteem_lover's Avatar
Thanked: 445 Times
use mild soap solution and brush the insides, rinse with clean water & let it dry, should do.
Old 12th February 2009, 14:01   #4
bblost's Avatar
Thanked: 6,663 Times
+1
also
Bell Helmets - Helmet 101
HOW DO I CARE FOR/CLEAN MY HELMET?
Cleaning Helmets
Helmets are made of materials that can be damaged by many common cleaners. Petroleum-based solvents or cleaners are especially dangerous. For best results, clean the helmet using a soft cloth or sponge, warm water and mild dish soap. Salt build-up on straps is best removed using a sponge and water.
and next time buy a helmet with removable inner liners.
Old 12th February 2009, 19:02   #5
Raccoon's Avatar
Thanked: 105 Times
I wouldn't use something like that with unknown ingredients... and something that you cant rinse out!
I'd suggest a good hair shampoo...
Old 12th February 2009, 19:42   #6
Thanked: 3,508 Times
Is the helmet liner removable? If it is then it's very easy. Take it out wash it with washing powder rinse it and let it dry.
If the helmet liner is not removable it's a bit difficult. First find a big bucket or basin large enough to swallow the whole helmet (remove the visor). Then soak the helmet in there, using least quantity of very mild detergent, for couple of hours. Then rinse it, as much as it takes to remove the traces of detergent. Hang dry it and then later sun dry it.
I've tried the latter for an AGV (import) with non removable liners without any harm.
Old 12th February 2009, 20:36   #7
Thanked: 9 Times
Done this a number of times when I use to ride.
WanderNomad is offline   Reply With Quote
Old 13th February 2009, 00:33   #8
Outside its quite easy to clean using something such as a mincream , however inside foam and cover which is the one which takes maximum punishment of sweat , dust and pollution is a pain!
vikrut is offline   Reply With Quote
Old 14th July 2009, 11:47   #9
Gordon's Avatar
Thanked: 162 Times
Motorcycle helmets get dirty and smelly over use, specially during the rains. Over time, it is almost detestable to wear one. Like all products that one wears, the motorcycle helmet is also supposed to be kept clean and hygienic.
Trouble is that how do you clean the insides of your motorcycle helmet?! Found some useful links on Google and turned up with this one: How To: Clean your motorcycle helmet
Do you have any alternate methods that you have tried?! A pictorial would be great.
Gordon is offline   (1) Thanks Reply With Quote
Old 14th July 2009, 12:02   #10
bblost's Avatar
I clean the exterior of my GPR with colin every second day.
Wipe it with a micro fiber cloth.
My helmet is about 18 months old and still looks like new.
I have a spare open face that I use when I go for short jaunts.
Also use the open face on Fridays when I need to place it in the open as I go for Namaz.
Neither of my helmets are left on the bike.
For the interiors. Both the helmets have removable lining.
I wash them with a mild detergent if needed.
I have taken to wearing a keffiyeh covering my head and ears inside the helmet.
Old 14th July 2009, 12:05   #11
sammyboy's Avatar
Thanked: 338 Times
Perfect timing Gordon Just bought a helmet yesterday and am getting a bike today.
Should be pretty helpful.
sammyboy is online now   Reply With Quote
Old 14th July 2009, 13:00   #12
Gordon's Avatar
Thanked: 162 Times
Thats one of the key reasons why helmets get very dirty, wet and smelly. My own helmets are clean; both inside and outside. A friend of mine generally leaves his helmet on the bike. The complete inner padding used to get wet AND dusty. Its impossible to wear it now.
We'll follow the instructions on that site, and if possible take a small pictorial too.
Gordon is offline   Reply With Quote
Old 14th July 2009, 13:26   #13
kannan666's Avatar
Thanked: 69 Times
Nice info Gordon ! My helmet is actually quite old but I manage to maintain it and keep it quite clean, both inside and outside ! And yes, it is single use, I never lend it to anybody, guess that helps too !
kannan666 is offline   Reply With Quote
Old 14th July 2009, 13:30   #14
bblost's Avatar
Replace your helmet every 3 years.
It looses its efficiency due to heat/moisture/pollution etc.
If your helmet has a bad fall, say down a flight of stairs then replace it.
If you bounced your head on a raod while wearing it, replace it.
Old 14th July 2009, 13:52   #15
akshay4587's Avatar
Thanked: 1,554 Times
Removable linings are good,i wash the one's on my AGV often and while i dip them in water i add a few drops of Dettol.
To clean visor i use Colin
akshay4587 is online now   Reply With Quote
Which Helmet? Tips on buying a good helmet Su-47 Motorbikes 2509 13th December 2017 14:27
For All Car Lovers - Keeping Your Car Clean Rudra Sen Technical Stuff 561 31st March 2016 16:03
Bike starts up only when you wear your helmet (TheGoodRoad) Rehaan Motorbikes 6 12th April 2014 11:05
DO NOT clean motorcycle chain with bike running in 1st gear and on the main stand! iron.head Motorbikes 82 27th June 2012 23:43
