Old 22nd July 2009, 17:57   #1
Default Jumpstarting a bike?
heres a question i need some advice on guys...
i have a Enfield Bullet with a dead battery, and a maruti alto. is it possible to jumpstart the Bullet with jump leads using the car battery without damaging the bike electricals?
option 2: can i jump start the bike with a friends bike ?
If any anyone has done this before please advice.
thanks.
nakedflame is offline   Reply With Quote
Old 22nd July 2009, 18:16   #2
amitoj's Avatar
Thanked: 1,691 Times
Given a friend reasonbly strong enough, is it not possible to push start a bullet?
amitoj is offline   Reply With Quote
Old 22nd July 2009, 18:18   #3
clevermax's Avatar
Thanked: 445 Times
As long as the bullet has a 12V battery (I'm not sure) , it should be fine to use your car battery to jump start.
Isn't that called bump starting?
clevermax is offline   Reply With Quote
Old 22nd July 2009, 18:33   #4
amitoj's Avatar
hehe. no idea. "push start" just happens to well describe the actions involved. I dont know BulletSpeak for it
Old 22nd July 2009, 19:11   #5
yzfrj's Avatar
Thanked: 119 Times
Is battery required to get a Bullet started up ?
My RX and Old Splendor I had used to run fine without battery.
Does the bullet have electric start ?
Car battery is 12V, but which is having a higher amp.
In theory it should't be a problem, but I'd not try it.
Push start is not an option ?
Again, in that case too with dead battery it will not work ?
I'm not sure if a "live" battery is required for a Bullet to start.
A carb car will start without a battery, only exception if the car has a electronic fuel pump. In that case the car will start with a battery in place (even if there is not enough juice in the battery for a self-start) and will not start without a batter or a battery with 0 charge.
yzfrj is offline   Reply With Quote
Old 22nd July 2009, 19:14   #6
pradipk's Avatar
Thanked: 21 Times
I own Thunderbird (no self start) which works fine even without battery or with dead battery. But I guess Bullet doesn't start without that. ( this one was one of the major reason not to go for Bullet).
Anyways now I found Bullet can also be started without battery or with dead battery. Refer following link there it's explained in detail.
The Bullet: Mystries & Myths - Improve Your Bullet
I hope this will help.
pradipk is offline   Reply With Quote
Old 22nd July 2009, 20:16   #7
Thanked: 175 Times
For the bullet standard you have to have a charged battery for starting it cause the spark is generated by the battery,
for a electra you have to have the battery intact it does not matter if it is charged or not its just that it has to be completing the circuit.
No you cannot push start the Standar cause it would still need the battery to be charged, though in some times yes it does start but thats a rare one.
yes you certainly can use the Car battery to Jump start the bike but make sure that you donot shot the who thing connect it the connectors correctly and then start it, after the bike starts take off the jump cables after 5 minutes and take the bike for a ride of around 7-10 Km it will charge the battery enough for the time being, as a pricaution and a good measure take off the tail light bulb so that there is no battery being used for any other things apart from the ignition.
DONT . PLEASE DONT use the horn.
teh link there does not apply to the new bullets they do not have the same mechanism of the electricals.
Note from the Team-BHP Support Team : Please use the "edit" button if posting within 20 minutes of the first post, instead of creating another back-to-back post.
Last edited by Technocrat : 22nd July 2009 at 20:19. Reason: Please read the note in post, thanks
desideep is offline   Reply With Quote
Old 22nd July 2009, 22:38   #8
Rehaan's Avatar
Thanked: 25,037 Times
Nakedflame,
As others have said - the simplest option by far is to push start the bike! Any reason for you not wanting to try that?
cya
R
Old 22nd July 2009, 22:58   #9
Nitin's Avatar
I've done this on my bike. Although its a 650cc bike, it uses a regular battery.
The day i got my bike, the battery went dead. I called the previous owner and he came by to jump start the bike. Exact same process, and it worked!
I would think its safe to jump start your bike. If the battery is completely dead, then you'd have to get a new one anyway. It won't affect the electricals, IMO.
Nitin is offline   Reply With Quote
Old 22nd July 2009, 23:19   #10
Shashank.A's Avatar
My cousin has a Thunderbird (September 2006), and he barely uses it. So I have to take it for a ride sometimes to make sure that it remains working, but still its quite often that his battery goes dead, so I connect it to my pulsar and start it. Simply use two wires and connect with battery of any other bike or car. (Make sure you connect the correct terminals).
Instead of going for a ride and risking getting stuck, just let the bike idle and increase the RPMs a bit. In 10 minutes you would be fine.
Shashank.A is offline   Reply With Quote
Singapore shops for Bikes & Bike accessories FrazerRazor Motorbikes 28 2nd March 2018 08:58
Good shop for bike on rent and 2nd hand bike in mumbai moto.medi Motorbikes 9 16th September 2013 00:51
Jumpstarting from a USB device? di1in Technical Stuff 7 7th April 2010 13:04
Rode my Dream bike: The LWR bike, BMW R1150GS BunnyPunia Superbikes & Imports 11 28th September 2007 09:37
Which bike? Need to change discover with lighter bike pingme Motorbikes 9 8th September 2006 17:39
