Old 23rd July 2009, 19:35   #1
trammway's Avatar
Thanked: 220 Times
Default Are RD350 LC and RD350 AC pistons are same ?
I have got this set of Original NOS Yamaha ART piston kits shipped from overseas with the part number reading 4L0-11631-00.
I'm now confused as the part number search from google resulted that this Piston is a LC piston. Anyone got an idea if the same piston could be used in Air Cooled RD350 ?
trammway is offline   Reply With Quote
Old 22nd August 2009, 04:33   #2
alok_balsekar's Avatar
Thanked: 34 Times
Originally Posted by trammway View Post
Attachment 163447
LC Pistons are Taller than the Aircooled Ones .....
The Transfer port holes in the Piston are of a different shape too ...
alok_balsekar is offline   Reply With Quote
Old 22nd August 2009, 22:30   #3
yamdoot's Avatar
Thanked: 12 Times
both are the same.. LC pistons have larger ports which dont pose a problen for aircooled RD.. height is the same.. theres only a small tang at the skirt which has to be removed for use in aircooled RDs..
yamdoot is offline   Reply With Quote
Old 23rd August 2009, 07:34   #4
Thanked: 34 Times
When I got the Orig ARTs removed and was going to put in the "RD350 LC" stamped TKRs I saw the difference ... Got the RD350 ones for TKR ...same height as the ARTs ...
Old 23rd August 2009, 14:41   #5
SunnyBoi's Avatar
Thanked: 2,832 Times
Pro-X Piston Modification
SunnyBoi is offline   Reply With Quote
Old 23rd August 2009, 15:44   #6
yamdoot's Avatar
Thanked: 12 Times
its possible u got fake pistons.. hence the difference..
Old 2nd September 2009, 20:27   #7
DeepakMenon's Avatar
Thanked: 145 Times
No Difference between a LC and a aircooled piston; the difference in the skirt is of a RZ piston
RZ pistons start with either : 31K; 29L; 2GU
4LO are LC (Non YPVS); most of the TKR pistons that you get in India are 4LO variety
I doubt your pistons are fake from what i see in the pic.. you have a good chance if you picked it up from ebay
DeepakMenon is offline   Reply With Quote
What if all tyre are of same specs, but not from same make? sups Modifications & Accessories 9 24th December 2010 16:34
Would you buy the "same car" with "Same Color" as your immediate neighbour? cool.aquarian The Indian Car Scene 39 12th November 2010 13:57
Same Profile, Same Make. But still difference in diameter. Possible? vrooooooom Tyre & Alloy wheel Section 34 13th August 2008 21:07
WANTED : Isuzu 1.8 Pistons...20 oversize GTO Shifting gears 7 21st February 2006 20:40
PLs Help Need Forged Pistons - Esteem Tom Shifting gears 2 5th February 2005 12:07
