Go Back   Team-BHP > Around the Corner > Motorbikes
Motorbikes Everything related to the two-wheeled breed.
LinkBack Thread Tools
Old 27th August 2009, 14:00   #1 (permalink)
RVD
RVD's Avatar
Question Starting Problem on a Bullet Machismo
Hi all, I have a 2005 Bullet Machismo which has done about 11k on the Odo. I have never had any problems with the bike until recently when the bike started giving me starting problem. I initially got the plug changed and got the air filter and the carb cleaned. The problem still persisted. I then changed the Battery as well ( Even though my bike is CDI ignition and a faulty battery should have nothing to do with the starting process). The problem still persists. What used to happen is that the bike would start without any problems and the moment I would turn the head light on, the bike would get switched off. Now the problem has worsened and the bike is giving troubles just starting. As suggested by a fellow T-BHPian, I got the rectifier checked but according to my mechanic, it seems ok. Now, I am back to square one and do not know what else could be the problem. Any kind of help regarding the matter would be greatly appreciated.
I recently cleaned the carb and might have messed up the mixture setting and that could explain the starting issue but that still does not explain the vehicle going off after turning on the head light.
RVD is offline   Reply With Quote
Old 27th August 2009, 15:28   #2 (permalink)
?ushk@r's Avatar
I think the coil near the clutch are causing this problem, there might be some earthing going on which is why the bike isn't starting.. I would suggest you go to the mechanic and ask him to check/replace the coil.
__________________
?ushk@r
1991 HM Contessa 1.8GL
2005 Royal Enfield Machismo 350
2003 Bajaj Pulsar 150
1999 Bajaj Super
~ Thruly !ND!AN ~
?ushk@r is offline   Reply With Quote
Old 27th August 2009, 18:40   #3 (permalink)
RVD
RVD's Avatar
@ ?ushk@r Pardon my ignorance but what coil is it ? I am not sure of the exact placement but is it the alternator that you are referring to?? Also, the bike does start but gets switched off only when the headlight is switched on. No problems with any other electrical item like the horn, indicator etc.
Rahul
Old 27th August 2009, 20:10   #4 (permalink)
sriku's Avatar
I once had a similar problem with my Std 350. What I did was to disconnect the headlight, the brake light, the horn, the indicators and then took apart the wiring inside the headlight cowl. I put it back together and taped any loose ends. Then took the coil and rectifier out from the seat, cleaned any dust and made sure no exposed wiring was shorting with the metal part under the seat. Then connected the coil, rectifier and opened the clutch box to check the wire that feeds the winded coils around the magnet. Apparently my main drive shaft had play in it which made the magnet touch the winded coils around it, shorting it now and then. Nevertheless, with a slight adjustment, and iterative reconnection of electricals I was able to solve the starting problem. I did replace both the primary and standby fuses as well, as I did not trust them. If possible, please get a rectifier from a working bike and connect it to yours to diagnose. The coil/rectifier/headlight wiring are always suspect in Bulls. Suggest you focus on them.
Cheers,
__________________
4 strokes move my body, 2 strokes move my soul!
sriku is online now   Reply With Quote
Old 27th August 2009, 21:07   #5 (permalink)
RVD
RVD's Avatar
@Sriku : Wow!! Thanks a lot. At least now I have something to work on.Frankly, even my mechanic was failing to get an answer. Hope this sorts out the issue. What I fail to understand though, is the coil that you mentioned as being under the seat. I have never removed the seat and checked but what can be seen from a peek under the seat is the rectifier. Am I missing something in regards to the coil ?
Rahul
Old 27th August 2009, 21:39   #6 (permalink)
sriku's Avatar
Rahul
No need to thank me, this is just what I went through once. I'm no specialist, and may not use the right technical terms, but I know that the coil(shaped like a cylindrical aluminum canister) under the seat near the rectifier will short if water hits it, as this happened to me in the rains, and I ended up changing the coil, in fact upgraded it to 12V and replaced the wiring harness as well as the battery. There is no quick fix for Bull electricals, the coil though, is vital to the bike's starting and running. The rectifier is solid and usually will not die on you, the coil isn't that way. If I were in your position, I'd take the rectifier, coil, battery, fuses from my other bullet and try them one after the other on the affected bull. Amateurs like us can only try this kind of debugging. Since your bullet is relatively new, I am assuming the wiring is in good shape, the bulbs and grounding are fine (check for a ground wire near the tail light assembly, it will be connected to a nut on your mudguard or frame, I forget which, to provide electrical grounding. Scrape any crud on the metal area where the grounding wire connects to the frame/mudguard, the lack of grounding could also be causing some trouble. Sorry for the rushed/incoherent reply, but I'm checking the forum between conference calls, and have only come out to order some pizza!
Cheers and a "Get well soon" for your Bull,
__________________
Old 28th August 2009, 00:18   #7 (permalink)
RVD
RVD's Avatar
@Sriku : Thanks again. I have left my bike at the mechanic. Will go in the morning and ask him to check the things that you mentioned. Now the only trouble is to find a donor bike. The trouble is that my mechanic is not a bullet mechanic and mine is the only bullet that he does, so finding another bike will be a task.
Old 28th August 2009, 10:26   #8 (permalink)
sriku's Avatar
with all due respect to your mechanics ability, please bring the Bull back home. Find a qualified Bullet mechanic or contact the ASC. I don't understand why when you have a new-ish bike, you'd want to take it to anybody other than a qualified Bullet mechanic. I suggest you reply with your location, and we will help you find a qualified guy nearest.
Cheers,
__________________
Old 28th August 2009, 10:35   #9 (permalink)
Same problem on my 500, the fuse blew every time I turned the headlight on. Mulled over that, fiddled with the bike, and discovered that it blew with the light on when I turned the handlebars - bike on the stand doing this of course.
That was a eureka moment - opened the cowl the first time, and was aghast to see the birds nest of wiring! Discovered a worn out insulation that was shorting. Taped it up, and the bike was fine thereafter. But, having seen the installation quality, and the thin cables used to cut costs, I am not surprised that the first thing many US/UK riders do is to rewire the entire bike before use. Great way to learn, and fixes one of the main weaknesses of the bike, the electricals.
Before you let the mechanic let his imagination run riot, I suggest you do this, because your symptoms sound similar. If you don't find the problem in the cowl, just trace the headlight wiring all the way down to where it is shorting.
One good news - the fuses do their jobs!!
Of course, in my bike it never started till the fuse was replaced, so your problem is a variation, but probably on the same theme.
__________________
If anything is worth doing, it is worth doing well
Sawyer is offline   Reply With Quote
Old 28th August 2009, 10:43   #10 (permalink)
ram.west's Avatar
Post
hey rvd: +1 to what sriku had to say. Please go to a qualified Bullet Mechanic. Others simply will not understand this piece of Machinery. And check your coil and CDI also as sriku had earlier said.
__________________
" When we remember we are all mad, the mysteries disappear and life stands explained "
ram.west is online now   Reply With Quote
Old 28th August 2009, 13:31   #11 (permalink)
RVD
RVD's Avatar
@Sriku, Ram.west: I completely agree with you guys and can see where you are coming from. The trouble is that I have give my bike to authorized service center's like Agro, and the one near TV tower (JC nagar) before but have never been happy with the work. The problem with most mechanics is that they work out of memory i.e for "X" problem, "Y" is the solution. Years of experience have taught them to understand most of the problems that might arise from the bike. The key word here is "most" as I had shown my bike to the workshop at JC nagar and he changed the rubber connecting the air filter to the carb. Agreed, that the rubber had cracks but that was obviously not the reason for the problem.
I have been going to my mechanic from the last 10 years albeit for my Yamaha but I have always felt that he looks at isolating the problem rather than just jump at a conclusion. Anyways, this will be a test from him. If he fails to get the problem fixed my hunt for a new mechanic will begin all over again.
@ Sawer : Thanks a lot. I actually called my mechanic now and told him the things to check that you and Sriku had mentioned. Will go and check the progress in the evening.
OT : Has anyone heard of this guy called gurunandan ? He is a bullet mechanic and I have heard some great review's about him.
Rahul
Old 28th August 2009, 18:49   #12 (permalink)
MumBiker's Avatar
B.R.Gurunandan is one of the best that you can get.
His website : Nandanmotors: Homepage & Nandanmotors: Serial Index
He also sells Pete Snidal's Bullet Manual - http://webhome.idirect.com/~snidey/inddist.htm
__________________
Rover, Wanderer, Nomad, Vagabond... Call me what you will.
MumBiker is offline   Reply With Quote
Old 28th August 2009, 19:02   #13 (permalink)
sriku's Avatar
I have also heard rave reviews about the Guru. Also, read somewhere about a Bullet workshop, an actual training school to educate Bullet owners and help them fix their own bikes, and understand the intricacies.
Cheers,
__________________
Old 28th August 2009, 23:13   #14 (permalink)
RVD
RVD's Avatar
My mechanic called me in the evening and said that he could not diagnose the problem . Anyways, after I posted about Mr Gurunandan, I went to meet him personally. His workshop is less than half a kilometer from my house. He said that the next batch of the bullet workshop will probably start from next month. He seems a very knowledgeable person and I am definitely joining his workshop.
Meanwhile I asked him what the problem might be with the bike and he said that it could be one 50 things that he could think of . Will probably leave the bike at his place tomorrow and hope for the best.
Old 28th August 2009, 23:47   #15 (permalink)
... Mr Gurunandan, I went to meet him personally. His workshop is less than half a kilometer from my house.
Sounds like you stay near Hebbal. In that case, get your bike checked up by Gurunandan.
We have a few good bullet mechanics in Marathahalli, K'mangla and one near Swagat theatre in Jayanagar.
PM me if you need any details.
Rajat
rajatmakar is offline   Reply With Quote
Thread Tools
Where to get low/ace-cafe handlebars for Bullet + my modded Machismo pics v12 Modifications & Accessories 17 15th March 2010 14:19
Need Help (deciding Second Hand) RE Bullet Machismo 350 or Electra 5S bharath_rbk Motorbikes 54 12th October 2009 16:42
Bullet Machismo - 350lb or 500 lb ? v&v Motorbikes 19 12th October 2007 23:00
Bullet machismo for Sale (Delhi) panky12345 Shifting gears 0 3rd February 2007 15:58
For Sale:Royal Enfield Bullet Machismo binz Shifting gears 0 24th September 2006 12:54
Powered by vBulletin
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright ©2000 - 2010, Team-BHP.com
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652
