Old 11th September 2009, 16:08   #16
topedgemonk's Avatar
Thanked: 7 Times
Why not a sandblasting followed by zinc metalizing spray/coat? Solve your rust problem for ever. Some good places to get it done in Kolkata. True, the surface paint will need to be re-done, but this is a permanent solution.
I had rust in my bullet's tank. The above mentioned process was done. I dont find any rust inside now.
topedgemonk is offline   Reply With Quote
Old 11th September 2009, 16:09   #17
Ajaybiz's Avatar
Thanked: 141 Times
Best is remove the rust from tank completly apply very thin layer of engine oil and get a nickle coat by any chrome guys works preety good.SS-Traveller said the same thing.
Ajaybiz is offline   Reply With Quote
Old 11th September 2009, 19:46   #18
SS-Traveller's Avatar
Thanked: 11,626 Times
Originally Posted by H3LIOS View Post
I too am facing rust problems with my Yezdi Roadking tank.
The Yezdi needs a petroil mix, and generally these tanks don't have a rust issue - I'm a little surprised you have such a problem.
...get the inside powder coated. As has already been said, the exterior paint is ruined when they put he tank inside the oven to cure.
The zinc metalizing process does not need to have a curing cycle in an oven. It's like a flame-thrower which blasts out superheated molten zinc onto a freshly sandblasted metal surface, and the zinc bonds on as it cools. The resultant surface is slightly granular in texture, but eternally rust-proof.
Edit: Check this link: Zinc metallizing is one of the processes we specialize in
Old 11th September 2009, 19:52   #19
simply_sunny001's Avatar
Thanked: 15 Times
BTW,How much a new Petrol Tank costs for bullet ?
simply_sunny001 is offline   Reply With Quote
Old 13th September 2009, 16:43   #20
H3LIOS's Avatar
Thanked: 17 Times
The bike was in dis-use for a couple of years and was not stored properly resulting in the rust issue (Visakhapatnam is on the coast and rust sets in quite easily if proper care is not taken). I got it out, did a little restoration and started using only since the past two months.
Thanks for the info on the zin metalizing process. I was not aware of that.
- Teja
H3LIOS is offline   Reply With Quote
Old 13th September 2009, 18:47   #21
james's Avatar
Thanked: 544 Times
Price depends on the model.. Std350 tank is around 4k without the emblems or knee pads. Just black tank with gold lines and clear coat.
james is offline   Reply With Quote
Old 30th November 2009, 14:21   #22
Rehaan's Avatar
Thanked: 25,038 Times
Cross linking to another related thread : http://www.team-bhp.com/forum/motorb...-proofing.html (Fuel-tank Rust Removal (by Electrolysis) & Rust Proofing)
cya
R
Old 29th March 2012, 11:02   #23
bblost's Avatar
Thanked: 6,976 Times
Default Re: Bullet Replacement Tank Woes
When my tank developed a tear near the side facing the seat. I took it to a welder.
Atif (Ranigunj, Hyderabad, 939109-9990) does stuff for bikes.
He cut open the tank. Added a new layer of metal to make it bigger.
Total capacity is around 18 liters now.
Then I got the tank painted by Hira (9290118319).
Hira's shed is close to Ranigunj area on the necklace road side.
Sudipto: You might try and find such a welder in your city.
I am very happy with my new tank.
Old 29th March 2012, 12:37   #24
Gansan's Avatar
Thanked: 914 Times
Default Re: Rust inside Bullet tank. What are my options?
A lot of people used to add a little 2T oil in the petrol to mitigate this. Another option was to add a magnetic fuel filter.
Old 29th March 2012, 14:34   #25
Slick's Avatar
Thanked: 103 Times
@sudipto,
I had the same issue in my Rx100, I got an epoxy coating done from the inside.
The bike is fine now, earlier I faced the same issue of engine starving because of rust clogging the carb.
The same has been mentioned in the thread earlier. In case of a tank tear, like bblost said get it welded.
-Harshad
Slick is offline   Reply With Quote
Old 29th March 2012, 21:54   #26
Leepower's Avatar
Thanked: 70 Times
How much does this magnetic filter cost? Where can I find one? I need one for my 74 yezdi type b...
Leepower is offline   Reply With Quote
Old 30th March 2012, 11:14   #27
Gansan's Avatar
Thanked: 914 Times
^^ May be around Rs 100 - 150. Has to be connected in the fuel line. It can remove rust, but the magnet has to be removed and cleaned from time to time. There will be a provision for that. Looks wise, not aesthetic.
Old 10th December 2013, 10:31   #28
4x4army's Avatar
Thanked: 59 Times
I am looking for this product, any idea where i can get similar product in India.
Thanks in advance.
Apply an Epoxy Sealer on a Leaking Gas Tank
Read more: http://www.motorcycleclassics.com/mc...#ixzz2n2ntqG2S
4x4army is offline   Reply With Quote
Fuel-tank Rust Removal (by Electrolysis) & Rust Proofing H3LIOS Motorbikes 30 19th May 2014 14:26
Rust in fuel tank of Accent CRDI badri Technical Stuff 2 26th January 2007 19:27
fuel tank 42lt.- fuel in-44lt. v.tec Technical Stuff 55 29th August 2006 20:50
