Old 27th September 2009, 03:42   #1
Thanked: 19 Times
Default Spongy Brakes on Honda Dio
The brakes on my Honda Dio feel spongy. I got them tightened and also the brake pads were changed, but the problem recurred soon after (i.e. within a few days). In brief, I am not happy with brakes.
Is there any way to improve the braking action of Dio?
Also, has any one tried something different than the routine brake cable tightening, brake pad cleaning and changes?
psp62in is offline   Reply With Quote
Old 27th September 2009, 07:34   #2
sudev's Avatar
Thanked: 2,639 Times
Did you get air bleeding done? Spongy is symptomatic of this. And air in barake circuit is dangerous. It should be done by competent mechanic and not in a hurry. The circuit should be bled several times to take out all air.
sudev is offline   Reply With Quote
Old 27th September 2009, 09:33   #3
vipul_singh's Avatar
Thanked: 256 Times
Faced the same problem with my KiHo Marvel (now stolen...sob!). Had to replace the brake drum + shoe as a set to get it fixed. Apparantly, the brake drum had developed a groove which was preventing full contact.
Edit: @sudev, I think the dio has a mechanical brake system, not hydraulic. psp62in can confirm this
vipul_singh is offline   Reply With Quote
Old 27th September 2009, 13:52   #4
Thanked: 19 Times
You are right Vipul, Dio has a mechanical brake system (so do the most other scooters and bikes AFAIK).
Old 27th September 2009, 17:38   #5
sudev's Avatar
@OP: My bad....early morning improper reading.
Old 27th September 2009, 22:01   #6
MA5K's Avatar
Facing similar problem on my friend's Dio as well. This was after getting both the front/rear brake pads replaced, not so long ago.
Subscribing to thread..
MA5K is offline   Reply With Quote
Old 27th September 2009, 22:08   #7
Thanked: 152 Times
The Dio has Brilliant Brakes normally. I suggest you just routinely tighten your brakes. At leas that is what I do
Cyrus43 is offline   Reply With Quote
Old 27th September 2009, 23:05   #8
aaggoswami's Avatar
Thanked: 1,541 Times
This is a normal thing.
1) Open the drum, take out the brake pads and see if there is life in them or not.
2) There will be some black powder on the surface of brake pad and drum, clean it.
3) After monsoon, water must have entered into drum and this is problem with scooters. Their wheels are small so even in very little water, chances are that water enters the drum. Clean surface of brake pad with sand paper. But do this only if the brake pads have life in them.
4) If still the braking performance does not improve, replace the pads, but do clean the drum.
5) The life of drum is more than 70K kms. Yes, I know it very much depends upon usage, but in general the drum will not get so much ineffective very soon.
I have worked upon my Bajaj spirit, friend's and cousins Activa and Dio respectively. I still change brake pads for my sister's Kristal.
aaggoswami is offline   Reply With Quote
Old 30th September 2009, 11:07   #9
Thanked: 19 Times
Hi aaggoswami,
What is the normal life of the brake pads? Because in last 6 months I have changed them twice already and still no big improvement. And got the cleaning done almost every month. This looks kind of too frequent (and not normal) for me for ~1500km done in 6 months.
Could this be something else, e.g. spares quality issue or any thing other?
I am still struggling!!
Honda Dio - Test Ride islero Motorbikes 16 6th March 2018 12:50
Honda Activa vs Honda Dio vs TVS Wego vs Hero Maestro vs Suzuki Access 125 90BHP Motorbikes 172 12th October 2016 10:40
Retarder in Volvo B7R buses (air-brakes / jake brakes) sfilinto Commercial Vehicles 12 30th March 2010 00:55
WTS Honda Dio scooter - how to evaluate price ? nsinha Motorbikes 6 27th April 2007 14:08
what do u think about the HONDA DIO? karthik247 Sedans 5 3rd April 2005 11:41
