Old 2nd November 2009, 18:12   #1
Thanked: 127 Times
Default Add a 6th gear to a CBZ!
As the thread title suggests, is it possible to add a 6th gear to the CBZ (type 1)? Lot of times i shift in to the non existent 6th gear when on the highway..and always wished there was an extra gear on the bike . Has anyone here done this before? any thoughts anyone?
heavy_foot is offline   Reply With Quote
Old 3rd November 2009, 13:02   #2
ilangop's Avatar
Thanked: 591 Times
Hi Heavy foot,
Though I am no bike expert here is one small suggestion.
If you are a frequent highway driver you might replace the rear sprocket with a smaller one so that the wheel revs more. But for this you would need to compromise a bit on torque, or pick up in a bikers language. I guess adding a 6th gear would involve more of research and cost. Or even a larger dia tyre would take you to higher speeds.
-Ilango
ilangop is offline   Reply With Quote
Old 3rd November 2009, 14:21   #3
Rennjit's Avatar
Thanked: 84 Times
Well to say, Impossible is nothing but what are you looking out from such a mod?
Not many have tried as results are far outweighed by the effort, time, cost factors. Its no retrofit job as of now. Sprocketing is a better option to get close to your riding needs.
If you are really in for trying out, consider the possibility of replacing 5th gear set with a new tall ratio set - get something usable from others / rework any from others/ make a set.. its all up to how much you are willing to. Gap from 4th to 5th would increase but if you find new ratio well & good you can replace 4th to even out the gap. This might be a beginning. Do keep us posted.
Rennjit is offline   Reply With Quote
Old 3rd November 2009, 18:33   #4
Thanked: 103,777 Times
OT but related : This thread reminds me of a popular RX100 modification by "Mubarak Auto" at Tardeo (Bombay RX owners will recall). He used to add a 5th gear to the RX100, which quite honestly didn't really make a difference
Old 3rd November 2009, 22:57   #5
aaggoswami's Avatar
Thanked: 1,542 Times
1) Its not worth doing. I dont think that any reliable modifications are done to gearbox. Adding a gear is not an easy task and we dont know what are the effects on the engine. Best avoided unless you are able to get in touch with someone who modifies bikes for racing. He is the best man you can approach for such modification.
2) From what I have in your post, it looks like you are looking forward to cruising at more relaxed engine rpm. The other way it is possible is to modify the sprockets. However, it depends upon bike and manufacturer how they have done calculations and decided onto sprockets.
IIRC, a few years ago in OD ( OverDrive ) there was a very vast coverage on the effect of reducing reducing rear sprocket size on bikes like Pulsar, Kaz and CBZ. If I am not wrong, installing a smaller sprocket on rear of CBZ relatively gave less effect than adding a larger sprocket on the front.
OD did an extensive test where in they added a larger sprocket on the front, tested the bike and then added a smaller sprocket on the rear with stock front.
This was given as a small booklet in newstand copy of OD.
At the end of the day, I will say that rather than doing modifications in gearbox, its better to experiment a bit with sprockets. First drop two teeths in the rear and then see effect.
Last, dont go overboard on this as engine might be strained. Max, drop three teeths on the rear or at the very limit, 4. Beyond this, the engine will be strained.
aaggoswami is offline   Reply With Quote
Old 3rd November 2009, 23:38   #6
Thanked: 175 Times
Adding a 5 th gear to a RX does make a difference.
there are some Gear boxes that you may be able to use but let me check what all they are.
We are in procedure to fit a 6 gear in FZ16 just for the sake of it cause we have a gear box that would fit direct and also we are putting in a Kick on the FZ.
desideep is offline   Reply With Quote
Old 4th November 2009, 14:04   #7
lancer&shogun's Avatar
Originally Posted by ilangop View Post
If you are a frequent highway driver you might replace the rear sprocket with a smaller one so that the wheel revs more. -Ilango
+ 1 Try sprocketing it really works.
Or
How about procuring a 6speed gear box? But we need to find which gear box should fix properly without any major modification.
Just my 2 cents.
Cheers,
L&S
lancer&shogun is offline   Reply With Quote
6th Gear for a car ! Need, Criteria, Advantages & Disadvantages swiftnfurious Technical Stuff 64 20th May 2018 19:48
Triumph Bonneville - 6th gear requirement / sprocketing nitrogary Superbikes & Imports 5 23rd September 2015 04:54
Would you fancy a taller 6th gear on the KTM Duke 200? JayPrashanth Motorbikes 6 9th September 2013 21:39
Ahoy..onto the 6th gear now! ventoman Introduce yourself 3 3rd September 2010 11:44
Candy Orange Suzuki GS 100R -- 6th Gear -- jp2u Motorbikes 5 14th April 2010 14:22
