| LinkBack | Thread Tools | Search this Thread |
| | #1 |
| Newbie Join Date: Sep 2009 Location: Bangalore
| Hi guys, I own a stock 2002 Pulsar 180 (a.k.a. Classic or non-DTSi). It’s done just about 49000 km on the odo. Issues I have been facing with the bike are:
Is it possible that the gears/cogs some bearings are worn out? The gear problem could be solved by taking a look at the entire gear mechanism instead of just resetting the clutch. Every service person just says the clutch is worn out and in the last seven years, I have changed all the clutch plates 5-6 times. This has never caused an improvement in the gears. At service centres, they say that just checking the gears and other related parts would involve dismantling the entire engine and would cost a bomb, but even when I say that I don’t mind paying for it, they have never opened up to check the internals. Is it possible that the rubber engine mounts are flattened/hardened and so the ride is harsh since normal engine vibrations are being transmitted to the chassis? Once these two issues are sorted out, I intend getting the entire bike refurbished with new stock parts as headlight dome rim, indicators and a few other plastics have gone rusty/old/brittle. No modification on my mind for now! TC ![]() |
| | #2 | |
| BHPian Join Date: Dec 2008 Location: Bangalore
| Quote:
As for the ride, I totallly agree this bike is a pain to change to first from neutral always gives out a loud noise, but the trick to change the rest of the gears is to use your heel rather than your toes, and cutting gears at the right RPM also makes a lot of differerence, when you are braking/slowing down- make sure to rev and cut down. Take your chain gaurd off if you have one, this solves the chain problem to an extent. many may recommend against it but a regular cleaning is required if you do this. See- its a bajaj, but this model is a masterpiece, you will have to live with some problems. The harsh ride after service is because of the mechs in your service station not changing gears properly. | |
| | #3 | |
| BHPian | Quote:
| | #4 |
| Senior - BHPian Join Date: Dec 2005 Location: Ridin earth now
Thanked: 105 Times
| The solution is to change 3 springs behind the clutch assembly which control the gear change . Give a try since you have tried many things . This solution worked for me. Also inspect the shift rod ,while you are changing, for any groves or damage/wear and tear . Last edited by black12rr : 5th November 2009 at 19:33. |
| | #5 |
| BHPian | you mean is to replace them? |
| | #6 |
Thanked: 105 Times
| Yes replace the 3 springs . |
| | #7 |
| Newbie Join Date: Jul 2007 Location: Mumbai
| i owe a Classic 180 i dont recall wht my mechanic guy did with the gear box but its awesome smooth with out any noise and do change sometime gear without cluth too and still its butter smooth for me |
| | #8 |
| BHPian Join Date: Jan 2006 Location: delhi
| I have one as well, not used for the last year or so. I plan to redo the bike again soon. Will post some pics when i do. This was my first bike and I did many many long rides on the same. The bike was always there in my initial strugle in the big city and has been a faithful friend always. thats why I never sold it. Comming to the hard gears did you change the clutchplates ot the pressure plates as well ? You may need to change the pressure plates as they get thinner and distortes. |
| | #9 |
| Thanks guys for all your replies. @ samuraijack: This is a bike that I bought brand new and is my very first bike, which is why I'm reluctant to sell it off. I totally understand how you feel about the bike. @ dhananjay: I agree with you and samuraijack about changing gears at the right rpm (works best for me between 5000 - 6000) but the issue is mostly when riding in traffic where you can't really rev that high. @ black12rr: are you sure it's 3 springs and not 4? could you let me know the specific part that has these springs? The shift rod had been changed about a couple of years back even though it had not worn out, but there was still no improvement. @ sanjusahu: could you find out from your mechanic what he did and let me know? Also, where did you get it done? @bhogal: the clutch plates and pressure plates have been completely changed at least 5 times in the past 7-1/2 years at Bajaj service centres. I guess they did it as a trial and error method, but there has never been any improvement, and the gear feel has deteriorated. Have any of you guys also changed the rubber engine mounts on your Classic? My mounts seem to have become brittle and flattened or cracked, which could also be contributing to vibrations that I have been feeling over the last coupld of years. Is the engine mount kit still available? TC ![]() |
| | #10 |
| BHPian Join Date: Jun 2007 Location: delhi
Thanked: 48 Times
| hi torq on, do you still have the problems cuz i might be able to help |
| | #11 |
| BHPian Join Date: Oct 2009 Location: Jaipur
Thanked: 33 Times
| | #12 |
| | #13 |
| | #14 |
Thanked: 48 Times
| tell me what all have you done to rectify the problem till now. ill put up pics to guide you from there. Also tell me more about your riding style. how fast you go , how often , how much do you rev it. there are a couple of design flaws in the first pulsar which were corrected later. but then depending on your riding it could be wear as well so give me accurate information you have mentioned that the clutch and pressure plates have been changed. but has the clutch drum been changed? its the assembly that contains the friction plates and pressure plates the service personel are correct in mentioning that checking the gearbox means dismantling the engine to the very last bolt, which is unadvisable for this problem because in my opinion the problem is most likely to be in the clutch itself. unless your riding style is very harsh or you dont change oil on time then the gears and the shifting mechanisms are unlikely to be damaged. then again you have mentioned that you havedone 123 kmph with a pillion. that is definitely brutal treatment so you never know, but then lets see. do tell me how capable you are when it comes to mechanical work. Can you dismantle the clutch yourself? or will you have to depend on a mechanic. Cuz the service centre people will definitely object to the change i want to implement. Last edited by mycarhasablower : 2nd September 2011 at 22:32. |
| | #15 | |
| Thanks for offering to help. My replies are underlined and are beside your own questions/comments so the correlation is clearer. (Mods, please note.) Quote:
--Pls let me know if you need any further info.-- | |
Similar Threads | ||||
| Restoration: PULSAR 180 - Classic - 2002 model | mittal_v2002 | Motorbikes | 4 | 9th September 2011 16:04 |
| Gas Shocks In Classic Pulsar 180 | kphilip | Motorbikes | 11 | 22nd April 2011 12:34 |
| Pulsar 180 UG3and Apache 180-for a new bike? EDIT - Its the RTR 180 | deepclutch | Motorbikes | 76 | 25th November 2009 23:34 |
| Is it OK to ride my new Pulsar 180 for about 500 kms continuously?? | bikerrocks | Motorbikes | 35 | 9th November 2006 10:41 |
