Old 4th March 2012, 01:59   #31
xmOD's Avatar
Talking Modifying the Bajaj P220F. Help?
Ok so I got my P220 finally upgraded after 2 years of use in its stock form.
Right now this is the mod list:
-230cc Big Bore
-Full SS FFE
-Pipercross Air Filter
-NGK Iridium plugs+MSD Ignition Coil+MSD plug cables
Now after all this, I was thinking of replacing the stock carb with a bigger one.
Anyone know whats the stock carb on the P220F?
Can I install a Mikuni VM34 Round Slide/ TM34 Flat Slide carb on it? Anyone ever attempted this? I think it should be doable.
Next on the cards should be probably be a total head+port job but I'm not sure when.
Any ideas/suggestions/advice/help ?
xmOD is offline   Reply With Quote
Old 4th March 2012, 07:55   #32
condor's Avatar
Thanked: 4,345 Times
Default Re: P220F Upgrades!! Help!
@xmOD, would be nice to hear the differences after the improvement.
Instead of these modifications, have you considered upgrading to a bigger / better bike itself ? You now have a choice of Honda, Ninja, & even KTM. Or even the P200NS, amongst others
condor is offline   (1) Thanks Reply With Quote
Old 4th March 2012, 08:25   #33
aargee's Avatar
Thanked: 2,115 Times
Instead of these modifications, have you considered upgrading to a bigger / better bike itself?
+Million!!! Just like there's no replacement for displacement, there's no substitute for peace of mind. Plus not to mention the handling part that lies in the frame & other engineering that no amount of tuning can be done.
Old 4th March 2012, 12:28   #34
xmOD's Avatar
@Condor: Well you gotta believe me when I say the bike flies when you open the throttle. Its pretty fast yea! A video should be coming soon. I am very happy with the bike right now.
Well my 220F isn't that old right now and I don really fancy the CBR/Ninja/KTM in their 250cc/200cc versions. Plus with the upgrades I already have, my 220 can take on most of the bikes in the sub 250cc category and with a bigger carb am really sure it'll outrun its competitors.
I am doing up my 220F not any competition or anything, its just a hobby of mine, I did it with my dio and my cars as well. As a matter of fact, I would be doing about the same thing even if I did buy a bigger bike, maybe not immediately but surely after a year. Also, an upgrade from this 220F won't be another 250cc for me, more likely a 600.
Coming back to my original question, Anyone know anything about changing the carb on the 220F to a Mikuni VM34/TM34?
Old 5th March 2012, 02:47   #35
cruiser@0523's Avatar
Thanked: 38 Times
Default Re: Modifying the Bajaj P220F. Help?
You can contact Joel Joseph of race concepts, he will get you everything that is on your list. He recently did a flat side carb on a 230cc big bore 220f.
cruiser@0523 is offline   Reply With Quote
Old 5th March 2012, 18:01   #36
xmOD's Avatar
All the things mentioned in the list have already been done on the bike. Thanks for joel's reference though, I got my bigbore+FFE from him.
I just need help with the carb, whether or not VM34/TM34 would be an easy install on the P220F?
Old 5th March 2012, 19:40   #37
abhayshanu's Avatar
Thanked: 168 Times
The mikuni carbs are really costly but will be a fit, but will require some moddification to accelerator wire. Maybe a 2 stroke wire will do the job.
abhayshanu is offline   Reply With Quote
Old 5th March 2012, 21:57   #38
xmOD's Avatar
The semi flat slide that I believe joel provides, how much are they for? I think a friend of yours has one the semi flat slides in his P220? Whats the performance update?
Old 6th March 2012, 09:04   #39
abhayshanu's Avatar
Thanked: 168 Times
What Joel provides are not textbook roundslides(semi flatslide) more like race CV carbs. The performance bump is noticeable and enhances the complete package.
All these mods will result in more power but then will require more care. If you go ahead with such mods my personal suggestion is use the bike for racing and rarely for regular use. That is what I am doing with my P250 now.
Old 6th March 2012, 11:19   #40
rakesh_r's Avatar
Thanked: 695 Times
Am using the semiflat.Its a direct fit.I paid close to 7.5gs for it.I had to replace the stock jet as the bike used to splutter past 7500rpm.Upjatted to 125.Planning to go for the 130.
rakesh_r is online now   Reply With Quote
Old 6th March 2012, 12:48   #41
xmOD's Avatar
Default Re: New P220 DTSi Mods - Game ON!!!
Where'd you get the block/piston for that?
I had to replace the stock jet as the bike used to splutter past 7500rpm.Upjetted to 125.Planning to go for the 130.
Have you got a aftermarket filter on it as well? If the bike behaves right at 125 then I suggest you stick with it.
Old 6th March 2012, 13:17   #42
rakesh_r's Avatar
Thanked: 695 Times
i had to chuck out the stock airbox to a simota air filter.
Old 7th March 2012, 02:50   #43
xmOD's Avatar
Have you tried it with a pipercross in the filter box?
New P220 DTSi Ownership Review sam_sant2005 Motorbikes 76 4th July 2011 15:30
Moving to Court against Bajaj - Chain Sound in P220 DTSi sam_sant2005 Motorbikes 23 17th June 2010 11:57
Bajaj Auto's New Game - XCD Sprint 150/Pulsar 200Fi/New P220 five46 Motorbikes 11 9th November 2008 11:51
Pulsar 180cc DTSI Cosmetic Mods in Banagalore prince_pervez Technical Stuff 2 10th October 2007 21:28
P220, ZMA, Unicorn's Early Morning Ride to Lavasa(Lots of Pics) Technocrat Travelogues 6 21st March 2007 17:32
