Old 10th November 2009, 11:58   #1
Thanked: 29 Times
Post The RR700 Prostreet Turbo. The Ultimate Bullet mod job EDIT - Now Super Charged
Fellow TEAM-BHPians,
After over a year of effort, it gives me great pride to present before you the RR700 Prostreet Turbo. The bike is now almost ready, and I think is India's (if not the world's) first turbo charged single cylinder custom bike using the antiquated Royal Enfield powerplant. The bike is the result of more than a year of hard work by its creator and conceptualiser, Ranjit Randhawa a gentleman farmer based in Kharar near Punjab. Ranjit is in my mind, one of the finest automotive brains in the country and the RR700 Prostreet is his finest creation till date.
I have entered my motorcycle in the RE Rider Mania Custom bike competition and intend to ride it to Goa for the Rider Mania taking place this month. As opposed to mostly cosmetic / visual changes, this bike sports extensive modifications to the power plant as well as the visual appearance of the motorcycle. A true custom with both custom made internals and externals.
The bike handles like a dream and performance is DEADLY. We estimate BHP output to above 40bhp and an exponential increase in the tourque. I kid you not, the bike does wheel spins in second gear when the throttle is yanked. I guess I can give more objective data when the bike is tested by an auto mag.
I am attaching a few bike pictures. The mods made to the bike are too many. However, a brief list of the bike specs and mods is enclosed.
More details will follow.
Thanks for looking...
Ride hard, ride safe
MODS ON THE RR700
Frame, suspension and brakes
1. All new tailor made custom frame
2. Engine offset to accommodate large 200 cross section tyre
3. Custom made 17” 6 spoke front and rear alloy wheels
4. Tyre dimensions: Front: 120”, Rear: 200”
5. Mono-shock rising link rate rear suspension. Fully adjustable – load, preload, damping sourced from a CBR900RR
6. Fully adjustable front suspension sourced from a CBR 900RR.
7. Hand made fiber glass front and rear fenders with tire hugging profile
8. Custom made user friendly chain adjustment mechanism
9. Custom made 4 pot hydraulic rear sprocket brake.
10. Custom made housing and installation of rear brake master cylinder
11. 4 pot hydraulic front brakes and rotors sourced from an earlier model R1
12. Rubber bush mounted engine
13. Custom made handle bars tailor made to suit my riding stance. All wiring and cables hidden inside handle bars and frame.
14. Custom made, hand crafted twin body 20 litre capacity petrol tank
Engine
15. 535 cc stock Enfield engine souped up to 700 cc by lengthening the stroke and increasing the bore.
16. Custom modified crank shaft and connecting rod
17. Low friction, high compression piston sourced from Honda CRV SUV
18. Large CV carb sourced from a Honda 450 super 4
19. Engine compression ratio raised from a std 5.5 / 6:1 to 8.5 by reworking the head profile and tightening the squish zone
20. IHI RHB 31 turbo with custom made plumbing and fitment
21. Custom made heavy duty electrical starter motor housing and installation
22. Custom made twin spark digital ignition system to replace the stock points system
23. Stock 5 speed Royal Enfield gear box
24. Custom made gear shift mechanism. Gear shift on the left and braking system, on the right side.
25. Custom made free flow exhaust system
26. Custom made wiring harness to accommodate high voltage twin spark, powerful lights and loud horns
27. 12 V, 18 amph sealed Exide battery
Others
28. Custom made, billet aluminium Cyclops twin headlight
29. Custom made rear LED tail light
30. LED turn signals
31. Custom made digital speedometer with integrated trip meter recessed into the fuel tank
32. Custom made digital display for Neutral indicator, high beam, low beam, turn signal- recessed into the fuel tank
EDIT - Latest Updates Posted on This Post
The RR700 Prostreet Turbo. The Ultimate Bullet mod job EDIT - Now Super Charged-img_0843.jpg
The RR700 Prostreet Turbo. The Ultimate Bullet mod job EDIT - Now Super Charged-img_0853_revised.jpg
The RR700 Prostreet Turbo. The Ultimate Bullet mod job EDIT - Now Super Charged-img_0859.jpg
The RR700 Prostreet Turbo. The Ultimate Bullet mod job EDIT - Now Super Charged-img_0873.jpg
The RR700 Prostreet Turbo. The Ultimate Bullet mod job EDIT - Now Super Charged-img_0892.jpg
The RR700 Prostreet Turbo. The Ultimate Bullet mod job EDIT - Now Super Charged-p101051.jpg
The RR700 Prostreet Turbo. The Ultimate Bullet mod job EDIT - Now Super Charged-p1010542.jpg
Last edited by Technocrat : 1st February 2012 at 05:14. Reason: Threads merged, Latest updates post link added to this post, thanks
ForcedInduction is offline   (1) Thanks Reply With Quote
Old 10th November 2009, 19:17   #2
Thanked: 24 Times
That's one hell of a bike you got there, I like the mods done, and the over look is fasntastic. Overall, very good, I would love to have one of these.
musicmanaman is offline   Reply With Quote
Old 10th November 2009, 19:26   #3
mantrig's Avatar
Thanked: 175 Times
Great efforts have gone in there.
All the best for the RE Rider Mania 2009. I'm sure your hardwork will payback.
Also, it would be great if we can have a picture of the fuel tank from above to understand how the speedo and other functionalities have been integrated with the tank.
Once again, great job and happy thumping.
mantrig is offline   Reply With Quote
Old 10th November 2009, 19:33   #4
Sankar's Avatar
Thanked: 4,637 Times
Super Nice! Great work!
Congrats man Yours must be the first turbocharged two wheeler in the country! Put up a video if possible, i really wanna see your baby fly!
Is it built by Antony?
Edit: How much boost is it running?
Old 10th November 2009, 19:36   #5
Ajaybiz's Avatar
Thanked: 141 Times
Very neat and class modification, eagerly waiting for performance details if you don't mind sharing it.
Ajaybiz is offline   Reply With Quote
Old 10th November 2009, 19:41   #6
Thanked: 1,057 Times
Wow! Amazing work and it shows how much of hard work has gone into it.. All the best for the RE Rider Mania mate!!
abhinav.s is offline   Reply With Quote
Old 10th November 2009, 19:45   #7
Gilead's Avatar
Thanked: 21 Times
Fantastic job! I think the bike would have looked even meaner and deadlier in matte black.
Gilead is offline   Reply With Quote
Old 10th November 2009, 19:55   #8
greenhorn's Avatar
Thanked: 1,516 Times
I think a bunch of mallu college kids beat him to it
http://www.team-bhp.com/forum/motorb...-turbo-ed.html
greenhorn is offline   (1) Thanks Reply With Quote
Old 10th November 2009, 20:01   #9
Sankar's Avatar
No wonder i missed that thread, you posted it on May 24th. I was in for major repair
Old 10th November 2009, 20:02   #10
Thanked: 56 Times
Thats a lovely mod job.
If you can make another one of this kind in black, Batman would be interested in buying.
ashokrajagopal is offline   Reply With Quote
Old 10th November 2009, 20:03   #11
Thanked: 24 Times
Looking at the bike again, I wonder, are there any rear breaks on the bike, looks like there are none, can see on front disks.
Old 10th November 2009, 20:06   #12
Rennjit's Avatar
Thanked: 83 Times
Great attempt, Turbo .
can we have some more photos- Close ups, internals etc.
@ Sankar bhai, happy? i remember a post of yours longing to see a turbo Enfield.
Rennjit is offline   Reply With Quote
Old 10th November 2009, 20:08   #13
Sankar's Avatar
Haha.. i knew someone would miss the rear brake on this one! The rear brake disk is the rear sprocket. Caliper grabs the sprocket. Sprotor concept.
Would be more happy if he posts a video
Old 10th November 2009, 20:17   #14
vaisakhr's Avatar
Thanked: 139 Times
My god what is it?....Awesome job man. IMHO the color theme should have been better and some more chrome to the engine....
Great work man. Congrats
I think he already talked about that
"9. Custom made 4 pot hydraulic rear sprocket brake."
Doesn't it have a number plate?!
Last edited by vaisakhr : 10th November 2009 at 20:33. Reason: to avoid back to back post
vaisakhr is offline   Reply With Quote
Old 10th November 2009, 21:49   #15
Jaggu's Avatar
Thanked: 8,670 Times
Wow very interesting mod job, how is the engine handling the turbo job. Any rough performance figures?
and greenhorn this is a petrol turbo and that was a diesel engine?
Civic with K&N Typhoon Kit. EDIT : Now TURBO-Charged m4ugr8 Modifications & Accessories 327 6th September 2012 12:12
My Turbo charged Baleno - now 116 whp @ 6psi Edit:145whp at 11 psi! binz Modifications & Accessories 128 13th February 2012 10:18
Pete's Super-charged Audi R8! GTO Super-Cars & Imports in India 34 5th May 2011 09:59
Super charged Fiero venugopal Motorbikes 83 28th October 2009 13:00
