Old 15th November 2009, 20:57   #1
bivin's Avatar
Thanked: 114 Times
Default Honda Dio tyre change. need some help.
hey guys!!
my 2007 honda dio has just crossed the 10k mark and is well due for a tyre change, mostly due to my rather senseless obsession for burnouts.
i was going to replace it with mrf zappers, like the ones i have now(not sure of the series name), but was wondering if there were any other tyres available for the dio. does any other company manufacture tyres for the dio?? im looking different threads or atleast a wider rear tyre. i have always fancied the rear tyre of the kinetic blaze. can it be retrofitted onto a dio?
any info on the above is welcome.
thank you.
bivin is offline   Reply With Quote
Old 15th November 2009, 23:35   #2
aaggoswami's Avatar
Thanked: 1,542 Times
I would suggest you not to go in for wider tyres. There is not much space available for such modification. Next when you suffer from a puntured rear wheel, it would be difficult to take the wheel out. Infact, installing it first would be difficult also.
Although many people have done this, they end up bending the silencer for better accessibilty. also many people remove the rear mudguard for better access, but this is not a good thing. Those behind you will get a lot of water sprayed on them during rainy season.
Next, go for directional tyres. And dont overinflate. What happens due to overinflation is that the central grove will get used up pretty fast and the side will not be used up.
aaggoswami is offline   Reply With Quote
Old 16th November 2009, 01:38   #3
Thanked: 152 Times
Welcome to the club. Only in my case, its covered only 4000 KMS. Just replace the OEM ones with exactly the same. They are fantastic.
Cyrus43 is offline   Reply With Quote
Old 16th November 2009, 03:49   #4
Thanked: 54 Times
and make sure you buy the "tuffup" tube - this is usually available only at the dealers spare parts counter . When I went to buy a tyre for my dio at the mrf store - they didnt have the tuff-up tube and I had to buy it from the dealer !
techn0l0gist is offline   Reply With Quote
Old 16th November 2009, 17:13   #5
bivin's Avatar
Thanked: 114 Times
thank you for the help.
ok, so a wider tyre is out of the question. do any other brands offer tyres for the dio??
Old 17th November 2009, 02:14   #6
Addy's Avatar
Thanked: 9 Times
Default MRF Zapper
@bivin: Hey Bivin, do not disregard the broader tyres. They are just awesome. I have 4 Honda's at home, 1 Dio and 3 Activa's all are running with the MRF 100/90/10 tyre. It is just awesome and the grip is great. One of my cousin has gone 1step ahead and has both the front and back of the broader tyre. He is very happy.
Installation: There are no issues what so ever with this tyre. When you have a puncture its off easily only by bending the vehicle on the side stand, and once the puncture if fixed, ask the guy to fit the tyre on the bike first and then fill it up with air.
I am talking out of Experience!! But ensure that you fit the Tuff up tube as already advised. My Activa has clocked 76k Kms, and I am pretty sure I haven't suffered more than about 6-7 punctures!!
These tyres cost about 1k with the tube in Bangalore, give the tube back to the retailer and he reduces about 100-150 bucks.
Ride Safe
Addy is offline   Reply With Quote
Old 17th November 2009, 15:07   #7
bivin's Avatar
Thanked: 114 Times
thanks addy,
could you post some pics? i want to see the difference between the tyres.
Thanks once again!!
Old 9th November 2011, 14:42   #8
swarnava.m's Avatar
Thanked: 268 Times
Default Tyre Replacement for Honda Dio - Which brand?
Hello everyone,
My Honda Dio '07 has completed 30k+, and it is really time for a tyre change. The tyre size is 90/100, and I am considering going for some better tyres rather than the stock MRF. Tubeless, no doubt.
I am really not sure whether to upsize and go for a 100/90 or something similar only for the rear. I mean, is it fine to upsize only the rear? Also, what tyre brands am I looking at? I have heard some people putting Michelin for their Dio, but could not find out any product matching this size.
Any help would be really great. Thank You.
PS. Mods, I tried searching for a thread regarding this, but could not find a suitable one. If one does exist, please merge. Thank You.
swarnava.m is offline   Reply With Quote
Old 9th November 2011, 14:49   #9
Patriot_Vishwas's Avatar
Thanked: 132 Times
Default Re: Tyre Replacement for Honda Dio - Which brand?
I think that the stock Zappers are great!
I advice you against upsizing as you may experience drop in acceleration.
Even i wanted to get fatter tyres for my Dio due to the lack of grip during rains but was advised against it.
Patriot_Vishwas is offline   (1) Thanks Reply With Quote
Old 9th November 2011, 18:12   #10
swarnava.m's Avatar
Thanked: 268 Times
Would an upsize from 90/100 to 100/90 really cause a very prominent drop in acceleration?
And isn't the lack of acceleration far outweighed by the advantage of having better grip, hence better safety, especially in wet conditions?
swarnava.m is offline   (1) Thanks Reply With Quote
Old 9th November 2011, 18:24   #11
Thanked: 132 Times
I am skeptical about it pro's outweighing it's con's significantly!
One of the USP's of Dio is it's acceleration!
Even though the grip of the tyre is absolutely uninspiring when ridden on wet roads I've come around them by reducing speeds even more and relying on instinctual reflexes during panicky situations.
Anyways,it's your call in the end that matters
Patriot_Vishwas is offline   Reply With Quote
Old 9th November 2011, 19:27   #12
swarnava.m's Avatar
Thanked: 268 Times
Okay fine. I understand what you are saying.
Yes, if it is that significant then I don't think I am compromising the acceleration for anything. Stock for me, then!
Honda Dio - Test Ride islero Motorbikes 16 6th March 2018 12:50
Honda Dio Modded..still under construction..help needed!! xmOD Motorbikes 31 28th November 2016 13:28
Honda Activa vs Honda Dio vs TVS Wego vs Hero Maestro vs Suzuki Access 125 90BHP Motorbikes 172 12th October 2016 10:40
Need Help urgently - Dio or Flyte?? abhinav.s Motorbikes 20 6th May 2008 20:58
what do u think about the HONDA DIO? karthik247 Sedans 5 3rd April 2005 11:41
