Old 13th April 2014, 14:41   #61
Default Re: Yamaha RX 100 Queries
Originally Posted by The Great View Post
Its a fairly simple job, choke cable can be connected to your carb.
Thx. I will get this done from my mechanic here in Pune.
For this you will have to get a bracket welded to your chassis, and you will have to change the ignition switch to that of the RXZ for central locking. Though its hard to come by these days.
Have you or anyone tried this out? If you have any pictures of this alteration, can you please share them. I can then have a fair idea of it and can get it done since i had enquired some mechanics and they had never tried this. For the availability of the ignition switch, i am sure it will be available in Nanapeth area.
Intrepidspy is offline   Reply With Quote
Old 14th April 2014, 14:08   #62
The Great's Avatar
Thanked: 642 Times
Its a very simple procedure. Any welder would be able to do it.
Procure the lock set first. (i.e ignition switch), and u will be able to make out where u have to weld the small stopper on the chassis frame.
The Great is offline   (1) Thanks Reply With Quote
Old 2nd May 2014, 10:58   #63
I am planning t put the new RXZ central lock on my bike today. Also upgrading my headlight setup. Do you have idea where i can find Stanley 55/60 Bulb (H4) in Pune?
I had the original headlight Stanley sealed beam assembly (Japan) on my KB100 and the light throw was superb.
Old 28th July 2014, 19:35   #64
Awaiting Email Confirmation
Thanked: 39 Times
How do I find out if the Autolube pump is working on not, without removing the pump.
Is there a way to do it? The bike is a '92 RX100.
the-mechanic is offline   Reply With Quote
Old 28th July 2014, 21:54   #65
The Great's Avatar
Thanked: 642 Times
Assuming that you are talking about the oil pump, and the oil container is filled with 2t, - open the pipe that connects the oil pump to the carb (remove the carb side of the pipe) and rev the bike. If u can see the oil coming out of it when u rev, then the oil pump is working.
You don't have to remove the oil-pump to do this.
Old 4th August 2014, 15:12   #66
Thanked: 39 Times
The amount of oil coming out is very minimal. I have to squeeze the pipe just to see if there's any oil coming out. Is that good enough?
Also any idea where I can get:
1. An 'unused' Mikuni carburetor for an RX100;
2. The neutral wire rubber cap for the same.
Any help would be appreciated!
Old 4th August 2014, 20:07   #67
The Great's Avatar
Thanked: 642 Times
So your pump is working, now go to the mechanic, get the oil pump cover opened and adjust the oil flow as required. A steady flow of smoke from the exhaust ensures that oil is reaching the engine.
As for the spares, I would recommend you to place an order at the "Yamaha Factory Shop" in your area. Can't help with other locations as I am from Mumbai.
Cheers !
The Great is offline   Reply With Quote
Old 4th August 2014, 21:09   #68
Thanked: 39 Times
Cheers !
Thanks again. Oil pumps tuned and running fine now.
Will check out the Yamaha Factory Shop.
Old 20th January 2015, 21:47   #69
Originally Posted by vrprabhu View Post
Gordon,
Apart from what aargee has stated, please check out the air filter and petrol filter (if you are using one) too.
who has not only fitted RX100 with disc brakes but also a remote start (KiHo starter and car anti-theft remote!) way back in 2000!! So the rebuild is really endless.
Does anybody know a good mechanic in Mumbai Western Suburbs,who can fix a RX100. Please let me know.
NandanB is offline   Reply With Quote
Old 25th January 2015, 19:02   #70
WildInstincts's Avatar
Thanked: 59 Times
All,
I am looking for a good garage recommendations around Coimbatore for my RX100. Would you be kind enough to recommend any good and reliable mechanic who is familiar with RX100 engine works? Appreciate your help.
WildInstincts is offline   Reply With Quote
Old 5th April 2015, 16:35   #71
Mr.Boss's Avatar
Thanked: 2,535 Times
Guys, any help/pointers to use a Pulsar tacho in RX?
Mr.Boss is offline   Reply With Quote
Why was Yamaha RX 100 production stopped abruptly? finneyp Motorbikes 33 27th August 2009 19:51
Yamaha's new 100 cc bike coming this year ! nfs3000 Motorbikes 3 8th March 2007 22:01
Need advice on yamaha rx 100 badboy Motorbikes 9 18th June 2006 00:39
