Old 15th February 2010, 23:44   #181
stnair's Avatar
Originally Posted by EssYouWe View Post
@Rollin
Refer to Randhawa's thread for his figures. If my memory serves me well... I think it was 35 kmpl when he bought the bike, but it dropped down to 25 kmpl in the cold winters.
My 350 continues to give me figures in the mid 40s.
Good! Now I am happy I booked 350.
stnair is offline   Reply With Quote
Old 15th February 2010, 23:46   #182
Randhawa's Avatar
Thanked: 270 Times
@Essyouwe-
1.There is no way your caliper will touch the rotor. Probably your front disc pads are rubbing against the rotor. Actually mine has been doing the same for quite a while but I never bothered till now.
Cause-Either wrapped rotor or jammed caliper pins or piston.
2.Fork sleeve scrapping- Just get the sleeve aligned properly and thats all to it.
3.Thump should increase rather then decreasing as more your ride, more carbon deposit and the thump gets rich. Check for exhaust leak between the bend and the exhaust.
4. Check out the audio(not the video one) file in my CL review, if you have the same then I'll explain you the reason behind it.
Is it only on acceleration and under 60km/hr?
@rollin- Mine never gave more then 32km/l and now its hovering around 25-30km/L.
Randhawa is offline   Reply With Quote
Old 16th February 2010, 08:14   #183
Rollin' Thunda's Avatar
Thanked: 71 Times
@Rollin
Randhawa has now clarified that he never got more than 32 kmpl.
In fact, I think stnair's figures are possibly the 350's, not the 500's.
By the way, your bike looks FANTASTIC!!
Rollin' Thunda is offline   Reply With Quote
Old 16th February 2010, 10:02   #184
bj96's Avatar
Thanked: 130 Times
there is slight rustling sound and it stops rotating
Try cleaning and lubricating the caliper pin for free movement as other have already suggested. Also, ensure wheel bearings are not the culprit for "jammed" rotation.
If the resistance is not "serious", do not loose sleep over it. Try this- run the bike for 5-6 KMs with moderate speed, do NOT use front brakes. Stop the bike and try to touch the brake rotor (disc). If it is not warm/hot- means friction due to brake pads touching it is not high enough- you can ignore and ride on. It should go away on its own after sometime. However, if the disc feel "hot" (even without using front brake)- means the resistance (friction) is severe and you should get it attended- yours must be in warranty?
-BJ
bj96 is offline   Reply With Quote
Old 16th February 2010, 13:54   #185
iron's Avatar
Thanked: 33 Times
if ii am not wrong the CL350 does come with a fuel level.indicator
now this will obviously be due to the float built in the tank or something similar. can anyone post the electrical diagram from the manual for the same
iron is offline   Reply With Quote
Old 16th February 2010, 19:35   #186
EssYouWe's Avatar
Thanked: 16 Times
Hi guys...
Went to the RE workshop and got things fixed.
The pads were removed, scrubbed and put back. The revolutions are much better now.
The front mudguard was bent back into shape.
I requested the guy to tune the carb to slightly rich. He did it quite quickly, I hope he didn't screw it up.
I completed 1000 kms today. Yay!
@Iron
No it does not.
EssYouWe is offline   Reply With Quote
Old 16th February 2010, 20:01   #187
mustang89's Avatar
Post deleted by the Team-BHP Support : Please do NOT post one-liners that add little or no informational value to the thread. We need your co-operation to maintain the overall quality of this forum.
Please read our rules before proceeding any further.
mustang89 is offline   Reply With Quote Received Infraction
Old 16th February 2010, 20:32   #188
stnair's Avatar
I also dont believe it but The review is of 500. See the 3rd page of review posted below
Royal-Enfield-Bullet-Classic-500-Spunky-Thumper,Buy New Cars, Used Cars, Auto News and Reviews India - Zigwheels.com
@EssYouWee, Congrats on the 1000!. Keep going
Old 16th February 2010, 20:41   #189
stnair's Avatar
Default Question on Front Forks
RE Experts Pl clear a small doubt of mine- Sorry if my query is dumb.
Electra (and TBTS) are having Telescopic front Shock absorbers while Classic and others are having the traditional sleeved type. How does it compare with each other? Is the Telescopic forks better than the other in terms of riding comfort, durability etc or vice versa?
Old 16th February 2010, 21:08   #190
GreaseMonk's Avatar
Thanked: 87 Times
Im pretty sure the sleeve is just a dust cover, and underneath, it is the same telescopic as the other bikes. Although I have heard that they have changed the spring/damping variables of the Classic's suspension. Have not confirmed this though.
GreaseMonk is offline   Reply With Quote
Old 16th February 2010, 21:34   #191
stnair's Avatar
In that case if I put a sleeve on Electra fron forks, it will look the same as the Classic and other RE?
By the way, Here is the link for that review where RS CL500 claims a Fuel efficiency of 40.78. Royal-Enfield-Bullet-Classic-500-Spunky-Thumper,Buy New Cars, Used Cars, Auto News and Reviews India - Zigwheels.com
I posted this link in another post but cant find it now. Mods- Have you deleted it? If its not ok to paste links, then you may delete it again.
Old 16th February 2010, 22:39   #192
Thanked: 56 Times
atlast you are at the 1000 mark , too good to see your problem got fixed.. so when you are coming ? lol
shan2129 is offline   Reply With Quote
Old 17th February 2010, 00:38   #193
EssYouWe's Avatar
Thanked: 16 Times
@Stnair and Shan
Hehe! Thanks.
I am still looking for a nice helmet. Will surely try and get to Doon on the bike without telling my folks.
The engine and exhaust note has not improved. I am guessing it'll take another 20-30 kms for the new carb settings to impact it.
Old 24th February 2010, 15:27   #194
stnair's Avatar
@EssYouWee, @Randhawa
Why are you people so quiet? Have you stopped riding your Bulls? For people like me who booked it and are waiting waiting waiting waiting waiting to get the bike, reading your experiences is the only relief.
So please update !
Old 24th February 2010, 16:10   #195
RECL350's Avatar
So please update !
I was doing same 2 months back . Let me update, my wife has been complaining about pillion not being wide enough which is one of the root causes for leg and back pain on long rides. All bullets' pillion seats are narrow unlike rider seats, no one complains . I have given it for modifications and will be receiving it in the evening today. I have asked him to make it a bit wide at rear end, will post pics soon.
RECL350 is offline   Reply With Quote
Royal Enfield Classic: Initial ownership report xistinchaos Motorbikes 12 11th May 2016 19:37
Help required: Electra or TBTS or Classic 350 or classic 500 shailu Motorbikes 66 21st March 2016 23:29
The Thump, I always loved the most Ownership Review of Classic 350 traveloholic Motorbikes 31 14th February 2016 10:06
Enfield Bullet : Classic 350 versus Classic 500 zaks Motorbikes 173 1st June 2015 18:19
