Old 10th July 2010, 23:07   #346
rahulya007's Avatar
Thanked: 35 Times
Originally Posted by ElectraTspark View Post
I can help you and any TEAM BHPian in making or helping you to make a custom made LED for almost any light on two or four wheelers (Except the head lights).
ElectraTspark,
you can PM me on rahul.korde@gmail.com . I am on gtalk now os that we can chat..
rahulya007 is offline   Reply With Quote
Old 11th July 2010, 22:24   #347
rahulya007's Avatar
Thanked: 35 Times
hey ElectraTspark,
Today I had been to the RE showroom at my place for payment of my Electra and happened to see the change in headlamp. Earlier it used to clear glass with multi-focal reflector. But the one I saw today was having a multi-focal glass and plain reflector, the way it used to be on the standard. Does your bull have a similar one or the clear glass ? The CL's also have the same glass and come with an eyelid factory fitted, I guess. the dealer had 2 CL's of both the versions and both had the same old type glass.
Old 11th July 2010, 22:33   #348
Originally Posted by rahulya007 View Post
hey ElectraTspark,
The OEM was clear lens multifocal reflector. I have now switched to multi focal glass with plain reflector (Auto pal). I have also added the eye lid. I've added you on gtalk.
ElectraTspark is offline   Reply With Quote
Old 11th July 2010, 23:09   #349
EssYouWe's Avatar
Thanked: 16 Times
Hi guys!
Glad to see activity!
The rear plate connecting the short bottle to the frame broke off today. Was forced to tie the exhaust using a rope to the frame.
Was supposed to get the magic seat which would deliver me from the backache. But that wasn't to be.
In any case, not to be outdone by luck, I decided to get the foam changed on the current plate. Took 2-3 long hours. I got the back raised, the middle depressed and the front raised.
Something like what nasirkaka did.
Facing the exact same issue. The plate is too small, I am literally on the tank right now. Even though the back support is appreciated, I can't find a right position.
Re-tuned the Bull as well. It was not running lean, was in fact quite perfectly brown.
I am inclined to blame the XtraPremium petrol. Sucked out most of the top end.
@Those unhappy with the UCE mill's sound
My fellow brethren, a free-flowing exhaust does change things very positively. Do take care that the change comes after 2-3k kms.
You have a number of options:
- a short bottle
- a gold star
- a bazooka
- a rocket
- Punjab silencer
- Indore
- Chennai goldstar
- upswept goldstar
My vote however goes to the Punjab silencer. Sounds punchier than my short bottle and nowhere as irritating as a goldie.
It has a huge dia for the bubble and the end muzzle, longer than a long bottle. Do expect some serious torque issues, but the sound is to die for.
Do lemme know if anyone needs any help with their Classics in NCR!
Cheers people!
EssYouWe is offline   Reply With Quote
Old 11th July 2010, 23:31   #350
TheARUN's Avatar
Thanked: 498 Times
Getting to see many CLASSICs on the road. ROYAL ENFIELD must have got their wating period under control
TheARUN is offline   Reply With Quote
Old 12th July 2010, 16:54   #351
rahulya007's Avatar
Thanked: 35 Times
Thanks ElectraTSpark.
I saw one invite on gtalk by the name surajss. Is that you?
Also check the last post on page 23.
Does the change in reflector change the light throw or just the look.?
Rahul
Old 13th July 2010, 10:52   #352
Rahul
yes thats me.yes change in reflector and right kind of bulb makes a lot of difference in terms of spread and throw. In my experience convex glass has a Good throw than flat ones
Old 14th July 2010, 13:12   #353
bludhemn's Avatar
Guys, while cleaning my bike I came across this dangling gasket/seal at the kicker shaft. Didn't notice it before and I wonder if I should get it checked at the service center right away or just wait until my 1st service (another 300 kms to go).
Suggestions, anyone?
Thanks a lot
Felix
bludhemn is offline   Reply With Quote
Old 14th July 2010, 13:45   #354
Randhawa's Avatar
Thanked: 270 Times
@Felix- No need to worry, its just a extra piece of gasket which goes nowhere. You can pull it down with your hand and forget about it.
Randhawa is offline   Reply With Quote
Old 15th July 2010, 01:32   #355
bludhemn's Avatar
Oh, ok. That's a relief.
Thank you Randhawa
Old 5th August 2010, 14:51   #356
Randhawa's Avatar
Thanked: 270 Times
Hey Achint, can you confirm the movement of ammeter needle on your bull?. Just need to know how much the needle deflects to the right with the headlight on or just look at the video file I posted and see if its same on your bike.
Old 5th August 2010, 23:44   #357
EssYouWe's Avatar
Thanked: 16 Times
Replied!
Hit 5250kms. Will be getting a service done next weekend. Shifting to synth, lets see how it goes.
Cheers guys!
Old 6th August 2010, 00:00   #358
Randhawa's Avatar
Thanked: 270 Times
Wow, you have been riding lately. You will love the synth, are you going in for 300v?
Old 6th August 2010, 07:22   #359
EssYouWe's Avatar
Thanked: 16 Times
Exactly!
The riding is gonna stop again (shifted to a cab, 90 kms during rains would have been killer).
That day one of the nuts holding the rear seat and the rear shocks together with the frame came off. :P
All part of owning a Bull, I guess.
What happened to the Delhi plan?
Old 6th August 2010, 10:20   #360
Randhawa's Avatar
Thanked: 270 Times
Delhi plan is happening for sure as I need a new rear tyre. Left with only 20% tread on rear.
Whats happening with slime?
The nut on your came off and on mine the bolt broke.
@Felix- why is the chain lock on your bike facing the wrong direction?
Royal Enfield Classic: Initial ownership report xistinchaos Motorbikes 12 11th May 2016 19:37
Help required: Electra or TBTS or Classic 350 or classic 500 shailu Motorbikes 66 21st March 2016 23:29
The Thump, I always loved the most Ownership Review of Classic 350 traveloholic Motorbikes 31 14th February 2016 10:06
Enfield Bullet : Classic 350 versus Classic 500 zaks Motorbikes 173 1st June 2015 18:19
