Old 17th December 2010, 13:34   #571
EssYouWe's Avatar
Thanked: 16 Times
Default Re: RE Classic 350 - Initial ownership
@Adrian
Tried it already. :(
Its still there, and most annoying.
EssYouWe is offline   Reply With Quote
Old 17th December 2010, 14:05   #572
adrian's Avatar
Thanked: 602 Times
Originally Posted by EssYouWe View Post
@Adrian
Sorry to hear that friend, but there is nothing that can't be corrected. Check for air in the system. You are have a cold climate up north, aren't you ? Perhaps a cracked rubber pipe or something ? Check the seal of the fluid reservoir as well.
adrian is offline   Reply With Quote
Old 17th December 2010, 14:20   #573
stnair's Avatar
Brake fluid level is constant? Any leak perhaps ?
stnair is offline   Reply With Quote
Old 17th December 2010, 14:25   #574
EssYouWe's Avatar
Thanked: 16 Times
Nope. Its more or less constant. Will try and get the brakes bled soon.
Silly REs :P
Old 18th December 2010, 14:01   #575
adrian's Avatar
Thanked: 602 Times
Originally Posted by stnair View Post
The various seat modifications on Classic so far has been to harden the cushion and stiffen the springs. Perhaps we should try the opposite (soften both) and see the results?
regards
san
Hi San,
RE should have incorporated provision to adjust the tension of the springs and also to adjust the angle of the saddle. In Bajaj scooters one can adjust the spring tension by the twist of a nut and the saddle of the scooter is comfy too.
Old 18th December 2010, 15:15   #576
stnair's Avatar
Originally Posted by adrian View Post
Hi San,
The Classic seat is actually like a flat wooden bench. For a 70~75kg rider, it doesnt sag at all. No easy way out without modifying the entire seat. But this is pretty good for city rides. For long rides the only way out is take 10 minute break every 50 minutes. In a way its good - Regular breaks refreshes the mind and body - avoids fatigue. RE Engineers must have known that
regards
san
Old 20th December 2010, 13:43   #577
Milestone's Avatar
Thanked: 27 Times
Hi All - Of late I have seen rust on chrome around mirror, chrome around ignition key, chassis area etc. Can anyone help/suggest/solution for arresting the rust ?
Cheers !!!
Milestone is offline   Reply With Quote
Old 20th December 2010, 21:25   #578
stnair's Avatar
Achint
Ever thought of using K&N filter ? I know its costly and a bit of modification is required etc, but will there be any advantage in our carburetted C350 ?
By the way whats the status of your ABS ?
regards
san
Old 20th December 2010, 21:48   #579
EssYouWe's Avatar
Thanked: 16 Times
Hey,
Not really. I don't feel that the bike is gasping at high revs. Going unnecessarily lean makes no sense to me. I might go in for it when I want to play around with it some more. Tuning the carb right, itself creates a huge difference.
The ABS is still there. I am being slightly lazy about it, and haven't really gotten time from office to address that. The Bull is still busy clocking a 100 kms everyday.
UPDATE:
So the update for today is that my clutch cable snapped at the lever end on my way back home. It was the puncture revisited as I pushed the Bull uphill to a spot where I could park and do something about the cable.
Luckily, I was carrying a spare clutch cable. It took me a bit to get it done as I was having some difficulties with routing the cable. Luckily a guy stopped to help me out with it. He was a C5 and a Std. owner. While he fed the cable, I pulled it down. We fixed it and I spent a bit adjusting the play.
I had been in touch with Sanjeet, so I let him know that all was well and moved on. The clutch play wasn't working out right. It took me 4-5 tries to get it right (in the process ended with a burnt finger), but I finally managed to get it done.
As of now the plan is to manage till January and get a servicing done around January end. Will pick up another spare cable one of these days.
It anyway wasn't a great day for riding. I had almost banged into a dude, crossing the dude with his eyes fixed on his phone, in the morning.
Phew! Tired!
Old 20th December 2010, 22:30   #580
stnair's Avatar
Thats bad
What tools do you require for fixing the clutch cable ? Will the standard toolkit supplied by RE do ?
regards
san
Old 20th December 2010, 22:33   #581
EssYouWe's Avatar
Thanked: 16 Times
Yes, the standard toolkit is more than sufficient.
I was thinking of uploading a step by step picture tutorial. Just the lack of a camera that holds me back always :(
When will you guys feel pity and gift me one?
Old 21st December 2010, 13:03   #582
adrian's Avatar
Thanked: 602 Times
Hey,
UPDATE:
Hi, Did you grease the cable or is it not necessary in the new RE ? You must have shape shifted to Arnold Schwarzenegger after pushing the Bull uphill
First we will listen to the radio. How about a descriptive account of the procedure ?
Cheers !!!
How old is you Bull Milestone ? You park him in the open ?
Old 21st December 2010, 13:40   #583
Milestone's Avatar
Thanked: 27 Times
Hi Adrian,
It's 2 yr old, and it's parked in building parking area which is open from one side. Most of the time it used to be covered and recently someone stole the cover of my Bull and since the its parked open !!!
Cheers !!!
Old 21st December 2010, 14:23   #584
adrian's Avatar
Thanked: 602 Times
Hi Adrian,
Cheers !!!
Hi friend,
Covering the machine in monsoon season does more evil than good. Condensation forms and stays inside due to lack of ventilation and this is not good for the paint and chrome.
Regards Adrian
Old 22nd December 2010, 12:21   #585
Milestone's Avatar
Thanked: 27 Times
Hi friend,
Regards Adrian
Hmm, that could be the reason. I think, I will have to get some rust removal powder and try it.
Cheers !!!
Royal Enfield Classic: Initial ownership report xistinchaos Motorbikes 12 11th May 2016 19:37
Help required: Electra or TBTS or Classic 350 or classic 500 shailu Motorbikes 66 21st March 2016 23:29
The Thump, I always loved the most Ownership Review of Classic 350 traveloholic Motorbikes 31 14th February 2016 10:06
Enfield Bullet : Classic 350 versus Classic 500 zaks Motorbikes 173 1st June 2015 18:19
