Old 6th January 2014, 00:41   #1051
Thanked: 30 Times
Default Re: RE Classic 350 - Initial ownership
Guyes.. my classic 350 is more than 3 years old and had done 10k on odo.. I am currently facing two issues with mu bull.
1) Engine noise - Engine sound has over the years changed considerably and it sounds as if something has stuck inside the engine. When i took it to my mechanic i was told that the connector has a play. So engine was opened and bearing were changed. But the engine sound still hasnt improved. Has anyone of you faced this issue. If yes can you pls let me know how have you dealt with it. Soon i will post a video clip of the sound so that you will have a better idea.
2) second issue is about how engine looks after three years. I clean my bike every week and i give equal attention to the body as well as crome parts. Despite if that the engine looks very old compared to the rest body parts. I have used all sorts of crome polishes but none of them have actually made it look new or shiny. Attached emage clearly suggests that the engine looks old compared to other body parts. Can someone pls let me know how to make it look new.
Abhishekjp is offline   Reply With Quote
Old 6th January 2014, 11:47   #1052
Shakensoul's Avatar
Thanked: 222 Times
Regarding second issue, use a rubbing compound like this http://www.snapdeal.com/product/waxp...-and/280645246
I have used the same product with good results.
Only use it on the aluminum engine parts. Take small amount of rubbing compound on a piece of cloth and rub in a circular motion. It will turn black, after sometime take a clean cloth and slowly keep rubbing the area and it should shine like new.
Shakensoul is offline   Reply With Quote
Old 11th January 2014, 08:41   #1053
ariendj's Avatar
Thanked: 83 Times
im a new owner of the classic 350.
have been confused big time on how to do the first start for the classic?
the dealer told me to do only kick(with choke if required),the vehicle manual says the same.
but many others tell to just kick start at first and use ES for rest of day.
ariendj is offline   Reply With Quote
Old 11th January 2014, 21:17   #1054
swapnilup's Avatar
Thanked: 48 Times
Congratulations on your buy.
I was told only to use ES and I am doing that for the past 3 months now.
Will recheck with the service center guys.
swapnilup is offline   Reply With Quote
Old 29th January 2014, 17:43   #1055
Thanked: 430 Times
I'm facing problems with ES. I get only a "tak-tak" sound from the starter relay when I press the ES switch. A couple of taps on the starter relay did not bring about any change.
However the engine fires to life on the first kick. The battery was also changed recently (as in last 2 weeks).
Any tips, pointers? Am sure someone else out there have faced the problem. A couple of times I did have the engine grinding to a halt (for lack of a better phrase to describe the associated screeching sound). However this is not a daily or a weekly occurrence, the screeching to a halt part.
Btw, this is a 2010 version of the CL350. So it doesn't have the latest sprag clutch for sure.
Thanks.
P.S.: Also found out that the starter relay has also undergone some change of design in the later versions.
vinjosep is offline   Reply With Quote
Old 12th February 2014, 01:20   #1056
SHAHBAAZ's Avatar
Thanked: 109 Times
Hi Abhishek,
Use a Silvo polish for engine covers. This polish is very good for all aluminium, chrome and silver products. I have been using this since childhood... Directions are the same as in other cases..
http://www.amazon.co.uk/Silver-Polis.../dp/B001CIZ5H2
SHAHBAAZ is offline   Reply With Quote
Old 12th February 2014, 12:34   #1057
adrian's Avatar
Thanked: 602 Times
Did you get the connecting rod job done at RE service or with a local mechanic ? The engine sound in UCEs could be anything from the following :-
1. A lean carburetor (especially with a change in exhaust)
2. Exhaust header leak
3. Loose engine mounts
4. Cam gear lash
5. Faulty hydraulic lifters
6. Bend pushrods
7. Clutch trouble
8. Piston slap
9. Worn rocker arms
10. Valve guide damage
I think that you have been taken for a ride by the mechanic unless he checked for the listed problems before going for the rod job. You could have taken a second opinion from another trustworthy garage. Any way could you post the sound clip of the problem ?
regards adrian
adrian is offline   (1) Thanks Reply With Quote
Old 14th February 2014, 09:01   #1058
Thanked: 30 Times
4. Cam gear lash
6. Bend pushrods
7. Clutch trouble
8. Piston slap
9. Worn rocker arms
regards adrian
Mate
I did the engine job at a local mechanic but he is quite good. Its a place called Enfield riders where they organise Bullet rides from Mumbai to various places and they have their mechanics as well to do the repair work who are really good. I never take my biked to RE dealers even for servicing as i am never convinced with the kind of attention they give to the bikes. I have been to Yovage motors for servecing and the numbers of biked they service on a daily basis is unimaginably high. My bike sounded really weired before getting the engine job done and it was quite obvious that something was going wrong inside ( My technical understanding is very limited)
Offlate i have heard a lot about these UCE engines getting seized quite frequently on a log rides. Two of my friends had their engines seized when they went to ladakh last year. Even i am taking my classic 350 to ladakh this July. Hope the engine holds up. I have really looked after my bike since i got 3 years ago but this engine worries are making me mad. I even thought abt selling my bike if i get to a conclusion that this engine issues is not fixed.
Abhishekjp is offline   (1) Thanks Reply With Quote
Old 14th February 2014, 10:19   #1059
adrian's Avatar
Thanked: 602 Times
Mate
UCE engines are sturdy ones and the cases of engines getting seized are those which are not properly run in or the ones in which proper maintenance are not done. What I meant is that you get a seized engine when you run in the bike in the city traffic and one fine morning you head to highway and give the throttle full blast. You have to run in the bike to the 100 kph mark at first and it takes time. My ride is a 2011 standard and some times I think that the machine is going to fall apart due to the sound After a lot of worrying and sleepless nights I found out it is simply because of cam gear lash which the RE service should have rectified in the first free service. All they did was to assure me that it is the normal engine sound in the UCEs. Just run in your bike to the 100kph mark before going full blast to the highway and you will be fine. All the best for your ladakh trip buddy
regards adrian
adrian is offline   Reply With Quote
Old 12th March 2014, 17:30   #1060
Thanked: 40 Times
I have a 2013 model and inspite of Indian Railways trying their best to destroy my precious during transportation from Punjab to Pune, It has survived rather well and ageing beautifully. Since day 1, there has been a minor niggle in the form of a clatter from the fuel tank, as if some nut is stuck inside and is constantly getting pushed all around the tank. Service guys at the dealership say there is no need for the entire tank to be dismantled for such a minor problem and there is no cause of worrying as engine is well protected via a filter in the petrol tank.
Bhatt is offline   Reply With Quote
Old 13th March 2014, 10:33   #1061
Thanked: 289 Times
Make sure that the noise is from the fuel tank and not the engine. Engine knocking also called pinging also called pre-detonation all sound like they could be from the fuel tank area.
If you are sure that the sound is from the fuel tank, then removing the tank and turning it upside down is the easiest thing in the world
john doe is offline   Reply With Quote
Old 13th March 2014, 11:17   #1062
Thanked: 40 Times
Thanks John doe, although I am sure the noise is from the fuel tank but still would try to verify your suggestion. This rattling inside the tank occurs randomly and is absent most of the times. I think knocking would be much more consistent in its occurrence. I also believe I would be able to recognize engine knocking when I hear one, but still wouldn't want to take any chances with the Classic.
Old 10th April 2014, 10:52   #1063
Thanked: 53 Times
My Classic 350 had covered 1200km and the first 2 services. Spur of the moment decision and off I drove to Coonoor solo last week. Came back next day. Excellent fun! Few photos and the google map tracker (output from a small app I wrote) are available. While coming back, I saw a couple on a standard 500 on Mysore - Bangalore highway; that bike accelerated like anything and I am sure was cruising at 120kmph minimum; he just disappeared from my view though I was at 80kmph. Wondering if I should upgrade
vsbabu is offline   Reply With Quote
Old 24th April 2014, 12:19   #1064
Thanked: 19 Times
Is it possible to fit a Classic Chrome tank on a CL350?
My friend really likes the looks of a Classic Chrome and is planning to convert his black CL350 to Classic Chrome, so please suggest guys.
Also does anybody know the cost of a new classic chrome tank, read mud guard and front mud guards?
Vijay
vijay_k is offline   Reply With Quote
Old 6th May 2014, 11:54   #1065
Dear BHPians,
My classic350 is due for delivery in less than a month, I have got a call that the bike is allotted and I am in process of closing things on payment front.
Just wanted to know the important things to remember while getting the bull delivered and the important accessories that I have to go in for..please help with suggestions.
--Pramod.
118pramod is offline   Reply With Quote
Royal Enfield Classic: Initial ownership report xistinchaos Motorbikes 12 11th May 2016 19:37
Help required: Electra or TBTS or Classic 350 or classic 500 shailu Motorbikes 66 21st March 2016 23:29
The Thump, I always loved the most Ownership Review of Classic 350 traveloholic Motorbikes 31 14th February 2016 10:06
Enfield Bullet : Classic 350 versus Classic 500 zaks Motorbikes 173 1st June 2015 18:19
