Old 14th December 2009, 17:42   #1
Raccoon's Avatar
Thanked: 105 Times
Default Availability of DOT 4 brake fluid in Pune?
Is anybody here using DOT 4 brake fluid?
I need to change the fluid in my CBZ-X, but am unable to get DOT 4 anywhere. Everyone has DOT 3 only.
Same problem with the car.
Anybody from Pune who can point me towards shops that stocks small bottles that are needed for bike brake systems?
Tried calling up Bosch Chasis Systems (KBX), but it didn't help. :(
Old 14th December 2009, 23:12   #2
Thanked: 39 Times
I know i use a DOT 4 brake fluid for my Harley here in USA, my best bet try getting some info from harley in India and sure you can get your hands on that one.
4 oz bottle costs is 3.99$ in USA
shrini78 is offline   Reply With Quote
Old 14th December 2009, 23:37   #3
SunnyBoi's Avatar
Thanked: 2,778 Times
You do not need DOT4 for indian bikes. Have you ever seen your DOT3 brake fluid boil inside the master cylinder? If no then dont bother.
SunnyBoi is offline   Reply With Quote
Old 14th December 2009, 23:40   #4
Raccoon's Avatar
Thanked: 105 Times
Harley in India, esp. Pune? That will take some doing in finding out. Plus they need to be ready to sell it over the counter.
Damn... dunno why its soooooooo difficult to get DOT 4 anywhere here in town!!
Old 15th December 2009, 19:49   #5
Thanked: 63 Times
Bosch/Mico have a Dot 4 brake fluid. Try Behram on 9823354503.
Bomi is offline   Reply With Quote
Old 15th December 2009, 20:08   #6
Raccoon's Avatar
Thanked: 105 Times
^^^ Thanks a lot... but could you tell me who he is? I mean is he with Bosch or distributor or shopkeeper?
Old 16th December 2009, 01:18   #7
Thanked: 973 Times
Hey Raccoon,
I am using a Harley in Coimbatore, and recently did some brake fluid bleeding to remove some squealing, and needed DOT4 for replacement. It was readily available at the local bike parts shop. TVS Girling is now marketing DOT4 fluid as well as brake system spray cleaners, and should be available at your local auto parts shop.
Gthang.
gthang is offline   Reply With Quote
Old 16th December 2009, 15:53   #8
Raccoon's Avatar
Thanked: 105 Times
gthang, it is not readily available here. Else would not have posted here. Anyway, I found out two places in my area who stock KBX (Bosch) and TVS Girling... but both of them have only 250 ml bottles and above. :( And I need much less for my bike. If I don't get a smaller bottle, then I guess I'll have to buy 250 ml and waste the rest. Don't know how/where to dispose it. Any ideas?
Strange... dosen't anybody use DOT 4 for bikes??
Old 16th December 2009, 21:58   #9
Thanked: 63 Times
He fixes cars (usually high end) as a passion. most of these cars use the higher spec brake fluid so he carries an inventory.
Old 17th December 2009, 00:00   #10
Raccoon's Avatar
Thanked: 105 Times
^^^ Okie.. thanks! But that means he would most likely have bigger bottles required for cars. Will try and check with him though...
Old 17th December 2009, 05:37   #11
revtech's Avatar
Thanked: 35 Times
i recently topped up the brake fluid in my pulsar.dont rem if i used dot 3 or dot 4. will have to go home and check but it was readily available.
revtech is online now   Reply With Quote
Old 17th December 2009, 15:51   #12
Raccoon's Avatar
Thanked: 105 Times
^^^ Topped up? Not flushed/changed? Most likely they used DOT 3. Do check and let me know which make... if its DOT 4.
Old 17th December 2009, 16:08   #13
genesis's Avatar
Thanked: 294 Times
Fiat Palio's use Dot 4. You can try a car auto parts store?
genesis is offline   Reply With Quote
Old 17th December 2009, 16:59   #14
Raccoon's Avatar
Thanked: 105 Times
^^^ Dudes, as I now mentioned, I have found a couple of places that have DOT 4. But now the problem is they only have big bottles which are needed for cars. I need a small (100ml) bottle for bikes. If anybody knows which company makes smaller bottles, please do let me know. Else I'll have to buy a big one and waste a lot of fluid.
Also, it seems DOT 4 is yellowish and DOT 3 is red. Does anybody know if they come in other colors also? I need to ascertain that my ASC has used DOT 4 in the car.
Old 17th December 2009, 23:59   #15
Thanked: 172 Times
Raccoon let me see if we can Courier fluids. i may be able to get a bottle of DOT 4 for you by KBX. i will check it tomorrow the bullet Pricol system takes a DOT 4 in it.
desideep is offline   Reply With Quote
Brake fluid/Parking Brake Indicator light- Is this a problem? santosh.s Technical Stuff 10 7th June 2017 14:02
Anyone using DOT 5.1 brake fluid?? Shan2nu Technical Stuff 27 3rd May 2016 18:44
Brake Fluid Replacement - IMPORTANT vigsom Technical Stuff 50 1st June 2015 13:13
Brake fluid leakage- help required! santosh.s Technical Stuff 53 11th March 2009 23:16
DOT 3 vs DOT 4- Indica Brake Oil Change wolfinstein Technical Stuff 9 10th June 2007 18:04
