Old 20th September 2005, 17:44   #16
ScarySkulls's Avatar
Thanked: 19 Times
Discontinued because of the stupid Indian public for whom a stupid 4speed Rx is better 'cuz it gives more mileage.....stupid retards....
ScarySkulls is offline   Reply With Quote
Old 20th September 2005, 17:49   #17
Thanked: 1,640 Times
Originally Posted by Mpower
List out what mods you have. If its not ported, thats the first thing you need..then U can open up the bore.
Wonders how this dude does 140 without any mods other than the Cuticura Tin featured in the pics...
Steeroid is offline   Reply With Quote
Old 20th September 2005, 17:53   #18
Originally Posted by ScarySkulls
Looks like proton guys market their products very well. They know how they can fool the regular public.
Proton is a very respected name here. You do get generic expansion chambers from them but they also make them to order.
I happen to know the owner of Proton and he is definitely not the type to fool anybody.
hrag is offline   Reply With Quote
Old 20th September 2005, 18:43   #19
devarshi84's Avatar
Thanked: 119 Times
But I think the yamaha people are stupid people. they were selling a rx-z for 60k and didnt even give it a fat rear. And seriously that bike would have sold more at close to 50k maybe.
devarshi84 is offline   Reply With Quote
Old 20th September 2005, 18:44   #20
The Wolf's Avatar
Thanked: 58 Times
Malcolm, there are loads of stuff you can do to make your bike faster...If you wana use your bike for drag racing and daily use both then you cannot 1)rip the chassis 2) put in thinner tires 3) use bigger butterfly carbs nor any other weight loss treatments...
But otherwise:
1) ship a 28mm butterfly carb with single/double airjets.
2) carbonfibre flexible shortneck reed valve or slice the bore inlet and place the reed valve closer into the bore.
3) Port the inlet and outlet(should get the angles right hence should be done by a specialist)
3) Change the bore sleeve to a bigger one increasing the cc and fit in oversized al/ceramic piston.
4) Custom make ignition coil according to how much power they requre to burn the fuel depending on how much is your final bore cc's.
5) Quicken the Ig timing.
6) Change the sprockets(front and back both) with lesser teeth after checking on the final drive to the wheel is ascertained.
7) Use octane boosters in fuel.(Bardahl or stp)
8) Use quick throttle and make the bike more aerodynamic and lighter by using fibre parts in place of metal ones.(You can custom make aircraft grade aluminium chassis, rims, clip on's, wheel nuts etc...
9)Most Imp:: dont buy ready made expansion chamber...Get one custom made depending on what you want; low, midrange or top end. Your current one is a universal chamber spreading your power but get one done with a bigger expansion cone ann shorter stinger, that will give you enormous power and top end. Circuit racing requires big top end speeds hence ultra small chambers with hugh cones and narrow bend pipes.
10)In drag racing people donot use airfilters to maximise air fuel mixture but for road racing k&n or kawa cone filter should do good.
If you want anymore suggestions feel free to ask...I have 4 yrs of bike drag racing experience so dont worry i wont misguide you.
The Wolf is offline   Reply With Quote
Old 25th September 2005, 13:34   #21
Thanked: 19 Times
Talking hahaha....LOL
Yes yes mate.
Listen to this guy. Protons are the best out there.
One chamber suited to all.....
Every type of engine setup, every type of ignition curve, every type of driving style and final requirements.
U can't go wrong with the readymade "paarfarmance" chambers like krp, proton.
Go for them blindly...
Old 25th November 2005, 00:58   #22
devarshi84's Avatar
Thanked: 119 Times
what will be the price of a used Rx-z 5-speed in the best condition?
Old 25th November 2005, 17:37   #23
Thumbs down
140 is a long shot for an rxz. to reach a speed of 140 on an rxz ul hav to do tonnes of things like porting,filters,etc etc. the rxz's top speed is 110(stock) so just by fitting a proton exhaust there is absolutely no way ur gona get any where close to 140. u should be able to get a decent condition rxz for about 22 to 25k.
cooljun is offline   Reply With Quote
Old 25th November 2005, 22:03   #24
cbr1000f's Avatar
i have ridden malcolms bike and it does clock what he says it does on speedo.
his bike does clock 140 on speedo but it has nil acceleration in the loser gears.top end seems to be scary but.i dont know how it is this way!
my bike clocks a speed of somewhere around 130+ on speedo.(130-140 are very close to tell the difference on speedo) at 11000rpm!
if you are interested in a 5 speed malcolms bike is up for sale for 45k!! anyone interested can PM him!
cbr1000f is offline   Reply With Quote
Old 26th November 2005, 01:52   #25
devarshi84's Avatar
Thanked: 119 Times
Old 26th November 2005, 22:11   #26
cbr1000f's Avatar
i have seen quite a few 135 5 speeds but hardly any rx-z 5 speeds!!
should be pretty difficult to find someone whos kept his well
Old 4th December 2005, 02:53   #27
Default re
i got offer for 45000
malcolm is offline   Reply With Quote
Old 27th October 2006, 08:21   #28
higautham's Avatar
[quote=mclaren1885]get a k&n performance air filter fitted to ur bike dude...will give u a better growl and the pickup will increase..even ur fe might go up slightly]
i'm also having an yamaha RXZ 5 speed. iam thinking to have a K&N filter for it, how much will a K&N cost.
higautham is offline   Reply With Quote
Old 27th October 2006, 15:01   #29
higautham's Avatar
hi ... iam also having an yamaha RXZ 5 speed. i'm planning to have K&N filter for it. plz help me , from where shall i get it and how much will it cost.
Acquired!!!! RXZ - 5 Speed alok_balsekar Motorbikes 13 13th April 2010 10:25
My RXZ 4 Speed. jkdas Motorbikes 9 7th December 2009 16:32
Seeking Parts for RXZ 5 Speed in Bangalore Bhargava_sr Motorbikes 5 28th July 2009 16:19
