Old 18th December 2009, 11:05   #1
sreerama's Avatar
Default How to convert my unicorn to 200cc
HI i want to know which piston has to be used for the above conversion like the zma with 65.5 or p200 with 67mm.
I find that the connecting rod pin of uni is just 14mm so how to fix the bigger pin
Should i have to shave the piston on the top, if so how many mm? bcos i tried with ambition piston which is 59 mm which makes it to 159cc but i shaved it too much i guess so the compression is very low.
Thanks for your replies...
sreerama is offline   Reply With Quote
Old 26th January 2010, 23:35   #2
sreerama's Avatar
245 views but not reply
Old 26th January 2010, 23:50   #3
Sheel's Avatar
Thanked: 5,648 Times
I am very poor with tech knowledge but even if you manage it, reliability(99% chances) will take a beating,
just upgrade to a 150cc+ motorcycle
^^know you didn't want this reply but had to
on a more serious note, you want more performance right?
get a bigger(Karizma/P-220/RTR180)/better(R15) motorcycle.
Old 27th January 2010, 10:21   #4
chiragh_bir's Avatar
Thanked: 70 Times
i think Joel can help you out !!
chiragh_bir is offline   Reply With Quote
Old 27th January 2010, 10:48   #5
mercedised's Avatar
Thanked: 177 Times
You should max out at 165cc, 200cc is over kill.
Honda CB Unicorn/Unicorn Dazzler - Technical Specifications & Feature List bluevolt Motorbikes 0 25th September 2011 15:35
RTR/Unicorn or Avenger - which one? Edit: Bought Unicorn - Dealer woes manish7 Motorbikes 34 24th April 2008 11:53
is honda not going to get into the race for the 200cc and 200+cc segment bikes? mrstyx Motorbikes 10 1st April 2007 16:33
Intro & Question (200cc+ bike) Sriramk Introduce yourself 5 7th December 2006 11:14
I want know about CBZ 200cc thanksnet Motorbikes 2 10th September 2006 20:39
