Closed Thread
Old 10th January 2010, 15:29   #1
iron's Avatar
Thanked: 33 Times
Unhappy 6 month old Standard 350 does not go beyond 60km/hr:)
hi.
i have a 6 month old Standard350.
the problem i m facing is that the bike does not go beyond 60km/hr
the bike has done around 3021kms+.
Daily running is of around 36kms..
The bike has comlpleted 3 services from the A.S.S.
I told the problem to the mech at A.S.S. on the day of the 3rd service.
he said he will do the needful.
he tuned the carb but the bike still dint go beyond 60km/hr.
I took the bike to him the next day he said he will check the clutch plates, and he opened the clutch plates found nothing wrong put them bk and said he went for a test ride and the bike did arnd 80 -90km/hr.( i ws at wrk wen he was wrking on the bike)
since it was late evening and mumbai traffic did not allow me to go beyond 60km/hr.
Next day early morning i took the bike out at 6:30am. the bike accelarated really well ,gear shifting was extremely smooth but again it did nt go beyond 60km/hr.
My riding style is quite sedate i accelarate gradually and if the road is open i go upto 80-90km/hr on bikes. Can you guys please help me out .
iron is offline
Old 10th January 2010, 17:46   #2
Thanked: 1,572 Times
Originally Posted by iron View Post
hi.
Ok. Let's go step by step.
First check whether you are having a massive air leak by examining the intake manifold and the rubber hosing that leads to the air box. Does your STD350 choke for fuel(does it feel like hitting a brick wall at 60)? This could be the result of an extremely lean mixture.
Misfiring and choking for air will point out to an extremely rich mixture. Once upon a time, my LB500 had trouble crossing 80 when I jetted it way too rich.
Also, try riding with a new spark plug. This could be a possible solution if your previous plug is fouled.
Another issue could be a air lock in the fuel tank that could be stopping fuel at certain higher pressures.
Extremely loose pushrods(tappets) could also cause huge performance dips.
All said and done, it is very difficult to judge the issue without actually having a look at the motorcycle. I've done the best I know. I'll talk to my friend, Chinmay and get back.
Cheers,
Jay
JayPrashanth is offline
Old 10th January 2010, 18:14   #3
Here you go.
This is what Chinmay Dangre had to say about the issue. There was a Bullet STD350 with the similar issue.
1. Valve clearance(push rod setting)..keep it bit loose in test ride it.
2. Check the spark plug color
3. Make sure the carb is set on 1.5 to 2 turns as applicable.
4. Since it's a C.B. Point bike, so check the timing.
5. If timing is wrong then symptoms are:-A. the bend pipe will become bluish B. Black smoke from tail end. C. Over Heating issue. D. Some times misfiring.
6. For better performance get hold of EI system instead of C.B.POINT. Much way better life and performance n ZERO issue in future.
7. Check the needle setting in carb. make sure it is on 3rd position from top. Well it's a new bike so i doubt about the change in setting but stil just to verify.
Cheers,
Jay
Old 10th January 2010, 23:15   #4
iron's Avatar
Thanked: 33 Times
Originally Posted by JayPrashanth View Post
Here you go.
Cheers,
Jay
thank you for your replies Jay and thanx to chinmay also
1) what should be the color of the spark plug?
2)the bend pipe has indeed become blusih infact drak bluish
3)Is jerkin while the bike is running and hiss sound wen it jerks a symptom of misfiring
4)It does overheat sometime.
5) By E.I you mean Eureka's electronic ignition or OEM Enfield eletronic ignition? i'll b doing that after warranty period gets over
i'l get the rest of the tings cheked by my mech i will not go to the A.S.S.
thanks for ur help really appreciate it.
iron is offline
Old 11th January 2010, 00:00   #5
Iron,
Clearly a case of retarded timing which is automatically reducing your pick up as well as top speed. Since, you own a STD350, take it to a good mechanic in Mumbai who will set your timing correctly.
If the plug is chalk white, you are running very lean. The ideal color should be chocolate brown.
Cheers,
Jay
Old 11th January 2010, 12:46   #6
Thanked: 175 Times
in my case the bottle coil was faulty and thats why it was not going above 65 on the speedo.
desideep is offline
Old 11th January 2010, 14:12   #7
sriku's Avatar
Thanked: 167 Times
Since you are in Bombay, I can recommend Malik Auto, an authorised RE service center run by Malik (9892894789). All our bullets (Std 350, TB, 500LB) are serviced here, and I am sure he will be able to help you. His workshop is on the Eastern Express highway under the Kurla flyover. (Road leading from Suman Nagar towards thane.
In your case, as your bike is new, you should insist that the service center replaces the carb, plug, clutch and facing plates and set the timing correctly before considering replacing the points with EI. You could ask for and try bigger main jets on your old carb too.
sriku is offline
Old 13th January 2010, 14:38   #8
iron's Avatar
Thanked: 33 Times
Thank you everybody for ur replies.
it was the timing.
i took it to my mech he corrected it.
now it does 90 on the odo
iron is offline
Old 13th January 2010, 16:15   #9
it was the timing.
I'm pleased to hear that. Enjoy the magical thump of the STD350.
Cheers,
Jay
Old 13th January 2010, 18:27   #10
Rennjit's Avatar
Thanked: 84 Times
..now it does 90 on the odo
its not the max i hope, should be showing 100+. tried?
..the bend pipe has indeed become blusih infact drak bluish..
Time to thank RE A.s.s for their expertise now by claiming warranty replacement for pipe asap. Burnt chrome plating rusts easy.
Rennjit is offline
Old 13th January 2010, 23:37   #11
iron's Avatar
Thanked: 33 Times
Originally Posted by Rennjit View Post
its not the max i hope, should be showing 100+. tried?Time to thank RE A.s.s for their expertise now by claiming warranty replacement for pipe asap. Burnt chrome plating rusts easy.
i wud have tried 100+ but i ran out of road.
I called the dude who takes care of this replacement he said he's on leave for 2 days and asked him on a thursday as he will he bk in bombay.
iron is offline
Old 15th January 2010, 16:59   #12
masterblader's Avatar
it was the timing.
Good result Iron
I was confused when the machanic got 90 and despite your sedate style 65 was definitely unacceptable. If your bike is fitted with CB's there was a tendency for the igntion advance mechanism to seize not allowing the igntion to advance with increasing engine speed. Check the bob weights, pivots and springs on a regular basis.
masterblader is offline
Old 15th January 2010, 17:42   #13
Dippy's Avatar
Thanked: 192 Times
Note from Support:
Since the problem of the thread starter is now solved, this thread is closed.
Dippy is offline
Closed Thread
Royal Enfield Bullet - Standard 350 - production to be stopped? naveenroy Motorbikes 89 10th February 2011 17:57
Can a front disc brake be fitted on Bullet 350 standard model from enfield OEM parts? sidindica Motorbikes 27 26th August 2010 15:53
Paint Job - Bullet 350 Standard sherintjacob Motorbikes 7 28th April 2010 17:54
Problems With Standard 350 shan2129 Motorbikes 34 1st February 2010 12:55
LG Home Theater System: DVD does not run beyond a certain point rkavthekar Gadgets, Computers & Software 11 24th September 2008 09:47
