Old 4th April 2012, 23:52   #2491
aruncheloor's Avatar
Thanked: 191 Times
Default Re: The Royal Enfield 500 Classic thread!
My CL500's fuel efficiency has improved after the ignition map+ Bosch Primary spark plug change. Earlier, it used to give me around 20km/ltr. Nowadays, its in 25-26 range in the city traffic. So, i believe my 750rs was not spent in vain.
The vibes have come down a lot too. Vibes around 40km/hr speed was a real pain earlier. Now, i'm able to use the humongous torque without hiccups in 3rd gear. Kudos to RE.
aruncheloor is offline   Reply With Quote
Old 5th April 2012, 00:41   #2492
iron.head's Avatar
Thanked: 117 Times
thumbs up to Bosch for their plugs and extra 500 bucks to RE for selling a Rs 250 plug for Rs 750!
iron.head is offline   Reply With Quote
Old 5th April 2012, 01:34   #2493
ArizonaJim's Avatar
Thanked: 2,090 Times
Invader:
Your starting problem is very odd.
When you depress the starter button with the ignition key turned on, electrical power is sent to the starter solenoid thru a wire.
In order for this power to activate the solenoid another small wire coming out of the solenoid must be grounded (connected to the negative side of the battery).
There are two parallel electrical circuits which can provide this grounding.
One is the neutral switch.
If it detects that the transmission is in neutral, it closes to provide a ground path for the solenoid and also grounds the neutral indicator light in the speedometer, which will then light.
The other solenoid grounding circuit goes to the clutch lever switch.
When the clutch lever is left released, this switch is open and no electricity can pass thru it.
When the clutch lever is pulled in the switch closes providing a ground path for the electricity going to the starter solenoid. The solenoid will then be activated and it will connect the battery to the starter motor.
As you can see, either one of these circuits is capable of activating the starter solenoid but if one of them fails the other one can still work.
Activating one of the circuits like the clutch should not prevent the starter from operating even if the switch is defective providing the other circuit is operating.
As long as you can start the motorcycle this problem is not a pressing issue but when you take your motorcycle in for service be sure to tell the mechanic about the problem.
ArizonaJim is offline   (1) Thanks Reply With Quote
Old 6th April 2012, 09:04   #2494
Thanks ArizonaJim; I felt it was something to do with the charge and wiring however, you have explained it in a lucid manner.
Will request the gentlemen at the service station to look at these circuits and rectify.
Thanks again
Originally Posted by ArizonaJim View Post
Invader:
Invader is offline   Reply With Quote
Old 8th April 2012, 08:20   #2495
devarshi84's Avatar
Thanked: 119 Times
I am abroad and my father starts the DS and runs it for a minute twice every week.
I have had battery trouble twice before where the starter emits a krrrrr sound and the bike doesn't sound.
The first time the workshop guys charged the battery.
The second time they replaced the battery.
My dad last started the bike on Wednesday and today the bike is again making krrrr noise and doesn't start.
AM I looking at some other minor/major problem here?
devarshi84 is offline   Reply With Quote
Old 8th April 2012, 09:32   #2496
Thanked: 15 Times
I think you would need to actually take the bike for a round occasionally for it to charge, idling it for a few minutes won't do. Leaving the engine on while the bike isn't moving isn't advisable, in fact the Royal Enfield manual asks the rider to switch off the engine if it is at standstill for a certain period of time as the engine is air cooled.
Ideally if you aren't using the bike simply disconnect the battery and follow the storage procedures given in the manual. Either that, or give it to a friend who will treat your bike like a queen .
adises is offline   Reply With Quote
Old 8th April 2012, 10:42   #2497
ArizonaJim's Avatar
devarshi84
I agree with adises about the run time.
Running the engine for 1 minute will not create enough power to recharge the battery (even with the lights off) so starting the engine twice a week is basically running the battery down.
If the motorcycle is run for a period of 5-10 minutes with all of the lights turned off at a speed slightly above an idle it should recharge the battery enough to keep it in fair shape.
IMO a run of 10 minutes shouldn't overheat the engine as long as it is not running at a high speed.
The other alternative is to buy a "trickle charger" which produces about 1 1/2 to 2 amps. of charging power. Local motorcycle shops should have these for sale.
Do not use a battery charger that is made for cars as they usually produce higher charging amperage which can result in an overcharged battery.
Overcharging will destroy the plates inside the battery which create the electrical power.
Of course if you buy a trickle charger it must be attached to the battery correctly.
If it is hooked up backwards it may rapidly ruin the battery.
ArizonaJim is offline   Reply With Quote
Old 8th April 2012, 11:44   #2498
devarshi84's Avatar
Thanked: 119 Times
but are our C5 batteries so weak as to die out in 10 days? I was driving the back every day until 26th march.
Old 8th April 2012, 21:33   #2499
Thanked: 443 Times
Fellow CL 500 Owners, had a small question, if you may help.
I'm going to pick my Black CL 500 anytime next week, 12th or the 15th, initially I was planning go keep the silencer stock but now having read somewhere on the forum that the upswept one does not hamper the Running In process, I'm planning to go for it the moment I pick up the bull.
I am a bit finicky about the running in thing, I stick to the manuals be it cars or bikes.
Another query that I had was, how do i confirm if the silencer provided by the RE Dealership is a genuine one and not a fake one, actually there a small shop right next to this dealership which is into selling these aftermarket exhausts, so I want to be sure that the dealership does not pick up one from there and hand it over to me.
Any particular marks, stickers or anything that would help me figure out that it is a genuine RE upswept exhaust would be of great help !!
Request for your suggestions on the pros and cons on getting the upswept one on a stock bike.
Thanks !!
Happy Motoring !!
Torquedo is offline   Reply With Quote
Old 9th April 2012, 01:43   #2500
Thanked: 191 Times
My upswept silencer came in a RE cardboard pack. And i brought home my old silencer in that box. May be you can verify this before installing it.
aruncheloor is offline   (1) Thanks Reply With Quote
Old 9th April 2012, 14:53   #2501
bikham's Avatar
Need help in changing my classic clutch cable.Is there any video uploaded on how to do that.If i put the cable first from lever side then i am not able to put the cable at the other end.Tried adjusting screw also :(
bikham is offline   Reply With Quote
Old 9th April 2012, 15:10   #2502
nasirkaka's Avatar
Thanked: 529 Times
The original up-swept silencers has etching on the underside. The etching says something like " for off-road purpose". Dont recollect the exact words.
nasirkaka is offline   (1) Thanks Reply With Quote
Old 9th April 2012, 23:41   #2503
devarshi84's Avatar
Thanked: 119 Times
bump: Please advice what I am doing wrong or what's wrong with my bike.
Old 10th April 2012, 08:02   #2504
Thanked: 443 Times
Just read on the price list provided by the dealer that the left hand side carrier has been made an optional accessory and customers will be charged an additional fee for the same, this is w.e.f - 17th March 2012.
I am picking my bull on the 12th or the 15th shall keep all posted on the developments.
Happy Motoring !!
Old 10th April 2012, 09:28   #2505
Thanked: 32 Times
Happy Motoring !!
By side carrier do you mean the sari guard?! There is no side carrier (pannier/bag/box) that comes by default with the cl500.
Btw, which dealer have you finally booked with?
Puneet.S is online now   Reply With Quote
Royal Enfield Classic Chrome 500 - "The Chrome Decimator" xydon Motorbikes 17 9th February 2016 12:12
Enfield Bullet : Classic 350 versus Classic 500 zaks Motorbikes 173 1st June 2015 18:19
Royal Enfield Classic 350 / 500 - Now on Sale Puffdamgcdragon Motorbikes 1173 18th September 2012 17:31
Booked Royal Enfield Classic 500 but need help whether should wait for carb ketan4renault Motorbikes 12 29th June 2011 14:53
