Old 15th May 2012, 04:00   #2566
GreaseMonk's Avatar
Thanked: 85 Times
Default Re: The Royal Enfield 500 Classic thread!
As long as you get the same 55W/60W rated bulb, you won't need a relay.
GreaseMonk is offline   Reply With Quote
Old 15th May 2012, 09:21   #2567
nareshtrao's Avatar
Thanked: 183 Times
Originally Posted by bikham View Post
Can i fir Osram Night Breaker on my DS500 ? Do i have to use any relay for that.Please let me know if anyone has fitted it the model number of it.
Osram has improved a lot in the recent times, especially Night breaker series which is made in Germany. I have been using Osram Night breakers in all the cars (Civic and i10 currently - Getz and Lancer previously) and they last almost for the life of the vehicle. Their plain Halogens had a problem in the past and hence never were a success.
I have Osram Night breaker Chrome 500 for over 6 months and it is working well. No relay needed. Just replace the existing bulb.
H4 is what you need.
Philips Extreme is as good but is a little more whiter and closer to 5000 K. Whereas Osram is around 4300 K. While Philips is pleasing to eye and bright in close quarters, visibility at long distance and in foggy weather is poorer. Philips too lasts almost a lifetime.
Take your pick.
nareshtrao is offline   Reply With Quote
Old 15th May 2012, 09:33   #2568
//M
//M's Avatar
Thanked: 6,648 Times
I got delivery of my DS500 on 12th May and I have clocked around 90 kms on the odo. Checked everything in the PDI list as mentioned by Randhawa Sir. Also got the upswept exhaust fitted from day 1. The bull is running brilliantly and I have some minor concerns:
1. There are minor jerks while deceleration. Is it a common issue?
2. There are vibrations during low speed riding. These vibrations tend to smoothen up with speed.
3. The RVM's vibrate to some extent.
4. There is a tick-tick noise whenever I start the bike. How do I resolve it? I have read about it in this thread but I would like to know in detail about how to deal with the noise.
5. Does leaving the bike idle for a minute after starting every morning resolve the tick-tick sound?
6. The fuel economy of the bike has been around 20 kpl. Any inputs to improve it further? I have been riding it at sedate speeds of 40-50 kph during the run-in.
This is my first Bullet so please bear with my stupid questions.
Overall I am very satisfied with my purchase and the DS500 is a looker. The thump is lovely. The torque is humongous and it is a great feeling to ride the Bull in open roads.
//M is offline   Reply With Quote
Old 15th May 2012, 12:46   #2569
bradhey's Avatar
Thanked: 32 Times
@//M:
My advice to you, "stop looking at your bike through a microscope, just because its a Bullet" If it is running well and returning a descent mileage, there is every chance the bike is running well. Secondly if you read this thread you will find answers to all your queries.
From what I gather, your bike is absolutely normal, except for the mileage, which should be 20-25 % better. Try to running in your motorcycle on more open roads, as riding at 40-50 in top 2 gears is not a very good idea, as it lugs the engine. The idea is to keep the RPMs low but run at a speed that is appropriate for each gear, so that the engine runs cool initially and the internal parts mate well !
Note from Support - Post edited. Please avoid posting in bold text.
bradhey is offline   (3) Thanks Reply With Quote
Old 15th May 2012, 22:25   #2570
GreaseMonk's Avatar
Thanked: 85 Times
In addition to Bradhey's points:
Points 1 & 2: Welcome to the world of amateur fuel injection.
Bullets vibrate like mad. Mirrors will be the least of your concerns in the long run Just ensure that you ask the service guys to tighten EVERYTHING EVERY service.
The ticking is from the auto-decomp. Essentially when the bike's idling is too low, it opens the decomp valve to prevent the bike from turning off. I believe it is the auto-decomp mechanism which causes the ticking. Nothing to be worried about.
As you idle the bike when you start it for the first time in the day, oil is spread out through the system and the engine starts to warm up. It gets to a point where it idles at a sufficient speed for the auto-decomp to disengage, hence stopping the ticking noise. Again, all normal behaviour. If you mention this in the service station, all they will likely do is increase your idling.
GreaseMonk is offline   (1) Thanks Reply With Quote
Old 15th May 2012, 22:35   #2571
//M
//M's Avatar
Thanks a lot bradhey and GreaseMonk for the valuable inputs.
I have another query. While filling up petrol, drops of petrol tend to spread in the fuel tank. Will this affect the matte paint of the Desert Storm? I wiped off these drops today with a wet cloth cautiously without rubbing the paint and then did the same with a dry cloth over the affected area. Is it the correct process or should I resort to some other measure to retain the original matte finish in the long run?
Old 16th May 2012, 09:00   #2572
ruchirtnt's Avatar
Thanked: 74 Times
Take your pick.
I have ordered for a philips crystal vision at 4300k,
it is a white light with a pair of parking light, can somebody suggest that can i fit these parking light in our enfield eyes.
Dealer told me that it is better than extreme, any inputs please
ruchirtnt is offline   Reply With Quote
Old 17th May 2012, 11:52   #2573
iron.head's Avatar
Thanked: 115 Times
UPDATE-All new UCE500's are coming with Bosch Platinum Plus WR8DP as the primary plug! Verified it by checking a Desert Storm which had come to the workshop for PDI. Could not check if the secondary plug had an extra washer with it. One mechanic said that there is no extra washer with the secondary plug but I could not check it myself. I got my bike on 4th January and it did not have the platinum plus plug. Another nice practice of RE is to use different parts as per availability for installation on our bikes. If the stocks of one thing gets finished another alternate part is used and vice versa.
Another Update-Bought a Bosch Super WQR6DC plug from RE and I have been using it in place of the Platinum Plus for the last 2 days. Smoothness of the bike is not like before. Rarely there are some jerks. Will install the platinum plus again and see if the smoothness comes back.
iron.head is offline   Reply With Quote
Old 17th May 2012, 17:28   #2574
nareshtrao's Avatar
Thanked: 183 Times
Installed NGK Iridium IX Plug set (Both Primary and the Secondary Plugs) on the Chrome 500. Difference is evident. Much smoother than what was previously there. This is October 2011 batch Chrome.
Tried Stop and Go Bangalore traffic and also Highways at speed up to 125 kmph. Seems to manage without any strain and misses.
Rather expensive as a set but probably worth the improvement. Rs. 650 for Primary and Rs. 550 for Secondary (I am told the Platinum Plus is Rs. 750 for Primary but no Secondary available - hearsay and not verified myself).
Old 17th May 2012, 23:57   #2575
iron.head's Avatar
Thanked: 115 Times
Hi nareshtrao
Can you please quote the part number of the plugs that you have bought for your Classic Chrome 500? Are both the plugs exactly same in dimensions? Primary plug that we have is also used in some cars and the secondary plug is used in some bikes. Bosch Platinum Plus WR8DP MRP is 250 when in Bosch packaging and Rs 800 now when in RE packaging.
I will check in the local market for NGK platinum plugs in a day or two. Bosch makes the best plugs and a secondary platinum plus might be available or the dealer can make a order for us for the minimum number of plugs. Will check back and update.
Old 18th May 2012, 08:32   #2576
nareshtrao's Avatar
Thanked: 183 Times
Hi nareshtrao
These are two different plugs. One regular size for the Primary plug ans one smaller that is usually the secondary plug. I bought in individual packing but now realize that the same is available in a set for RE CL 500 on PlanetDSG
NGK Iridium Spark Plug : Royal Enfield Classic 500 (Set of 2..
As a set, it costs only Rs. 1100. Details and part number in the link.
By the way, you mentioned, NGK Platinum. I am referring to NGK Iridium. (Lots of stuff available on the web comparing Platinum and Iridium plugs, should you be keen to research)
Old 18th May 2012, 11:28   #2577
mobike008's Avatar
Thanked: 6,179 Times
Installed NGK Iridium IX Plug set (Both Primary and the Secondary Plugs) on the Chrome 500. Difference is evident. Much smoother than what was previously there. This is October 2011 batch Chrome.Tried Stop and Go Bangalore traffic and also Highways at speed up to 125 kmph. Seems to manage without any strain and misses.
Naresh, I note you too have a Chrome 500. As you know mine is Dec-2011 model.
Can you share a feedback for below queries?
a) What is the stock plugs in my bike? Is it good or should i replace them with NGK?
b) What is the major difference that can be felt between stock plugs and NGK?
c) My bike has done 1900kms till date and i have touched a max 100kmph. Above that it does not seem possible to go as bike feels too fast and a bit of vibration too. How did you reach 125kmph?
Old 18th May 2012, 11:48   #2578
nareshtrao's Avatar
Thanked: 183 Times
1. Stock Plugs are fairly good. I did not have Platinum plus though. Despite, I never had any major issues with stock plugs except missing once a while when suddenly increasing throttle. The move to another plug is more of a technology fascination than the claimed benefits. Though bike does feel considerably smoother now. And further research on the web tells a lot about superiority of Iridium in supporting good combustion and long lasting electrodes. Much better than Platinum.
2. As I said, the bike does feel smoother. No jerks and misses ever. And the speed. However, Pick-up seems almost the same.
3. I have done 1700 in last 7 months. Did not exceed 100 to 110 with the previous plugs. Not that they were not capable but did not want to as the bike was running-in. After 3rd service at 1600 and a change of plugs, I tried the speed and it went up to 125. However, I must admit that it refused to go beyond 125. I would have tried if I had a few more kilometers of road which I ran out of. But I doubt it would have gone more than another 5-10 kmph. Perhaps 130 is the max it can ever go. I think.
Of course vibrations are there beyond 100 but quite manageable. Wobbling has not been there at all as reported by some. This is perhaps due to the fact that I removed both the wheels when bike was new and got the truing done by an old hand in Shivaji Nagar and remounted them. I did not trust the balancing and truing of factory.
Hope this answers. Happy to give more details if you want. Let me know. Thanks.
nareshtrao is offline   (1) Thanks Reply With Quote
Old 18th May 2012, 11:53   #2579
iron.head's Avatar
Thanked: 115 Times
I am aware of Iridium plugs but they are much more expensive than platinum plugs and that's why I skip them. Bosch makes Platinum Fusion plugs as well which have 4 electrodes but they are quite expensive as well (platinum plus Rs 250 and platinum fusion around Rs 700). Bosch Iridium are even more expensive and I think that platinum plugs are good enough for our C5's.
Hi mobike008
Stock primary plug in your bike should be Bosch Super WQR8DC and the secondary plug is Bosch UR6DC.
I have done back to back tests with the stock primary plug and a platinum plus as the primary plug. Difference is quite evident between the two plugs. Rides at slow speeds are smoother. Minor 'jerks' between slow downs and gear shifts are much lesser which makes the overall experience much smoother and better. Platinum Plus and other advanced plugs help greatly in winters as these plugs reach higher temperatures faster than stock plugs and help to burn off the carbon on the tips quicker. So the warm-ups in winters are quicker. RE recommends to replace only the primary plug with a Bosch Platinum Plus which is good enough but Iridium plugs might perform even better. Replacing the secondary plug might not make much difference but you can replace it too with a better plug if you wish.
My bike has high speed instability from the beginning and the rear starts wobbling right after 115.
iron.head is offline   (1) Thanks Reply With Quote
Old 18th May 2012, 14:35   #2580
mobike008's Avatar
Though I am aware of folks changing their sparkplugs in cars with Iridium but, never could manage to find out if there was any marginal increase in their performance, as such replacements were part of many other mods including customized air-intakes, re-maps etc so couldnt really make out the difference of iridium spark plugs improvement in isolation
Thanks for the feedback, I reckon will try NGK soon myself as 1100bucks for a smoother ride isnt too expensive. Besides, if it doesnt work too well, can always go back to stock plugs
Thanks IronHead. So your feedback clearly states the following
Bosch is just fine C5--> Platinum Plus are better than Bosch--> NGK Iridium would be even better.
Nice! So i reckon it makes sense to jump from fine to even better for a smoother ride
Let me go for it in my next service ( 3000kms) which should be due in July-2012
P.S: Do I source the plugs from PlanetDSG or its available off the shelf in automative spare parts shops?
Royal Enfield Classic Chrome 500 - "The Chrome Decimator" xydon Motorbikes 17 9th February 2016 12:12
Enfield Bullet : Classic 350 versus Classic 500 zaks Motorbikes 173 1st June 2015 18:19
Royal Enfield Classic 350 / 500 - Now on Sale Puffdamgcdragon Motorbikes 1173 18th September 2012 17:31
Booked Royal Enfield Classic 500 but need help whether should wait for carb ketan4renault Motorbikes 12 29th June 2011 14:53
