Old 24th April 2014, 10:11   #3526
nareshtrao's Avatar
Thanked: 337 Times
Default Re: The Royal Enfield 500 Classic thread!
I will be soon replacing the rear tyre of my Classic 500 Desert Storm. Is it advisable to go for a tubeless rear tyre?
Also, what brand should I look for? I don't intend to upsize or downsize.
You can not fit Tubeless tyre on the rim that comes with spokes on Classic. You will have to go for alloys.
Originally Posted by cataclysm View Post
Hi Guys,
I noticed yesterday that the at least 2 teeth from the rear sprocket of my bike are missing. Just wanted to ask if anyone knows how much would it cost to get the sprocket changed from the service centre? Or is it advisable to get the complete chain set replaced?
Thanks!
You should change the entire set as the chain may have been damaged and would further damage the new sprocket
nareshtrao is offline   Reply With Quote
Old 24th April 2014, 10:19   #3527
ArizonaJim's Avatar
Thanked: 2,004 Times
I have no idea what a new sprocket would cost. I assume that would depend on whether your Royal Enfield is one of the older Ci or AVL models or one of the new UCE machines.
The older models would only need a new sprocket. The sprocket for the UCE' models is integral with the brake drum so it may have a higher price.
As for the rear drive chain, it is undoubtedly damaged. In fact, it is most likely the cause of the missing teeth on the sprocket.
If you get a new sprocket and don't change the chain, your new sprocket will soon be trashed.
Always install a new chain whenever the front or rear drive sprockets are changed if either of them show any damage at all.
Once the new sprocket and chain are installed, be sure to oil the chain every 500 km or sooner. Even every 400 km isn't too often.
ArizonaJim is offline   (1) Thanks Reply With Quote
Old 24th April 2014, 13:10   #3528
Rennjit's Avatar
Thanked: 80 Times
Uce inherited the rear brake drum- sprocket combo from the old Bullet, only that its flipped to right (wrong? ) side. Its one of the very few functional elements carried on to uce models from yesteryear thumpers. Typically on oldies the rear sprocket lasts through a couple of chains & least one FD sprocket change. It all depends on the riding style though.
Rennjit is offline   Reply With Quote
Old 25th April 2014, 06:17   #3529
cataclysm's Avatar
Thanked: 88 Times
I have no idea what a new sprocket would cost....
Thanks for the reply guys! I'll be getting the complete chain set changed.
cataclysm is offline   Reply With Quote
Old 25th April 2014, 11:37   #3530
Maestros,
I have been told by many that attaching a Yamaha RD 350 handle bar to the new UCE Classic 500 makes it more comfortable. I am 5ft 9in. While city driving is not a problem, on cruises, I tend to develop a slight back pain on the right side after driving for more than an hour at a stretch. A short stop gives me another hour.
Want to know if any of you have fitted the same or have seen anyone fit it and if yes, then how does it work. I saw the handle and it goes wide so that instead of stretching in front, the hands would go outwards. Not sure how good this would be.
Please suggest.
csubhojit is offline   Reply With Quote
Old 25th April 2014, 12:43   #3531
man_of_steel's Avatar
Thanked: 1,056 Times
Please suggest.
I have tried the RD350 replica handlebar(HB) on my TBTS and have fallen in love with it totally, both in city and highways. Infact I never went back to the stock HB after that. My friend has fitted an RD350 replica with cross member on his C350 and has confirmed after an 800kms ride that the seating comfort has definitely improved over the stock HB. He has also tried Electra's HB but found the RD HB more comfortable.
Regarding the question on how it works, yes it is wider than the stock one but it is also higher. This makes seating much more relaxed. And regarding the back pain, the spring seat could also contribute to the back pain. Its not at all meant for a bike with rear suspension(soft tails).
man_of_steel is offline   (1) Thanks Reply With Quote
Old 25th April 2014, 12:54   #3532
Thanks man_of_steel. This definitely helps. If only now I can find a good mech to fit it on my new bike.
Old 2nd May 2014, 10:01   #3533
cataclysm's Avatar
Thanked: 88 Times
Hi Guys,
All of a sudden my bike's self start stopped working. I fiddled around with the fuse box and it worked but now it's back to the same. When I press the button nothing happens but the battery is fine and the bike starts with the kick. Any suggestions?
Old 2nd May 2014, 10:23   #3534
akshay4587's Avatar
Thanked: 1,629 Times
Hi Guys,
You are still running the stock battery i guess from 2011?
The bike starting with kick doesn't mean that battery is fine.
Mine starts with a kick with almost dead battery.
Get the battery checked first.
Old 2nd May 2014, 10:27   #3535
cataclysm's Avatar
Thanked: 88 Times
Yup it's the stock battery! The battery has been low for quite sometime now but it was starting fine till yesterday.
Old 2nd May 2014, 10:36   #3536
akshay4587's Avatar
Since its old,battery should be the first point of failure
Even i need to get one.Let me know from where you get and how much.
Old 2nd May 2014, 10:38   #3537
cataclysm's Avatar
Thanked: 88 Times
Will let you know. But the problem was that when I fiddled with the fuse box it started fine and now nothing is happening:what:
Old 2nd May 2014, 11:10   #3538
justin.das's Avatar
Thanked: 67 Times
In Short am looking for a remap for classic 500 version 1.0.
Reason For Remap
Me and brother owns two Royal Enfield 500's.The one belongs to brother is 500 version 1.0 and mine is classic chrome 500 version 2.0.Even though the specification is same both of them have different characteristics.My bike power delivery is more torque'y than that of my brother bike .His 500 is struggling in lower rpm's in all gear's and in the same scenario my bike is behaving normally(am not talking about lugging here).My bike gives a smooth and linear power delivery in the same case i have to keep the engine boiled to extract power from my brother's bike.can i remap the older version to that of version 2.0 ?will a remap fix this issue ?if yes how can i do it?
justin.das is offline   Reply With Quote
Old 3rd May 2014, 09:21   #3539
Thanked: 56 Times
Reason For Remap
The best part about Royal Enfield is that you can simply ask the ASM or TSM in your locality ( through dealership | Brand store ) & ask them to remap your BULL & they will do it no questions asked. Just ask them for the newer map.
shan2129 is offline   (1) Thanks Reply With Quote
Old 3rd May 2014, 11:00   #3540
justin.das's Avatar
Thanked: 67 Times
Originally Posted by shan2129 View Post
I tried contacting the dealership but as per them the map which they have is a 2012 version but my bike is 2013 February model and they are not sure about the current version of map .Any way decided to give it a try
Royal Enfield Classic Chrome 500 - "The Chrome Decimator" xydon Motorbikes 17 9th February 2016 12:12
Enfield Bullet : Classic 350 versus Classic 500 zaks Motorbikes 173 1st June 2015 18:19
Royal Enfield Classic 350 / 500 - Now on Sale Puffdamgcdragon Motorbikes 1173 18th September 2012 17:31
Booked Royal Enfield Classic 500 but need help whether should wait for carb ketan4renault Motorbikes 12 29th June 2011 14:53
