Old 12th August 2014, 20:13   #3601
Rennjit's Avatar
Thanked: 75 Times
Default ES Motor make ?
Can anyone please let me know the Make/ brand of Electric stater motor used in Uce models?
It is an outsourced component, the pre-unit 500's had great DENSO made motors while most 350's had pathetic Varroc make (worst ever thingie on those bikes, yuck.. the motor's screech even puts diesel ricks to shame!)
Denso ain't easy to get. Current Uce ES motors sounds good but to save myself from pains later i'd prefer to know the make
Could some one here pls help?
Rennjit is offline   Reply With Quote
Old 16th August 2014, 19:04   #3602
Default Re: ES Motor make ?
The stock part is not available but you can try a Minda branded one which can be used in UCE.
Objectiveman is offline   Reply With Quote
Old 17th August 2014, 00:24   #3603
ArizonaJim's Avatar
Thanked: 1,829 Times
Default Re: The Royal Enfield 500 Classic thread!
I'm not sure who makes the electric starter motor that is used on the new UCE engines, but I have yet to hear of a failure of one of them.
There has been a number of failures of the electrical starter solenoid (relay) which controls the electrical current to the starter motor.
This solenoid is the large cylindrical device which has the heavy duty wire running from the battery to it and a similar wire running from it to the electrical connection on the starter motor. Several smaller wires are also connected to it to activate it.
ArizonaJim is offline   Reply With Quote
Old 19th August 2014, 21:23   #3604
That is true Jim, infact I mistook the question about starter motor for starter relay.
An unrelated question for you Jim. I got the piston-cylinder kit changed recently after 39000 km on my C5. What should be the oil change period and should I treat 2000 km as the break-in period? I have been using Motul semi-synthetic 15W50 since some time now.
Thanks.
Old 19th August 2014, 22:22   #3605
cogentr's Avatar
These are Denso 0.9 KW motors.
cogentr is offline   (1) Thanks Reply With Quote
Old 20th August 2014, 01:08   #3606
ArizonaJim's Avatar
Thanks.
The new piston, piston rings and cylinder do need to be broken in.
During this period the rings and cylinder wall will wear. Early in the process greater leakage between the top of the cylinder and the crankcase will occur. This is especially true under high loads so using large throttle openings should be avoided.
While the engine is running, the piston, being aluminum, also expands much more rapidly than the steel liner that forms the cylinder bore. This will result in a light skuffing of the aluminum until enough of it wears away to provide a near "line to line" fit. If done slowly, no harm will be done to either part.
The dangerous part of this is if the engine is run hard and fast, the piston will expand faster than it can be worn away. This will result in the piston grabbing the cylinder wall and "seizing". This may not stop the engine but it can damage the piston.
IMO, you should break in a newly fitted cylinder, rings and piston by riding easy and giving the new parts a chance to cool off by stopping often on longer trips. I would avoid speeds higher than 65 kmph.
5 or 10 km trips at moderate speeds without stopping is fine unless the weather is unusually hot.
The new piston and rings should be worn in pretty well by the time they have been ridden 600-700 km.
I recommend changing the oil and oil filter following this break in. They will have accumulated a lot of small pieces of steel an aluminum which wore off of the cylinder wall, the piston rings and the piston. You really don't want those small bits in the engine and they will tend to plug up the oil filter.
Given a nice break in, your engine should be good for another 40,000 km.
ArizonaJim is offline   (2) Thanks Reply With Quote
Old 22nd August 2014, 00:11   #3607
Thumbs up Re: The Royal Enfield 500 Classic thread!
Thank you Jim. I knew it needed to be broken in, what I needed to know is for how many kilometers, which I know now. :-) Thank you.
I have been following your posts since some time now on this and other forums. It is great of you to share your knowledge with rest of us.
Note from Support - Please avoid quoting a full post as it inconveniences our mobile users.
Last edited by n_aditya : 22nd August 2014 at 15:55. Reason: quoted text shortened
Old 5th September 2014, 19:26   #3608
Hi All,
I have a machismo 350 and am thinking of buying DS500. I went for a test drive today just to get an idea of extra torque. Dealer had only std 500 so couldnt test the EFI engine.
What i observed was that vibrations were very high compared to my machismo. Infact did a test drive for a CL350 just to see if it is the case with newer models but vibrations were much lesser compared to std 500. Dealer said its just because the test drive std 500 is not well maintained and that it is more than an year old model. Wanted to know what is the experience of people with the latest classic 500 version.
sameerg is offline   Reply With Quote
Old 6th September 2014, 02:33   #3609
Randhawa's Avatar
Thanked: 217 Times
Originally Posted by sameerg View Post
Hi All,
Fortunately your dealer is right, just go ahead with the booking. You can try to get a test ride from a different dealer of a CL/DS 500 just to clear any doubts.
Randhawa is offline   (1) Thanks Reply With Quote
Old 6th September 2014, 05:59   #3610
Thanked: 95 Times
I recently changed over to motul semi synthetic oil (checking first the recommended product on the motul website for RE). Although the bike has been running fine i noticed that the colour of the oil (as seen from the viewing glass) has turned completely black! Is that normal? The only other mods on the bike are k&n filter ro5010 and iridium sparkplugs. Ans on that note i can add that there has been zero difference performance....only blackened oil
argchoff is online now   Reply With Quote
Old 7th September 2014, 00:59   #3611
ArizonaJim's Avatar
All good motor oils contain detergents in them to keep the interior of the engine clean.
These detergents (soaps) are effective on different by-products that are created as the engine runs so while one oil may be very effective, another companies oil may leave deposits behind.
Different oil companies use different detergents so by switching brands of oil, the new oils detergent often removes the accumulated debris that was left behind by the previous oil.
This can make the new oil appear to be much darker colored than the old oil was.
The color change is not necessary bad.
Usually the particles that are making it appear so dark are so small in size that they will have no negative effect on the ability of the oil to lubricate and clean the engine.
In other words, the dark oil will work just fine even though it looks "dirty".
My advice is to leave your new "darkened" oil in the engine and change it at the next scheduled change interval.
Old 7th September 2014, 10:08   #3612
Thanked: 95 Times
Thanks. I might probably upgrade to fully synthetic oil for next oil change.
Old 7th September 2014, 13:27   #3613
Originally Posted by nerd1200 View Post
I know it has been quite some time after I posted this, but here I am keeping my promise.
Went down to the RE showroom and here is the breakdown of RE On-Road prices in Bangalore. Hope it helps some of you.. I was quite disappointed to find out no new models were on display at present. Will visit again next month.
I checked with another showroom, they said DS and other c500 have waiting of 2 months and TB500 just 15 days while the image you attached says 6 months for DS500 and 2 months for TB500. Which one is correct? Is my dealer lying or do different dealers have different wait lists?
I was under the impression that RE would be maintaining a waiting list at all india level rather than a dealer/region level but over past few days have heard stories of people getting bikes earlier in vizag/mangalore vs people in bangalore.
I am planning on booking a DS500 so a little confused
Old 7th September 2014, 23:53   #3614
Thanked: 48 Times
Bike wise waitings are different I guess.
In February, thunderbird waiting was longer in Gurgaon than classic. Now the reverse is true.
P.S. is offline   Reply With Quote
Old 8th September 2014, 01:09   #3615
Bike wise difference is ok. I am concerned about dealer wise difference on same bike.
Royal Enfield Classic Chrome 500 - "The Chrome Decimator" xydon Motorbikes 17 9th February 2016 12:12
Enfield Bullet : Classic 350 versus Classic 500 zaks Motorbikes 173 1st June 2015 18:19
Royal Enfield Classic 350 / 500 - Now on Sale Puffdamgcdragon Motorbikes 1173 18th September 2012 17:31
Booked Royal Enfield Classic 500 but need help whether should wait for carb ketan4renault Motorbikes 12 29th June 2011 14:53
