Old 27th August 2015, 13:51   #3751
bikertillidie's Avatar
Thanked: 537 Times
Default Re: The Royal Enfield 500 Classic thread!
Originally Posted by Rennjit View Post
How did you confirm the difference?. Tried fitting it or a mech/part guy said so?.
I was hoping for a similar 'upgrade' believing it to be a drop-in replacement.
Hi Rennjit,
I had used a vernier caliper to measure the ID when we had difficulty sliding the replacement bearing in place.
An alternative would have been to machine the OD of sprag gear collar (where the bearing sits) to the right size.
But this idea was discarded, as I didn't have recourse to a lathe shop on a Sunday.
Secondly, I didn't want to forego use of my cycle for an extended period.
bikertillidie is offline   Reply With Quote
Old 14th October 2015, 22:06   #3752
Very Extensive and detailed review. Gave me a lot of inputs. I am intending to purchase a used RE Classic 500. I am getting a Classic 500 - 2010 model in 85K. is it worth the price. I had a RE Std 350 1997 model, hence I do not have any idea about the new RE's.
Please advise. Thanks
RE30 is offline   Reply With Quote
Old 25th October 2015, 18:42   #3753
Thanked: 332 Times
Is it possible to get tubeless tyres for Royal Enfield Classic 350cc?
StallionAmit is offline   Reply With Quote
Old 28th October 2015, 17:55   #3754
Thanked: 34 Times
Amit,
If your intention is to go tubeless, it's impossible with spokes based rim. If you upgrade to alloy rims then it is a go. I would not advice any aftermarket alloys as you see it on the internet for 12K, it could crumble on off-roadings, unless it is a genuine one.
However, you can fit a tubeless tyres but with tubes in it, as it is very hard to find a good buttoned tubed tyres.
I fitted a 4.25 MRF Moto C on the rear recently for my Leh ride, and it was a wise decision for me. This one rubs the underside of the mudguard when going over a hump or pot holes (numerous in Bangalore). My decision was based on another tbhp user, he was suggesting Moto C or D. I don't remember his handle or username.
sgmitr13 is offline   Reply With Quote
Old 28th October 2015, 18:17   #3755
akshay4587's Avatar
Thanked: 1,540 Times
Originally Posted by sgmitr13 View Post
Amit,
A tubeless tyre on a spoke rim is indeed possible; big tourers world over have tubeless tires, mounted on spoke rims.
In fact it is possible to convert a normal
Spoke rim to a tubeless one after some DIY.
Worth it or not is anyone's guess. I had planned this for my classic 500, but never got time to execute it.
Old 29th October 2015, 10:48   #3756
Thanked: 1,032 Times
Mate the big tourers you are mentioning come with reinforced sidewalls on their alloy rims where the spokes are attached(See Triumph Tiger, BMW R1200 GS, Suzuki Vstrom 650, etc. spoked wheels). In case of a conventional rim you will see that the spokes are attached directly to the middle part of the rim. The conventional setup does not allow using tubeless tyres, however there are some modifications that can be done. But then again it is not fool proof.
navin_v8 is offline   Reply With Quote
Old 29th October 2015, 11:51   #3757
//M
//M's Avatar
Thanked: 8,389 Times
I ride a Classic 500 Desert Storm, 2012 model, 37000 kms done approximately. During my very recent trip to Spiti, the bike started spitting white smoke from the exhaust. I topped up the engine oil but the exhaust started spitting white smoke as well as some amount of unburnt engine oil.
I have never faced such an issue before. What could be the issue?
The oil is not burning properly it seems, issue with the piston ring?
Also can anybody point me to a good 500cc specialist in Pune? Maybe in one of the authorised service centres? I have been getting my bike serviced from Alex of Royal Motors in Pune, but somehow not very satisfied in the last few months. There is a new independent workshop which has opened near my place of stay, called Bullet Guru. The owners Mr.Negi and Mr.Jaikant are from the Roadshakers club. Any feedback of this workshop?
//M is offline   Reply With Quote
Old 29th October 2015, 11:57   #3758
man_of_steel's Avatar
Thanked: 1,050 Times
Oil shouldn't burn. Its place is outside the combustion chamber. As you mentioned, it points to worn out rings or scratched piston/cylinder wall.
man_of_steel is offline   (1) Thanks Reply With Quote
Old 29th October 2015, 12:07   #3759
outofthebox's Avatar
Thanked: 349 Times
That is correct. But absolutely makes no $$$$ sense for RE CL 350/500.
This is the Alpina Tubeless spoke wheel kit. Price varies between INR 100k to INR 150K per wheel depending on bike model in UK. By the time one gets it into India, the total price is likely to be in the region of INR400k.
outofthebox is offline   (1) Thanks Reply With Quote
Old 29th October 2015, 12:07   #3760
rakesh_r's Avatar
Thanked: 620 Times
I believe you had the same issue during one of the Tapri meets while riding to Lavasa.How was the issue resolved?
Looking at the issue,looks like a Piston/ring is the culprit.
As far as I know Alex does a pretty good job.I suggest you visit him again and see what he has to say.
rakesh_r is offline   (1) Thanks Reply With Quote
Old 29th October 2015, 12:36   #3761
dkaile's Avatar
Thanked: 3,517 Times
Infractions: 0/1 (4)
I think it should be possible. See link -
http://www.google.co.in/url?sa=t&rct...06130839,d.dGo
http://www.ebay.com/itm/Tubeless-kit...770165&vxp=mtr
Outex kits from Japan are available at Karol Bagh shops in Delhi for around 10k. One of my mates had got it done for his Street Bob. Don't know if it makes fiscal sense in a Bullet where you can opt for alloy wheels in the same cost. BTW my Heritage Softail Classic does come with Tubeless Tyres on spoked wheels.
Cheers...
dkaile is offline   (1) Thanks Reply With Quote
Old 29th October 2015, 13:20   #3762
Thanked: 349 Times
Thank you for sharing this info dkaile. More interesting than their tubeless kit is their puncture repair kit. Appears to be a better solution than Slime. Have bookmarked their eBay store.
outofthebox is offline   Reply With Quote
Old 29th October 2015, 14:15   #3763
//M
//M's Avatar
The Tapri meet issue was very minor and was resolved. Thanks for the pointer !
I will check with Alex again, hopefully the issue will be resolved.
Old 29th October 2015, 16:08   #3764
Thanked: 155 Times
I'm planning to service my 1.5 years old CL350 (~15,000 kms) at Bullet Guru!
Had a chat with one of the guys.
Servicing cost: Rs. 450 (Includes wash & general check-ups)
You have all Motul engine oil options: 4T, 5100, 300V etc (charged per bottle)
They also keep the regular spares: handle-bars, seats (perfect seats), silencers (AEW), LED lights etc.
What I observed is there stock is same as Tehalia's (also a Roadshaker) located at Pimpri Chowk opp. Shakti Sports. But their mechanics work in front of the shop in very limited space! Servicing charge: Rs. 350/-
I decided on Bullet Guru as they have proper work benches & tools! As I don't require any special services just a regular service with oil change.
Hope this helps and please share your views! You can at least show them the symptoms and see their diagnosis before checking with Alex.
Cheers,
surjaonwheelz is offline   (1) Thanks Reply With Quote
Old 30th October 2015, 17:32   #3765
maker_of_things's Avatar
Thanked: 130 Times
Hi guys. I just joined team-bhp almost a month or so back. But I've read almost the all of the posts on this thread. Gave me some valuable insights into my Classic 500. Big thanks to Randhawa! Cheers!
Getting to the point. I guess all of you know that the rear seat is a pain in the butt, literally. I was thinking of replacing it with a carrier which maintains the old school classic aura of the bike. I saw on post on Royal Enfield's North America's instagram account. I really liked this carrier. If you look closely you'd notice that the front portion of the carrier is attached to the shock absorber's nuts, like how the rear seat is attached, while the rear is attached to the rear mudguard stays (I'm assuming that's what they're called).
So I started looking, and found something similar on Chawla Auto Spares' website. Here's the carrier. The only difference I noticed is that the rear rods which need to be attached to the mudguard stays look quite small.
Your ideas would be greatly appreciated.
Thanks!
maker_of_things is offline   Reply With Quote
Royal Enfield Classic Chrome 500 - "The Chrome Decimator" xydon Motorbikes 17 9th February 2016 12:12
Enfield Bullet : Classic 350 versus Classic 500 zaks Motorbikes 173 1st June 2015 18:19
Royal Enfield Classic 350 / 500 - Now on Sale Puffdamgcdragon Motorbikes 1173 18th September 2012 17:31
Booked Royal Enfield Classic 500 but need help whether should wait for carb ketan4renault Motorbikes 12 29th June 2011 14:53
