Old 17th July 2010, 21:19   #451
bludhemn's Avatar
Originally Posted by EssYouWe View Post
Re-foamed it into a slightly more comfy shape. The problem is that its great for long rides, but quite tedious to be on in the city.
Hi, Could you please post pics of the mod? I am looking to mod my seat as well, perhaps this could provide some insight.
Fel
bludhemn is offline   Reply With Quote
Old 17th July 2010, 21:34   #452
EssYouWe's Avatar
Thanked: 16 Times
Fel
Hi! Apologies, don't have access to a camera. :(
I can however, describe the shape and advise you against it if you drive in the city.
If you are taller than 5'11", any back-lifting on the stock plate will result in you being seated too close to the tank. If you prefer the forward position, then it'll be perfect.
What I basically got the guy to do was pad up a raised back, curve out the part where you'll actually sit and raise the front end. Even though the seat is very comfy, I find the forward seating position very awkward for the city.
So, basically I would advise you against changing the shape a lot. You can try harder foam before you change the shape.
Or if possible get a larger plate (which would mean either no pillion seat or a new one).
EssYouWe is offline   Reply With Quote
Old 18th July 2010, 01:16   #453
bludhemn's Avatar
Oh, ok. I think this is exactly what I had in mind. I'd stand around 5.8 , so I don't think it will pose much of a prob when modding the seat, especially if I change the handle bars to something similar to nasirkaka's.
Are you on the stock handlebar? If so, perhaps a change of bars may be what you are looking for, since you mention that you have to lean forward while riding.
Old 18th July 2010, 10:11   #454
EssYouWe's Avatar
Thanked: 16 Times
I did consider that, but i will still have to bend my legs more to find the foot peg than with stock. I did raise the handlebar a bit, don't want to stretch the cables too much so going to wait on the handlebar change.
Frankly, I like to run stock!
Sad you live in cochin, I could have taken your seat's foam. :P
Old 18th July 2010, 14:06   #455
bludhemn's Avatar
..I have an old sofa in my backyard...would you like to consider that ?? :P
Old 23rd July 2010, 18:01   #456
bradhey's Avatar
Thanked: 32 Times
Has anybody got any information on the power and torque curves of the C5 A proper diagramatic representation would be great help. Thanks
bradhey is offline   Reply With Quote
Old 23rd July 2010, 18:36   #457
GreaseMonk's Avatar
Thanked: 87 Times
Find attached a power\torque chart of the C5 at the wheel.
Courtesy 72Westie @ Royal Enfield Motorcycles - The Official home of Royal Enfield in the USA
Source: 2009 Bullet G5 EFI Dyno Results
GreaseMonk is offline   Reply With Quote
Old 24th July 2010, 13:15   #458
nasirkaka's Avatar
Thanked: 536 Times
21? And they said it was 27+ :(
It is the difference between the power at crank and power at the wheel?
Personally, i feel that C5 is quite under-powered for a totally new and modern engine, displacing 500 odd cc. Does anyone else here feels the same about C5? Any tips on how to improve the performance of a C5? (sometimes i feel this Fi is a devil disguised as a god, wrt performance mods..)
My guess is that C5 would be the SLOWEST 500 cc bike developed in recent past. Will dig out more on this and confirm.
nasirkaka is offline   Reply With Quote
Old 24th July 2010, 15:29   #459
GreaseMonk's Avatar
Thanked: 87 Times
Yes, this is at the wheel. 27 is supposedly at the crank. Enfields always had quite a high loss w/ transmission.
You've got to understand that this is a low compression air cooled engine with a very basic balancing system to 'retain the old bike charm' aesthetically.
The real modern thumper would be something along the lines of the KTM Duke, etc with two digit compresion ratios, a full-fledged counterbalance shaft and IIRC, liquid cooling. But a bullet frame\body with a KTM engine would have looked quite awkward IMHO.
Old 24th July 2010, 17:56   #460
nasirkaka's Avatar
Thanked: 536 Times
@ GreaseMonk:
Opps.. Thats some real loss. (6 bhp)
I dont get a few points.
The C5 with integrated gear box as UCE, wet clutch plates, about 15% reduction in No. of engine parts which is suppose to greatly reduce the transmission losses, is STILL loosing 6.5 BHP from crank to wheel.
Where as, the Cast Iron based STANDARD 500 looses about 5-6 BHP from crank to wheel.
Where is the gain then?
i think aesthetics of a bike is purely industrial design issue/approach. A 500cc based powerful bike (LC) could still be made to look retro.
A typical example that come to my mind is Triumph Bonneville.
An 850 cc bike generating 66 bhp at 7500 VS a 500cc generating 27.5 bhp.
(ofcourse the triumph is a parallel twin and there is difference in price)
Old 25th July 2010, 01:37   #461
nasirkaka's Avatar
Thanked: 536 Times
internal view of a 500CC UCE EFI:
Old 26th July 2010, 09:58   #462
ac 427's Avatar
Thanked: 114 Times
hey there,
another month for my classic 500 to roll in. its been 7 months of long waiting time.
cheers,
ac
ac 427 is offline   Reply With Quote
Old 26th July 2010, 13:08   #463
Randhawa's Avatar
Thanked: 272 Times
I thought you would have got your C5 by now, did you not booked your C5 last year?
Randhawa is offline   Reply With Quote
Old 28th July 2010, 18:02   #464
Randhawa's Avatar
Thanked: 272 Times
Any one lives near Kashmiri gate in Delhi? Need urgent help regarding a bearing I need.
Old 28th July 2010, 18:47   #465
girishab's Avatar
Default A long wait ends..almost
For about an year now, I was thinking of upgrading from my 2001 model CBZ. The reason for the upgrade, well, was the age showing up on my bike even though it surpassed the expectations I had from the 150cc mill, though I was not sure as to what I wanted for myself at that point in time. Heart would say go for the old-world charm of Bullet 350 Std (especially since my dad rode one and I have vivid memories of my childhood on this bike) but mind would pop the question “would you be confident that it will not leave you stranded?” So began the search for other bikes and I tested the new ZMR and P220. However, for some reason I wasn’t completely satisfied with these (though I cannot point out the reason behind it). And then came the news of the Enfield Classic being launched in India and I decided to go for the Classic 500. Unfortunately, could not book it in the initial days of launch as I was in the middle of a job change and had too many things to take care of. Once things settled down and approval sought from better half, I booked my bike in Feb 2010, with a waiting period of 6 months.
Then began the long wait, with constant calls to the RE brand store Jayanagar on the progress, getting glued to the thread on C5 on team-bhp. My morale went up everytime people shared the plus points of the bike and their feelings on owning it and so did it take a beating when people talked about the fundamental design issues, questioning myself on the decision. But again, looking at the effort and conviction of people like Randhawa and Nasirkaka (to name a few) to bring the issues to the attention of RE and/or fix them, I convinced myself that all will be well (hope that will turn true).
So, after a long wait, I will be taking delivery of my bike this Friday and am eagerly looking forward to the experience of owning an RE. By the way, I was surprised that the price for C5 in Bangalore has increased by about 7k as compared to the price in Feb.
Will update on the initial experiences soon.
girishab is offline   Reply With Quote
Royal Enfield Classic Chrome 500 - "The Chrome Decimator" xydon Motorbikes 17 9th February 2016 12:12
Enfield Bullet : Classic 350 versus Classic 500 zaks Motorbikes 173 1st June 2015 18:19
Royal Enfield Classic 350 / 500 - Now on Sale Puffdamgcdragon Motorbikes 1173 18th September 2012 17:31
Booked Royal Enfield Classic 500 but need help whether should wait for carb ketan4renault Motorbikes 12 29th June 2011 14:53
