| LinkBack | Thread Tools | Search this Thread |
| | #1 |
| BHPian Join Date: Jan 2010 Location: Mumbai
| Hi all, I have this weird problem all of a sudden. My babe has done 25K kms and has been properly run. Suddenly after the last Servicing ( nothing major was done), there is a terrible sound when i change my gears. Also, the smoothness that i changed the gears earlier, is missing. Any reasons this could pop up suddenly? also, my mechanic suggests changing the clutch plate to 5 speed. is this good? Please let me know. |
| | #2 |
| BHPian | while changing do u completely disengage the clutch and then shift or do u shift at half clutch? |
| | #3 |
| BHPian Join Date: Jan 2010 Location: London
| Never heard of a 5 speed clutch? Please explain If the clutch is suspect there are several checks needed. 1. cable correctly adjusted 2. friction plates within working tolerances 3. plain plates are true and not distorted 4. clutch spring length within working tolerances 5. If pushrod operated ensure correctly seated and bush in good condition Some motors have 2 different types of friction and plain plates and if not assembled as per factory a clean gear change will not be acheived. Good luck bud |
| | #4 |
| BHPian | I had the problem with mine a few times, tighten the clutch cable ( thats what my mechanic said he did). the problem went away immeditly. |
| | #5 |
| BHPian | he probably means 5 plate clutch. post 2003-04 all bikes were equiped with the 5 plate clutch. correct me if i am wrong. AFAIK 5 plate clutch were factory provided for the CI500 it was the CI350 that came wit 4plate clutch this was pre-2004. |
| | #6 |
| Hi Deep Try and adjust the clutch manual setting. Slacken off adjuster at handlebar end, undo the inspection plug on the clutch cover you will see an aduster screw with a locknut on the pressure plate. Undo the locknut with a screwdriver turn the adjuster until you feel contact at the other end now back off just a smidge and tighten locknut. Take up the slack using the adjuster on the handlebar leaving approx 1/16" freeplay. Pretty sure you will get a result. Good luck mate |
| | #7 | |||||
| Quote:
Thanks guys for the reply. will let you know of the results. | |||||
Similar Threads | ||||
| RPM shoots up when changing gears | lambdaplus | Technical Stuff | 110 | 3rd February 2013 02:23 |
| What makes the Cast Iron (CI) engined Bullets cruise effortlessly at low rpms? | aruncheloor | Motorbikes | 30 | 2nd July 2012 23:00 |
| Attention: Bulleteers with Cast Iron/AVL engines with electric starters | JayPrashanth | Motorbikes | 19 | 17th December 2010 16:37 |
| Changing gears without using the clutch | Lalvaz | Technical Stuff | 32 | 30th July 2008 12:19 |
| Not changing gears !!! | shirishindurkar | Technical Stuff | 27 | 14th September 2007 18:29 |
