Old 9th November 2005, 17:42   #31
go to Johnnys garage in bandra. he ll tell you exactly what to do about the battery.
will send you his number, he maintains many superbikes
sunilbakshi is offline   Reply With Quote
Old 9th November 2005, 17:46   #32
Default go to
Old 24th November 2005, 02:43   #33
Max
Thanked: 85 Times
Well guys,
My Aquilas battery is going out every 10-14 days or so due to the fact I don't drive my bike much and its NOT driven enough to recharge its little battery (read ahead). I also use lots of horn and high beam which adds to electric bill . Well, its battery is used allot and this beast's heart has electric powered ignition system so if battery is out it just refuses to run.
My Aquila's original imported battery is costing rs.6000+. This really freaked out engineer inside me and I decided to find out solution for it. I opened my aquila's battery and I found its using pulsars 900MAh battery instead 12Ah battery required by Aquila (previous owner was smart). But since pulsar battery is small I have to recharge battery every 7-15 days because I don't drive bike much and I drive it on low speeds at lower RPM's so it doesn't get much time to get self recharge. Pulsar battery cost only Rs.900 (exide) as compare to original battery which costs Rs.6000+ and has waiting period of about 15-30 days. I went to market to check if any other higher capacity battery will fit in but in local market here all dealers are only selling Exide batteries and I was not able to find any other battery with greater Amps battery with aquila standard battery size. Pulsor battery is small for aquilas battery compartment but next higher Amps battery becomes too large for it. So I have to keep pulsar's battery in it. after all its local and cheap as compare to original battery price.
Well, wait, I am still not replacing my battery because its still holding 70% charge as compare to new battery so I have decided to keep using it. I have made external charger and plug system in my bike so that I don't have to remove covers every time I want to charge my bikes battery through external charger. Now I charge my battery every week for about 1 hour and it works wonderful.
Do any one know about some good quality branded 12V external battery chargers ? Any suggestion about price and where to get them ?
So I saved Rs.6000+ with simple Mod and external charger cost me only Rs.250. I know charger is not perfect but who cares if battery lasted for 12 months instead of 24 !! Today I studied internet allot and studies some basics of electronics and learned about resister thing which will reduce voltage of my battery charger from 15.5V to 14V required to charge battery. I will be asking my B.E. professor brother to find out correct resister value for me to reduce voltage and I think then charger should become little more perfect.
Overall, I have really learned lots of things with my aquila about bikes and electronics which I never knew before. Till today my Aquila is working very well with zero maintenance.
Extremely happy with my Aquila.
Cheers !!!
Max is offline   Reply With Quote
Old 28th January 2006, 02:31   #34
Max
Thanked: 85 Times
Well, I searched around in the market and found that no standard Exide brand battery is fitting in my aquila then one guy told me to look for sealed batteries. I was told to buy YUASA batteries (costing rs.1800) buts it is not readily available. its 7.5 amps 12 volt battery and it fit well in aquilas battery compartment. Now I searched more and found "spark" (must be) brand battery which is made in Malaysia (rs.600). Exide dude told me its also available in exide brand but since it wasn't ready hence I went with this Malaysia brand.
Ok guys, I replaced my bikes battery with 7.5 AMPS battery (brand is made in Malaysia) for RS.600/- from thane and its working fine. All problems are now gone and bike is getting instant start-up and I haven't charged it since last 3-4 weeks, so I guess replacing battery does the job.
Old 21st September 2007, 14:54   #35
zenx's Avatar
Thanked: 75 Times
Someone's selling a 2003 Aquila (abt 12k kms) for 1.25. How's that as a deal ? Of course, probably makes sense to wait till next year for the biggies...
zenx is offline   Reply With Quote
Old 21st September 2007, 16:39   #36
lohithrao's Avatar
Thanked: 163 Times
Maintianing these machines would be hard, i guess Max should be able to throw more light on it
btw Max i think the self starter works well with a 14 amp batt, do check your manual.
lohithrao is offline   Reply With Quote
Old 3rd December 2007, 21:32   #37
Proxima's Avatar
BUMP
MAX and the other folks - do you think I will be able to get a user Aquila for about 1 lac in good condition?
What about the maintenance and availability of spares?
Proxima is offline   Reply With Quote
Old 18th August 2008, 09:34   #38
Thanked: 30 Times
Hi .. even i think that the price of 1.4 lac is too much .. you should get the deal settled at less than 1 Lac..The lesser the better..
Abhishekjp is offline   Reply With Quote
Old 18th August 2008, 10:20   #39
lohithrao's Avatar
Thanked: 163 Times
Sameer did you buy the aquila?
Old 8th August 2009, 20:46   #40
If you folks come across an quila for second-hand sale with price tag around 1L please let me know
Sameer, did you buy it?
Max, how is your on-going experience with aquila?
Thanks to every one in this post for so much information
Note: I am a fan of cruisers, yet to own my first one !
sugumar is offline   Reply With Quote
Old 22nd August 2011, 12:38   #41
Thanked: 82 Times
Default Re: Hyosung Kinetic Aquila ? should i buy?
I know i am asking a query pretty late. However, after going through the posts, am sure that aquilla is a good cruiser. Will I be right to purchase one now... (i know I know, its 8 yrs old).. however, its owned by one of my good friends, has done only 8500 KMs (he owns it just for the kicks of it, i suppose :-))
He is ready to sell it below 80K.
Have done test rides multiple times. Runs smooth. He has replaced the battery with a new one (original). Only certain snags.. the tachy and speedy cylinders are little lose, the exhaust (silencer) has a hole due to corrosion (i s'pose).
Need expert advise from users of aqilla.
preetamkabra is offline   Reply With Quote
Buying a Hyosung Aquila 250? preetamkabra Motorbikes 49 27th December 2012 23:31
I want to buy Kinetic aquila ..in mumbai or thane Abhishekjp Motorbikes 20 9th September 2008 20:29
Hyosung Aquila for sale!!! Shan2nu Shifting gears 4 3rd December 2007 22:07
Wanted : Hyosung Aquila a4_attitude Shifting gears 0 3rd August 2006 12:24
