Old 28th February 2010, 22:06   #16
anupam9557's Avatar
Thanked: 20 Times
The discs are surely of a Pulsar. But it has been fitted directly to a drum i suppose.
anupam9557 is offline   Reply With Quote
Old 1st March 2010, 00:09   #17
Chipz's Avatar
Originally Posted by Rennjit View Post
donate! if you don't find anyone to take it, i'll have it
That is a good idea.. me second in line.
Friends what do you think about the idea of using Pulsar digital speedo in place of that. is it mechanically feasible. I have heard the pulsar pinion has magnets and sensors . what do you think about it.
Chipz is offline   Reply With Quote
Old 1st March 2010, 13:45   #18
Chipz's Avatar
I have given up the idea or using this Kinetic drum. Is it posible if I change the drum to pulsar, then I can use the fiero F2 speedo. can it be done in the same fork.
Old 4th March 2010, 12:46   #19
motionfreak's Avatar
Thanked: 54 Times
wrong. the disk brake assembly is genuin. there is no drum brake. even the front forks are from Kinetic GF170.
Whoever did this job did it neat.
I'm in Mumbai so I'm nearest !!
As far as installing the wheel hub sensor unit and the wire, it is feasible.
But you will have to check for the Tachometer, various tell-a-tale lights.
Problem will be with Spokes and it won't perform as good as this disk.
You can trust me as I have done a lot of DIY on my GF170laser. You need to be a good DIYer to maintain it in good condition and I'm proud that mine was when we parted.
Anyway. first thing you should do is, get a Pulsar analog Speedo cable and attach it to the hub. rotate the wheel and see if the other end of the cable rotates.
If it does then you can buy a Pulsar speedometer.
if your bike doesn't have a Engine RPM sensor then buy a Speedo from some other Bajaj bike which only has speedometer.
F2 did have a tachometer.
I wish you could be in Mumbai. I love bike DIY jobs.
PM me for any details you want.
motionfreak is online now   Reply With Quote
Old 7th June 2010, 20:36   #20
Chipz's Avatar
Reviving this thread since 3 months passed and nothing happened this far, and i got some facts wrong in my previous post.
I got this wrong.
Is it possible if I change the drum to pulsar, then I can use the fiero F2 speedo. can it be done in the same fork.
What I meant so say was.. is it possible to change the HUB, then can it be fixed in the existing fork, will the pinion wheel work. Will the disc be compatible with the new hub.
My friend is changing his pulsar spoke wheels to alloy. So i am going to get his front wheel hub and wheel.
Any help will be really appreciated.
Thanks,
Chipz
Rear Disk Brake Conversion freakrz Modifications & Accessories 8 11th October 2013 22:45
Swift - Scratched Brake Disk, Help...! yzfrj Technical Stuff 17 3rd June 2009 23:38
pinion defect in ford ikon! babe_on_wheels Technical Stuff 15 11th May 2009 20:47
Disk Brake problem in Bullet zoom_vroom Motorbikes 3 11th August 2008 20:57
Disk Brake to normal brake change? ramki067 Motorbikes 10 7th August 2008 14:19
