Old 17th March 2010, 20:00   #16
Leepower's Avatar
Thanked: 70 Times
Warning signs of the impending doom -- scarcity for Bullet 350 parts!!! No wonder I am paranoid. How much does the Bullet 350's piston cylinder kit cost? What all should I stock up????????
http://www.team-bhp.com/forum/motorb...s-my-bull.html (Stocking up spare parts for my Bull)
Leepower is offline   Reply With Quote
Old 28th April 2010, 22:13   #17
jingaboysr's Avatar
Thanked: 18 Times
I found a way to source my much needed parts ( head valves and piston rings ). I ordered the valve kit thorough EBay UK and got a friend of mine to order the piston rings from hitchcocksmotorcycles.
Awaiting delivery....
Another question, is it advisable to change the spring set and the valve guide along with the valves? I saw a bronze valve guide for sale in hitchcockmotorcycles, what difference does it make?
jingaboysr is offline   Reply With Quote
Old 28th April 2010, 23:16   #18
Thanked: 1,556 Times
Rishi,
Guides, yes. Bronze guides last longer. Springs, not required but if you're going in for a top end rebuild, you might as well get new springs in as they anyway need to come out while the new valves go in.
BTW, like I said before, low compression could be a plethora of factors. Did you narrow down to the cause?
Cheers,
Jay
JayPrashanth is offline   Reply With Quote
Old 28th April 2010, 23:45   #19
jingaboysr's Avatar
Thanked: 18 Times
Originally Posted by JayPrashanth View Post
Rishi,
Cheers,
Jay
Not yet...I read Nandan's piece on compression and narrowed it down to either piston rings or valves(I am running on loose tappets now).
I am waiting for the valves and piston rings to arrive to get my mechanic open up the engine and check the problem. I don't want to open it up and then search for parts ..
I should get those next week, I will keep you posted.
-Rishi
Which current RE UCE Bullet to buy? Or should I go for a used CI Bullet? swami69 Motorbikes 77 14th September 2015 17:50
All Bullet Gurus:: Need your Suggestion : Planning to Modify Bullet-Project Wanderer Shubhendra Motorbikes 56 6th October 2014 11:18
Bangalore cochin trip on my bullet CI500 jingaboysr Route / Travel Queries 7 23rd December 2009 12:16
