Old 2nd April 2010, 15:35   #1
Thanked: 38 Times
Question R.E Machismo 350 Ignition Timing Advance
A buddy with a R.E Machismo 350 wishes to advance his ignition timing. It's one with a TCI and looks like a pretty fixed one. The stator and TCI sensor cannot be adjusted. There's no movable base plate. Has anyone tried a Rextor 5:13 CDI on the Bullet? This one has an electronic timing adjust screw (potentiometer) rather than a mechanical advance. Where can I get one. Sadly the Machismo got rid of the Delco or else, I could have suggested Kiran Bhide's points conversion kit.
drsamuelk is offline   Reply With Quote
Old 2nd April 2010, 21:01   #2
Thanked: 1,573 Times
First of all, why does he want to advance the timing? TCI is a set and forget system. The two possible ways to advance the timing would be to reduce the spark plug gap or alternatively advance the cam timing by adavncing the intake cam by a tooth or so. I would suggest against both of these methods.
Cheers,
Jay
JayPrashanth is offline   Reply With Quote
Relation between Ignition retard/advance and AFR chetanhanda Technical Stuff 36 11th February 2013 01:02
Ignition Coil - Machismo AVL 350 Gordon Motorbikes 10 10th November 2011 19:20
How does TAP (Timing Advance Processor) work? sukrit7 Technical Stuff 12 19th October 2010 14:25
LTFT , Ignition advance in Vtec chetanhanda Technical Stuff 5 30th October 2006 23:55
2000 Royal Enfield Machismo for sale / 350 CC / Green / Bombay (Andheri) nitinhegde Shifting gears 0 12th July 2006 16:31
