Old 4th July 2012, 06:19   #16
Rennjit's Avatar
Thanked: 84 Times
Default Re: RE Bullet 4 speed to 5 speed gearbox swap
Originally Posted by Hammer & Anvil View Post
.... OK- I am searching for help as follows: I want a pre-1980 350, and I need to change it to a LHS Shifter to match my other motorcycles. The possible solution being that I mate it to the 5-speed and use its LHS shifter to be able to ride all my bikes without having to worry about downshifting instead of braking. ...
Since you are considering 5s box, why not get a 5S CI electra? & give it Std 350 trims.
RE sold 4S-LH shift models in the US before 5S box was offered. you could have a look at getting whatever bits required for conversion. Though these were not same as regular 4S-RH in shift quality, it offered a solution for LH shifter needs.
Rennjit is online now   Reply With Quote
Old 29th July 2012, 13:23   #17
Hey all,
I know this reply is very late but i had done this conversion. Im attaching a photo. Cost about 2k at chennai including shifting the brake lever to the left side. Mine is a 5s Electra. Desideep is right that it makes no difference which year model CI you buy. the newer ones are of better quality. The old bike myth is just an old wives tale. Rennjit's suggestion that you buy a 5S electra is good considering all the mods you want to do.
PS: Making the right hand conversion will make the 5s leaky as you are drilling right into the oil tank of the gearbox.
dennie is offline   Reply With Quote
Old 30th July 2012, 10:50   #18
Thanked: 99 Times
Don’t we need to open and reassemble the gear box for this? If you have any photos during operation, please post. Ho the left side opening sealed?
(Alok) is offline   Reply With Quote
Premier Padmini 137D Gearbox Swap mituadas Modifications & Accessories 12 5th August 2009 20:48
Engine and gearbox swap for 1991 SWB Trax citron Modifications & Accessories 16 24th November 2008 22:38
Bullet gearbox trouble nakedflame Technical Stuff 3 8th January 2008 10:06
Willys Jeep Engine & Gearbox Swap dinya Modifications & Accessories 5 17th November 2005 10:06
