Old 2nd May 2010, 14:29   #1
sachinj12's Avatar
Thanked: 162 Times
Default Issues with my Bajaj XCD 135.
I have Bajaj XCD 135, 15 months old, 8.3K clicks on the odo. Running on stock tyres ( Euro grip company ). Whenever I ride above 55kmph, I feel my rear wheel swing ( I just don't know how to explain, I will try my best).This does not happen every time, is occasional. I feel as if the rear wheel just skids to the right, have lost control on one or two occasion but haven't fallen down. This problem persisted right from the beginning, but I ignored it as I thought my mind was playing games. I mentioned this to the S.A during 4th service, he suspected wheel alignment issue. Even after wheel alignment the problem persists.
Worst part is I have experienced this even in moderate speeds (around 30-40kmph). I just can't figure out what is the problem. I have lost confidence on my bike and never cross 60kmph after these incidents.
Please help me out folks.
sachinj12 is offline   Reply With Quote
Old 2nd May 2010, 14:40   #2
DRIV3R's Avatar
Thanked: 1,433 Times
This happens in any bike if u ride along the center of the road,(as there are irregularities) where the road markings are usually there. Try riding in some other road, more towards the left and see if it still persists.
If yes, put your bike in the center stand and catch hold of the rear wheel by hand and check for any horizontal movement. If so, your swingarm bushes have gone kaput. Get them replaced. Also check if the rear axle nuts are properly screwed in.
BTW, those Eurogrips do suck to the core. Very slippery, especially during hard braking and rains. Get yourself MRF/Dunlop/Michelin ASAP.
DRIV3R is offline   Reply With Quote
Old 2nd May 2010, 14:53   #3
sachinj12's Avatar
Thanked: 162 Times
Thought so, tried it on different roads, at the corners. Still same effect
Will try these. Do these go bust so early?
EDIT: Tried these, no horizontal movement.
Completely agree, their tyres are useless. Riding in the rain is a nightmare.
Thank you very much.
Do you suggest changing of tyres? The tyres are in good condition- no uneven wear, cracks etc. I ride sedate, no spirited sprints.
Old 2nd May 2010, 15:00   #4
DRIV3R's Avatar
Those tyres dont wear so fast, mate ! Go for a change if you get a considerable buyback amount for the current Eurogrips. After the change, the handling and braking will improve by leaps and bounds.
BTW, check for the tightness of the swingarm nuts too, while checking the rear axle nuts!
Old 14th June 2010, 16:31   #5
sportz_kruzer's Avatar
check the shock absorbers. are both of them set to the same level? As posted above also check swing arm for horzontal movement. They might not move when you try it by hand, but may do so under load.
sportz_kruzer is offline   Reply With Quote
Bajaj XCD 125 DTS-Si BunnyPunia Motorbikes 29 28th November 2013 14:02
Clutch issue with Bajaj XCD 125 DTS-SI vishwasvr Motorbikes 0 20th July 2011 11:11
Bajaj XCD Recall varma Motorbikes 80 31st August 2009 08:01
Bajaj Auto's New Game - XCD Sprint 150/Pulsar 200Fi/New P220 five46 Motorbikes 11 9th November 2008 11:51
Bajaj Discover 135 - All new with Digital Console etc blue_pulsar Motorbikes 2 18th August 2008 02:15
