Old 16th May 2010, 13:52   #1
Rollin' Thunda's Avatar
Thanked: 71 Times
Default TBTS: need help to fix a slip-sliding feeling
Today, when I was on a ride I noticed that my 2009 TBTS was not responding properly during direction changes. The rear-wheel seemed to to be slipping/sliding a little bit every time. I though I had a flat tire, and stopped to check. There was no flat, but I noticed that the entire rear-wheel assembly had developed some side-ways 'play', i.e., it moved side-ways by about 5 mm when pushed.
I tightened all the nuts in sight that seemed relevant, but no change. Does anyone know what may be the cause? It seems unsafe to ride at high speeds with this problem.
Rollin' Thunda is offline   Reply With Quote
Old 16th May 2010, 14:22   #2
akas_chauhan's Avatar
Thanked: 22 Times
What about a wheel alignment then. I think that should solve the issue and how much tyre pressure you keep in both tyres.
akas_chauhan is offline   Reply With Quote
Old 16th May 2010, 15:36   #3
Randhawa's Avatar
Thanked: 270 Times
Probably your swing-arm bushes are gone. Get them replaced, hardly takes 20min to change them.
Randhawa is offline   Reply With Quote
Old 16th May 2010, 16:22   #4
Thanked: 71 Times
Akas, Randhawa, thanks for the quick responses. I'll take it to the RE service centre and get it fixed.
I had the standard 22(F)/32(R) tire pressure, as I always have. I don't think that is the problem.
Old 16th May 2010, 20:19   #5
Randhawa's Avatar
Thanked: 270 Times
Na man, the pressure you are keeping is just fine.
Old 26th May 2010, 11:04   #6
jeeva's Avatar
Thanked: 559 Times
Even though its not yet time for the swing arm bushes to give away, do check it.
I suspect the wheel bearings.
jeeva is offline   Reply With Quote
Old 26th May 2010, 11:51   #7
bblost's Avatar
Thanked: 6,980 Times
Also check the spokes. Are they tight enough and is there any bend in the rim.
Old 26th May 2010, 17:27   #8
alpha1's Avatar
Thanked: 1,035 Times
Was there a pillion rider?
Old 26th May 2010, 17:31   #9
Thanked: 161 Times
your wheel bearings are busted.
howler is offline   Reply With Quote
Old 26th May 2010, 17:39   #10
bblost's Avatar
Also check if the tire is sitting correctly in the rim.
There will be a line on the tire less than a cm from the rim. The distance between the rim and this line must be a constant.
Also there will be tire alignment thing on both sides.
It will have these tiny notches. The number of notches on both sides must be equal.
Both these checks can be done without any dismantling.
Old 26th May 2010, 21:28   #11
Thanked: 71 Times
jeeva, bblost, alpha1, howler,
Thanks! that gives me a lot of options to suggest. I was away the past week and didn't take it yet to the mechanic. I will, in a day or two.
Old 26th May 2010, 22:06   #12
vivekiny2k's Avatar
Thanked: 184 Times
from the symptoms this seems more likely. I have had this in my bicycle years ago and can totally relate to that.
vivekiny2k is offline   Reply With Quote
Old 26th May 2010, 22:49   #13
Randhawa's Avatar
Thanked: 270 Times
Does the whole swingarm along with tyre moves sideways or just the tyre? If the whole thing moves then the bushes and if not then probably the bearings.
Old 27th May 2010, 06:40   #14
madhkris's Avatar
Thanked: 70 Times
Hi Rollin' Thunda. Did you get the bike checked? What seems to be the problem?
madhkris is offline   Reply With Quote
Old 27th May 2010, 09:53   #15
KA18's Avatar
Thanked: 69 Times
Relax man, he just posted yesterday night that he will get it checked in a day or two. Check the time of reply.
KA18 is offline   Reply With Quote
Front seat Sliding Lock malfunctioning on the Ford Figo. Tgo Technical Stuff 6 14th February 2018 06:59
Need Help before i Bite the Bullet - TBTS - EDIT- now delivered rm_arjuna Motorbikes 23 7th October 2009 15:06
Need help - Quick bumper fix for my verna shebin Indian Car Dealerships 1 2nd November 2007 15:34
Tray Sliding.... Time for fun in FWD cars too!!! karthik247 Shifting gears 21 16th April 2007 01:23
