Old 17th May 2010, 23:34   #16
Ripper's Avatar
Thanked: 21 Times
Here Goes,
Cosmetics:
1> Complete Paintjob >>> Rs. 4.5k Approx
2> Chroming of nuts,bolts and anything and everything that shines. >>>>Rs. 1k\
3> New Front fairing + Phantom Headlamp >>> Rs. 1700 Approx
Engine and misc:
1> Check the carb, get it cleaned, check the jets and float pin as you seem to get real low mileage.
2> Replace clutch plates and pressure and clutch bell if necessary.
3> Check the condition of the valves if worn out replace.
4> Replace timing chain
5> Change the gears to those in the Pulsar UG3 for smoother gearshifts
And a lot of other things as your mech suggests
Comfort and Handling.
1> Get the front forks realigned, overhauled with new oil seals and springs if needed
2> Upgrade to Gas charged shocks at the rear.
3> If possible change the rear swing arm to that on the UG3 with chain cover and a lot of other fitting that go into the mod. Again youll need the help of your mech.
Mods.
1> Change rear mudguard to that on the UG1/2 (dtsi)
2> Add magwheels and tyres. (17in) for better handling but slight drop in performance
3> You need a new exhaust... look around for the OE or the dtsi.
My bike,
http://www.team-bhp.com/forum/motorb...y-here-39.html (Modified Indian bikes - Post your pics here and ONLY here)
Ripper is offline   Reply With Quote
Old 20th May 2010, 06:53   #17
Originally Posted by tantragna View Post
(smoke does not show up at the exhaust when the clutch is worn-out, it is a different issue.)
Ya, now you know why I created this thread? I thought smoke shows when clutch plate was worn-out because I saw a guy insanely driving a scooter with dense white smoke coming out years ago when I was a child. I walked to him and asked if he designed it like that. He laughed and said the clutch plate is gone and needs to be replaced. So that is what I remember until now
If you are not a 'Chris Pfeiffer' fan,.
Come on. I stay 1KM away from people doing stunts. It is a 2 wheeler and I want to use both the wheels, wheelie and all is waste of resource
3. FZ headlight! - anything you like, its your bike, your taste .
Naa... Your smile makes me drop the thought.
@All Thanks a lot guys, response is highly appreciated and looks good.
As of now, I don't want my Engine to be opened. However, points noted down and made of list of things to change.
1> Chroming of nuts,bolts and anything and everything that shines. >>>>Rs. 1k\
2> New Front fairing + Phantom Headlamp >>> Rs. 1700 Approx
3> Replace clutch plates and pressure and clutch bell.
4> Check the condition of the valves if worn out replace.
5> Replace timing chain
6> Change the gears to those in the Pulsar UG3 for smoother gearshifts
7> Get the front forks realigned, overhauled with new oil seals and springs if needed ( was planning to change this completely)
8> Upgrade to Gas charged shocks at the rear.
9> Change the rear swing arm to that on the UG3 with chain cover and a lot of other fitting that go into the mod.
10> Add magwheels and tyres. (17in) for better handling but slight drop in performance
11> A new exhaust...
How does is sound? Any more changes you think I should do (Except the Engine)? Would love it if someone provided the approx price of all these stuff 1 by 1 to make sure am not thugged by the goons.
Ranjan Sharma is offline   Reply With Quote
Old 20th May 2010, 08:17   #18
tantragna's Avatar
Thanked: 23 Times
So, you think you can get the gears upgraded without opening the engine!
Ok, you can get the clutch assembly for little under 1k.
I think the engine note in the classic pulsar is what people crave for! Just my thoughts, choice is yours!
Happy motoring!!
tantragna is offline   Reply With Quote
Old 20th May 2010, 09:25   #19
Happy motoring!!
I used the wrong word I guess. By 'Engine open' I meant, no modification on the bore, pistons etc..
BTW, you are making me hate this smiley
Old 20th May 2010, 09:40   #20
tantragna's Avatar
Thanked: 23 Times
Chill dude! Only showing some humor, that's it! No offense meant there! Trying to help you there, if you dont like my comments just tell me! Will vanish out of this thread!
'Engine open' are not the WRONG WORDS by the way, it has to be opened to do that work.
One more point, if you open the engine to upgrade gears & find out the bore/piston worn out, then it has to be reworked or else there is a strong chance that you won't even get the existing engine performance if it is assembled back as it was before. If at any chance youarer opening the engine, keep atleast 5k handy just in case!!
Old 20th May 2010, 11:00   #21
Yeah I understand, but I want to do the engine work after everything else. I am not automobile expert so I don't know what all stuff is inside the Engine. For now, it everything except the engine. Once everything else is done, I will go for the Engine work. I want to see the difference of performance with only other parts changed and other parts+engine parts changed.
I am anyways buying another automatic scooter like Activa or a Deo, but want to keep my Pulsar because I don't want it to go. In the meanwhile I can experiment too..
Modifications For Pulsar 150 Classic Kick Start msvg Motorbikes 4 16th March 2011 16:48
Pulsar 150 Vs Pulsar 180 !!! EDIT: Its the 180 NOTORIOUS Motorbikes 34 24th June 2010 17:49
Rear tyre for pulsar 150 classic venkatesh_t3 Motorbikes 16 28th April 2010 12:44
BACK ACHE On Pulsar 150 Classic :- long rides,Plz suggest Shock Absorbers and Cushion msvg Motorbikes 11 17th November 2008 21:29
pulsar 150 classic for sale manaa45 Shifting gears 0 16th March 2006 17:37
