Old 19th May 2010, 11:42   #1
Thanked: 33 Times
Default Adding electric start to a Pulsar 150
Since long I have been contemplating adding the self start option to my Pulsar 150 Classic-2003 model.
Has anyone done such a modification? Are there any issues? Is it reliable enough or will it conk off after few months?
Please help me with your inputs.
Thanks,
amohit is offline   Reply With Quote
Old 19th May 2010, 11:50   #2
tantragna's Avatar
Thanked: 23 Times
@amohit,
Pulsar engine is already designed for electric starter, so mod required.
You would have to add the starter motor, relay unit, switch & upgrade for a larger capacity battery, (around 7AH battery). I dont know the exact cost of the motor & relay, approx the whole upgradation would cost somewhere between 3-4k.
tantragna is offline   Reply With Quote
Old 19th May 2010, 14:54   #3
Ripper's Avatar
Thanked: 21 Times
Can be done.
1> Switch gear: Rs. 450-600, go in for the avengers RHS switch as it comes with an engine kill option.
2> Starter motor Rs. 950 (Varroc)
3> Battery 9AH Rs. 1450 (Amaron)
4> Relay and Wiring Rs 500 for the wiring (minda)
These are the major components required for the mod. Good Luck.
Ripper is offline   Reply With Quote
Old 19th May 2010, 16:06   #4
sportz_kruzer's Avatar
you'll have to get the sprag clutch installed too. Its a one way clutch which transfers rotary motion from stater motor to the flywheel, via a gear wheel (which also needs to be added). The sprag sits behind the flywheel/magneto accessible after opening the LHS cover on the gear box. A sprag basically prevents the engine from spinning the starter motor back, once started. i can give you the part nos if u need it.
sportz_kruzer is offline   Reply With Quote
Old 19th May 2010, 20:55   #5
naveenroy's Avatar
Thanked: 782 Times
Sorry for a slight hijack of this thread, amohit.. But does anyone know if the Varroc starter-motor can be used for a Thunderbird? Mine actually has the starter-motor but like most Thunderbird starter motors, it has gone kaput and I am only using the kick-start now.
naveenroy is online now   Reply With Quote
Old 19th May 2010, 21:32   #6
Randhawa's Avatar
Thanked: 270 Times
Nope you can not use the motor on Thunderbird.
Randhawa is offline   Reply With Quote
Old 23rd May 2010, 22:37   #7
mithun's Avatar
Thanked: 58 Times
Originally Posted by Ripper View Post
Can be done.
But how will the 9Ah battery fit in the battery compartment which is meant for 2.5 Ah battery ?
Old 24th May 2010, 00:49   #8
tantragna's Avatar
Thanked: 23 Times
Modification! You need to alter & fabricate a new battery mount for the bigger one.
Old 24th May 2010, 06:57   #9
Thanked: 33 Times
Cool thanks guys.
I think I will go and check with the service center guy about how complicated this setup will be.
Now, what I am not sure about is, if this setup will be reliable enough to give be trouble free service for next 3-5 years. Service center guys will obviously say it will. What do you guys think?
Old 24th May 2010, 11:14   #10
Ripper's Avatar
Thanked: 21 Times
The mod if done properly will be as good as an OE fitment. It should give you trouble free service for atleast 2 years at the minimum. Good luck.
Old 25th May 2010, 20:46   #11
mithun's Avatar
Thanked: 58 Times
Is that mod "very" difficult ?
Old 25th May 2010, 23:15   #12
tantragna's Avatar
Thanked: 23 Times
If you land on good hands for the mods, not at all! It is just some pieces of metal strip that has to be cut & welded to the chassis correctly with provision for the battery belt.
It would be advisable to take a pulsar having self start for replicating the dimensions of the battery mount, then it would be very easy for the fabricator.
Old 26th May 2010, 00:05   #13
quadra's Avatar
Thanked: 58 Times
I once checked with a HH service center supervisor, he told the this entire thing would be very costly if they have to do it...afaik, the amount was around 10k (not the exact mount coz it was long time ago)
Do let us know what service center has to say on this.
Did you check with the local repair shops ??
quadra is offline   Reply With Quote
Old 17th September 2013, 19:03   #14
Thanked: 38 Times
Default Electric Starter Installation on a Kick-Start Bike
Hi Guys, I would like to know if it is possible to install an electric starter on a bike that does not originally have one. I have an old Honda Unicorn that only has the kick-start option. Can I install an electric starter? How much would it cost? Would a bigger battery be needed?
abybabykcc is offline   Reply With Quote
Old 17th September 2013, 20:13   #15
bluevolt's Avatar
Thanked: 2,351 Times
Default Re: Electric Starter Installation on a Kick-Start Bike
AFAIK it is possible but not advisable because I don't think retrofitting a self starter will be a reliable option. It can be expensive and unreliable.
bluevolt is offline   (1) Thanks Reply With Quote
Jetting For My Pulsar 150 nikibusa Motorbikes 19 7th March 2012 10:47
Modifications For Pulsar 150 Classic Kick Start msvg Motorbikes 4 16th March 2011 16:48
Pulsar 150 Vs Pulsar 180 !!! EDIT: Its the 180 NOTORIOUS Motorbikes 34 24th June 2010 17:49
Pulsar 150 DTSi or Unicorn?????? 1000bhp Motorbikes 5 28th February 2005 21:21
Pulsar 150, Rear tire 120/18 nikibusa Motorbikes 3 22nd July 2004 16:30
